Question about Refrigerators
Side by side and water when defrosting running out front corner of freezer door onto floor. The drain hole in back of freezer is full of water?
  • 4,066 Answers
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on May 15, 2010
Kenmore side by side water leaking from freezer
You can buy a kit from whirlpool. In the kit is a metal tab that mounts onto the defrost heater. It is long enough to go into the hole. When the heater comes on for defrost the heat transfers down to the hole and keeps it from getting plugged up with ice. Part number 819043
Feb 05, 2010 | Freezers
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
Water runs down back of freezer side and fills small tray on bottom of freezer side then refreezes and over flows onto floor past door seal freezer side also makes a surgeing sound at times
The defrost drain hole in the small tray is frozen over. Turn off the refrigerator. Remove the shelves and bins. Carefully break up the visible ice and dispose of it.
Use a hair dryer to defrost the drain hole. It will be a slow process. Be patient.
Jan 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Once or twice per day, water on floor below freezer door
check for plugged drain at back bottom of freezer if plugged/frozen over defrost and clear with hot water and remove all ice.
Nov 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
First thing this a.m. we discovered a puddle of water on the floor on the left side of the fridge. This is not the first time....so we are wondering what is causing this? I am guessing about the profile #...
You have a plugged defrost drain.
Unplug refrig. Unload freezer. Remove shelves. Take back panel out of freezer. Use a turkey baster with hot (not boiling) water to flush water in the area of the defrost drain hole until it is clear and water will run through it into the defrost drain pan under the refrig. The drain is a hole about the size of a nickel, usually in the very back center, below the cooling coils. You can use the turkey baster to force water into and eventually through the drain hole. Remove ice from floor of freezer.
Re-assemble, refill freezer, and plug in. Now, when your refrig defrosts, the water will go out the drain instead of onto the freezer floor and out the freezer door onto your floor.
Aug 05, 2009 | GE Profile PSI23NCR Side by Side...
Ice buildup on floor of side by side freezer floor..
Inside the freezer in the lower part of the back wall there's a drain hole wich probably is clough and the water from defrost doesn't go through and freezes up .Put hot water to defrost it and keep pooring it until goes through.If is still clogh try with a wire but do it ery carefull to not put a hole in the drain plstic tube.
Apr 22, 2009 | Kenmore 50522 / 50524 Side by Side...
Kssp42qhwoo(7 yrs old)
Check and make sure you defrost drain in the freezer isn't frozen. The water may be coming from the bottom of the freezer inside. When the heater comes on to defrost the evaporator, the water drips in to a small hole in the back bottom of the freezer inside. If the drain freezes, the water runs out into the freezer on the bottom and eventually onto the floor in front of the freezer door. It will eventually create a gap and let moisture into the freezer and may show up in the refrigerator section as condensation. Remove the ice build up including the alluminum drain pan area where the drain is located. Pour hot water into the drain to defrost it. You may have to remove the back of the freezer wall on the bottom to get better access. If the water goes down the drain, its clear. If you need a part for your refrigerator, please email me on ebay under user name themackshack. Good luck! , Mack
Jan 06, 2008 | KitchenAid KSSP42QKS Side by Side...
Ice and water on bottom of freezer
sjlobo, sounds like your defrost drain pan is frozen over or has some gunk in it. When the unit goes into defrost the water is running onto the freezer floor and out the front. Remove the lower bin and check the drain hole. You may have to remove the freezer back panel. If you can, just use some very hot water and some sort of baster to unfreeze the drain. Check this first, Catriver..post back.
May 05, 2007 | Maytag MSD2758G Side by Side Refrigerator
Water leaking onto floor
Angels, sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a baster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear. Catriver..post back.
Dec 22, 2006 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
