Question about HP Pavilion dv1000 Notebook
HP Pavilion dv1000 AC Adapter Problem?
I have just started having difficulty with the power cord suddenly not working and having to rely on battery power. It happened the other day and somehow I got the power cord working again. Of course I don't know what I did to make this happen...I think I just wiggled some of the connections and rebooted. I tried all that again today, but no luck.
Is there a way to tell if I just need to replace the AC adapter or if there is a more serious problem with the power jack to the motherboard?
  • oliverdog Mar 31, 2008
    Thanks so much for your advice. I ended up testing it with another AC adapter first (which I didn't have handy when I asked the question) and it was confirmed it was the adapter. I purchased a new one and am good to go!
    Novelist:
  • 119 Answers
Dear oliverdog
I am sorry to hear your problems but I hope we can figure this one out. Troubleshooting the AC power is not always easy. Let do the easy stuff first.
Warning: If you are anaware how to handle voltages please dont follow this guideline. It might hurt you or you equipment. Furthermore all parts if covered with warranty can and will be replaced, dont do any repairs as this will void it at some point. (Just to let you know)
If you have a multimeter you can test the actual power supply DC voltage output. When plugged in it should read certain voltages (look at the bottom of the plastics at the power cord (brick) to find the label regarding the voltages. Probably will be saying something like 18V 4.5A) You have to measure this with the multimeter at an appropriate scale (20/40 volts). If you are and not reading any serious +/- fluctuations then the AC input and DC output is fine!
Otherwise start searching for a replacement part.
If the power cord is reading fine the problem cannot always be the DC POWER Jack though. I had an AC Jack problem with a HP ZX5000 earlier this year but this is not always the case.
Please go to the following link (simply press left click/or copy paste to your browser and it will start the download automatically)
It is the complete HP Service Manual on how to troubleshoot and take apart your laptop.
h20000.www2.hp.com/bc/docs/support/SupportManual/c00444244/c00444244.pdf
At page 48 you will find extensive information of step by step info on troubleshooting your power AC up to motherboard problems. It is unfortunately too long to elabore here but it has good info in it.
Anyway, I hoped I have help you! (For anything else please ask me again. I will help!)
Please dont forget to rate this rating if it has helped you.
Posted on Mar 31, 2008
SOURCE:
Pavilion dv 1000 battery adaptor
You may take it to a tech center to fix it or buy a new charger. As for the cost, it is almost the same. So it is better to get a new adapter.
Replacement HP Pavilion DV1000 AC Adapter 65Watt 18.5V 3.5A
Nov 22, 2012 | HP Pavilion dv1000 Notebook
My hp pavillion was no power without ac adapter
if the pc is not getting power without the ac adapter then most likely the battery is dead if it does not take a charge via the ac adapter then then the battery is no good or the ac adapter is busted
Apr 28, 2010 | HP Pavilion dv1000 Notebook
I bought a new ac charger for my hp pavillion dv1000 it will not power on
Check and make sure the Voltage on the AC adapter is the exact same as your previous one. Just because the connector fits in the port, doesn't mean it's the right one. Look in your manual to figure out if your AC adapter voltage is correct. If it is, it's possible that you have a dead battery, it happens when surges happen during power outages. If it's so, look on the HP website for a new replacement battery. It should allow you to type in your pavillion model number.
Jan 08, 2010 | HP Pavilion dv1000 Notebook
No power hp pavilian dv 1000
OK i will assist you through this (where you have any difficulty comeback i am always here) First take off the docking device, is power up on battery power if No power up AC next power up the docking device. Second Reset power. cheers
Dec 09, 2009 | HP Pavilion dv1000 Notebook
Bought new power cord for pavillon dv 1000 and
If the laptop runs on batter but cannot run on the AC adapter, you have a broken DC Jack. If you laptop cannot power up with the battery or flash low battery indicator, you laptop is dead.
Oct 30, 2009 | HP Pavilion dv1000 Notebook
My comp shut off and wont turn on anymore.. lightening bolt comes
Please remove the battery and ac adapter and then press and hold the power button for 25 - 30 seconds after that connect the battery back and then try to turn on the machine. if not remove the battery and just plug in the adapter and then try to turn on the machine. If still not working then try to swap the ram. or else your system motherboard requires to be replaced.
Jul 15, 2009 | HP Pavilion dv6000z Notebook
Laptop wont boot and the battery and power lights flash
a simple power cycle might work. Take out the battery but keep the ac power connected. hold the poewr button down for 1 minute. then hit the power button again and it should poewr back up. If this doesn' t work. iyou said hte battery light flashes so the problem isnt the battery..the problem might be hte ac power adapter..if you have a warranty this would be a good time to call them. Try the power cycle first though this fixes the problems lots of the time
Apr 15, 2009 | HP Pavilion dv1000 Notebook
HP pavillion dv1000 won't charge
Try using your laptop without the battery and just using your power supply (new universal or your old one).
If your laptop works on just mains power it means your battery is causing the problem, which is not unusual.
Aug 07, 2008 | HP Pavilion dv1000 Notebook
No power and there is a clicking noise in ac power adapter
hearing a clicking sound inside an ac adapter is something very unusual. it could be possible that this is a factory defect. call hp and ask for a replacement of another brand.
Jun 17, 2008 | HP Pavilion dv1000 Notebook
Power LED flashes three times-no boot
Try this. Power down. Remove the battery. Remove the memory. Replace the memory. Replace the battery.
Try to power back up.
Best of luck...
R-
Nov 05, 2007 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
191 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
