Question about Mitsubishi VS-45607 45" Rear Projection Television
Replacing capacitors on Mitsubshi projection TV
My TV shuts off by it self and will not power up for about 3 to 4 minutes. Told to replace the capacitors. Which ones and with what capacitor? Found the board in the TV but confused what to change out. Please let me know. Thank you.
    Problem Solver:
  • 5 Answers
You should start looking for any capacitor that looks like it is bulged at the top. You could also look for discoloration on the tops of them.
Make sure you use a high quality replacement and be aware that even if you find one that looks bad, you may have some that are bad but don't have any visible signs.
Posted on May 21, 2010
Panasonic TV shuts off after a couple minutes
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 05, 2012 | Panasonic PT-50LC13 50" Rear Projection...
WS-55411 What seven capacitors need replacing? 2-3 code Problem
U check the power supply board,check all cap,and replaced it?Ur tv make buzzing noise when u turn on power?Ur flyback is dead.
Mar 17, 2010 | Mitsubishi WS-55411 55" Rear Projection...
Have a mitsubshi model no vs-5017s tv turns on sometimes.sometimes just clicks goes off when trying to turn on.i think it might be the timer but dont know how to reset.help
If it is the timer, the timer would be found in your menu, and it would have a minute timer showing on the screen. Otherwise you proabably have the all-to-common power supply failure. It can be tested with voltmeter. You can test the capacitors in the power supply with a capacitor tester. These capacitors due tend to go way more quickly now days.
Sep 09, 2009 | Mitsubishi WS-55511 55" Rear Projection...
New bulb/TV still shuts down
Its far more likely the result of the power pwb capacitors that have failed. As the 34 code will appear if the capacitors fail on the Power PWB. You can get the V26 DLP Power repair kit at the following link.with free instructions
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Apr 30, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Toshiba 50H81 Sound but no picture
if you heard a pop that would be a capacitor unable to take the voltage, hopefully no other damage, you will need to identify the capacitors that have gone and replace the parts with the same number ie 40v 300uf 105c remember don't touch the 400v or 200v capacitors as they will still have power in them, discharge them by placing a metal object over the + and the - on the capacitor and then the board will be safe.it could also be the bulb has gone. you would need to check this as if the bulb has gone the tv will shut down. and flash but usually there is an led that flashes to tell you bulb failed.
May 28, 2017 | Toshiba 50H81 50" Rear Projection...
After 2 or 3 minutes tv turns off it self
CK capacitors 114,120,150 if any of them is puffed up on top it is bad so replace all 3 capacitors cp150 2200uf 16v other 2 are 220uf 35v resolder all pinns on FBT flyback Transfomer.
Feb 15, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
KDF-46E2000 turns off then back on by its self
* Most common would be a couple of capacitors in the power supply that are not letting the proper voltage to the lamp.
* The lamp itself is not working properly.
Jan 25, 2009 | Sony KDF46E2000 46" Projection HDTV
Replacement lamp on mitsubshi tv
That model can have two 3300uf capacitors that go bad on the PWB which will cause the set to detect a lamp abnormality and trigger a red light on the lamp. You can find out more info on it by going to the following link and leaving them a email with your model number and symptom.
Jun 17, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishe WL 82913
does the lamp indicator light as red? let me know what the status light does...is it blinking or solid give me some info and I should be able to help you also mitsubshi had some problems with jamicon capacitors with a thousand uf and above ratings that are no good 95 percent of all dlp problems can be traced to those bad capacitors
Apr 10, 2008 | Mitsubishi WL-82913 82" Rear Projection...
Green light blinking, tv won't turn on
Had a certified Mitsubishi repairman out on Wednesday. It was indeed the four $1.69 capacitors that needed replacing. The bill was $376.95 which included the service call to my home.
The repairman told me that prior to January '08, this was a $700 fix. Somehow I still wasn't all that excited.
If this problem is this common, the repair should be handled completly by Mitsubishi. I'm still not convinced that just replacing the defective parts assures me of a long-term fix.
I believe I've purchased my LAST Mitsubishi product of any kind. Yes, I'm bitter.
Jan 01, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
163 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
