Question about HP Photosmart C6180 All-In-One InkJet Printer
Empty cartridge warning
My HP C-6180 keeps telling me that the yellow cartridge needs replacing and I have just put in a new one. Eventually after so many warnings, it won't even let me print in black.
    President:
  • 1,138 Answers
Most problem experienced with hp photosmart c6180 is the yellow catridge error. Try cleaning the contact surface of the catridge and the printer using moistened cotton buds..if error continues, you should clear the error that keeps on displaying.. here's how: press & hold "*" key...while holding, press "#" key and then release both keys..."Enter Special Key Combo" will be displayed...press "1", "2" and "3" to display "Support"...press ">" right arrow button and release when "System Config Menu" appear....press "OK" and/or arrow key to display "Hardware Failure Status"...press "OK"....when "Hardware Failure Status:Clear" appeared, press "OK" to clear...press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".....press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".....the last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to procede..After this try to print...
Posted on May 15, 2010
  • 1,218 Answers
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Posted on Oct 13, 2010
Replaced empty ink cartridges in hp c6280 printer but computer says they're empty. help?
Did you remove the protective cover / tape, you re put the cartridge.
Jul 25, 2012 | HP Photosmart C6280 Printer
Printer keeps telling me that the yellow cart is empty and I have put a new one in
Are you positive it says the yellow cart is empty? Because that brother printer is designed to say that a cartridge is empty whenever ANY of the color cartridges are empty. Usually it doesn't tell you which one is really empty either. So even if you replaced the yellow cartridge and say, the black cartridge is empty, it still won't let you print until you replace that empty black cartridge, nor will you know which of the cartridges is empty unless you pull them out of the printer and manually check the ink levels.
Its pretty much a guessing game with those old brother ink printers.
Hope this helps :)
May 03, 2010 | Brother MFC-5440CN All-In-One InkJet...
Hp black cartiedge is low on immediately
When you refill a cartridge, the printer will keep warning you that it is empty- a message pops out that says "low ink". That is because the printer sees the cartridge by it's serial number. The printer can't know that you have refilled the cartridge, so it keeps saying that it is empty. Once you put in a new cartridge, it will display the cartridge as full again.
May 02, 2010 | HP Easy Refill Kit for (HP) Black Inkjet...
New yellow cartridge installed. Printer still says it is empty. Tried two new ones so far. Have followed HP instructions to clean cartridge and contacts.
I have exactly the same problem with my HP C6180 - I have now replaced the Yellow cartridge for the second time, assuming that maybe the first replacement was faulty, but I just bought a new multipack and can't afford to keep on trying a new cartridge in the vain hope that it will eventually work.
There has to be a fault with the printer, but of course it is now well out of warranty.......I previously regarded HP as a company that produced quality products, but this image is in danger of being severely tarnished, added on to of my daughters PSC2355 dying last week.
Nov 07, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP will not recognise new cartridge
The problem you are describing with the yellow cartridge sounds like ink starvation possibly due to a clogged print head or an air bubble in the print head. Since the machine is so new I would contact HP to get the print head replaced. As for the magenta cartridge, exchanging it for a new one at the store you bought it from should fix the problem. It sounds like the chip on the one you have is either damaged or wasn't set to read full ink levels.
May 29, 2009 | HP Officejet Pro L7680 All-In-One Printer
New cartridge and still shows ink low
Since the printer cannot detect the amount of ink in the cartridge, the OEM companies place a chip inside of each cartridge that counts the number of pages that you print. When the cartridges reach a certain number of pages, they automatically tell your printer that you are running low on ink, even if it is not empty yet.
If the cleaning steps on your printer is still not fixing the color, try the very first tip on this page:
http://swapink.com/Merchant5/merchant.mvc?Screen=cp_faq&Store_Code=SI
I have found that using warm water on the paper towel clears the prints up better.
Jan 25, 2009 | HP DeskJet 1280 InkJet Printer
HP 6180 with a persistent empty yellow cartridge
Problem fix step by step:
1) Remove all ink cartridges, not just the affected cartridge. Close the doors and the access door.
2) Unplug printer without powering it down.
3) Plug in printer while holding down the # key and the number 6 key simultaneously. DO NOT RELEASE THEM! The printer will start up and then after a few seconds shut down.
4) Press the "On" button
5) Reinsert all ink cartridges.
6) Send me thank you notes. I spent hours on chat with HP support until we got the correct fix!
Dec 23, 2008 | Office Equipment & Supplies
HP 6180 with a persistant empty yellow cartridge error
try wiping down the metal parts of the ink cartridge with rubbing alcohol. as well as the inside of printer where it connects in.remember to unplug while doing this.then give it another try.
Dec 23, 2008 | Brother MFC 240C All-In-One InkJet Printer
Ink Cartridge Error
on your cartridges there is a chip that detects if the ink is low. The chip on your yellow cartridge is bad. You should return the cartridge for a new one(if you still have your receipt) or visit a Cartridge World in your area and they can put a new chip on for you
Aug 12, 2008 | HP Photosmart C6180 All-In-One InkJet...
Replace cartridge.....
Hi Dutchduo,
Please click on the web link given below and perform the steps as provided in the web page to fix the issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00414417&cc=us&lc=en&dlc=en&product=439491
Have a great day!
Mar 18, 2008 | HP Photosmart 3310 Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
430 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
