Question about Blue Rhino Uniflame Patio Heater Stainless Steel Commercial Triple Dome
Blue rhino can't get pilot to stay lit. flame burns below pilot area
  • 8,404 Answers
There is dirt in the pilot tube. blow it out with compressed air.
Posted on May 16, 2010
Pilot light won't stay lit when I let go of the igniter knob. Flame is yellow and long.
Sounds like the Thermocouple has failed and needs to be replaced. It's not difficult to do. But, finding the part may be. Blue Rhino, is the manufacturer for Endless Summer Patio Heaters, so start there.
May 19, 2011 | Endless Summer 2009 Open Flame Patio...
My pilot lights when I push the pilot button in but goes out automatically when I release it.
The Thermocouple, which keeps the flame lit, when in operation, but stops the gas flow if the pilot goes out has failed and will need to be replaced. You can purchase one online, directly from Blue Rhino.
Hope this helped you solve the problem.
May 08, 2011 | Blue Rhino 2350 Heater
Pilot lit will not stay lit check it and blew it all out with air .
Hi and welcome to FixYa. I am Kelly
A few things to do here.
1. Make sure the thermocouple probe is positioned directly inside the pilot flame.
2. Disconnect the thermocouple from the gas valve and clean the blunt end of the thermocouple AND the area in the gas valve that the thermocouple blunt end mates to. Any dirt, debris or corrosion in this area will cause the symptom that you describe
3. Worst case if you do not have a blue pilot flame you may have to remove the pilot orifice and clear the pin hole in the orifice.
4. If you have a push and hold type pilot lite gas button... press hard... and let go several times.
5. After all of the above the symptom is still present.... you will have to replace the thermocouple.
I read that you already did the burner tube cleaning.
Most of the time this symptom is caused by the thermocouple either being in the wrong position, a defective thermocouple or a dirty connection surface area where it mates to the gas valve.
Thanks for choosing FixYa,
Kelly
Jan 30, 2011 | Endless Summer Blue Rhino 235000...
Pilot light will not stay lit, even after holding for the required 60 seconds. Need manual and replacement parts.
Go to the Uniflame Home web page and you can download the Owners Manual for your heater in a pdf format. You can also order parts or find a dealer in your area that stocks parts. Uniflame is owned by Blue Rhino.
Jan 26, 2011 | Uniflame 200209 Open Flame Patio Heater
Pilot burnes yellow and stays lighted when I turn the may burner on its on for about 30 sec. then goes out pilot and burner
You may be low on gas in the tank and there's not enough pressure and/or volume of gas to sustain it. Also, try carefully cleaning the burner elements.
Jan 19, 2011 | Blue Rhino ES200209 Open Flame Gas Patio...
I have an Empire gas heater. It does not stay lit. It will go out after about 30 minutes to two hours. When we first started having this problem if you set it where it wasn't completely level it would stay...
Look at your thermocouple. Is it glowing red from being heated by the pilot flame? Is the pilot flame blue or yellow? You may have a dirty pilot orifice that is not heating your thermocouple enough to keep it lit after the burner cycles off. A yellow flame will eventually burn the tip of the thermocouple, which causes more frequent problems and eventually it will not work at all. If you have a can of compressed air with attached straw, use it to blow out the pilot orifice (with the gas off) where the pilot flame usually burns. Then examine the tip of the thermocouple and see if it is still round and smooth. Jagged or irregular tips mean it should be replaced. A blue pilot flame and a new thermocouple should do it. Hope that fixes it for you. Douglas
Jan 04, 2011 | Heating & Cooling
Pilot light won't light the low flame or stay on
If the pilot light will light at all but not have a good strong flame I would remove pilot assembly and clean it thourghly,being careful not to damage pilot orifice. Reinstall pilot and seeif you have any improvement. If pilot still won't stay lit I would replace thermocouple being careful to make sure top inch or so is in pilot flame. Hope this helps. Thanks
Nov 20, 2010 | Blue Rhino Heating & Cooling
Blue rhino endless summer patio heater
Try replacing the regulator, easy fix. If it is not the regulator, the thermocouple could be bad, or the pilot flame may not be strong enough to heat the thermocouple. Take apart the head, if you are comfortable with it, and see if there is a blockage in the pilot assembly.
Jun 28, 2009 | Blue Rhino Portable Patio Heater
Blue flame heater pilot wont stay lit
There is a therma-couple that the flame burns against. When it is working correctly it allows gas to travel to the flame. When it goes out you get no gas, as a safety feature. Replace the therma couple and it should work again.
Oct 06, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Blue Rhino Uniflame Patio Heater Stainless Steel Commercial Triple Dome Logo
138 people viewed this question
Top Blue Rhino Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Blue Rhino Pool and Spa Expert? Answer questions, earn points and help others
