Question about GE Microwave Ovens
Hotpoint RVM 225 BL 002 power reset. Internal breaker?
Hotpoint RVM 225 BL 002 power reset. Unit has no power. Wall outlet is hot. Is there an internal reset or breaker that can be checked? If so how do you find it?
  • GE Master
  • 9,047 Answers
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
I would suspect the fuse or magnetron thermostat.
Posted on May 16, 2010
How do I reset a older model microwave by hotpoint?
disconnect the power cord from outlet wall by 45 seconds.And try again. and ready.
God bless you
Jul 28, 2013 | Hotpoint Microwave Ovens
My GE JVM1750DM blew an internal breaker or fuse when I attempted to remount a lamp lighting the stove top; it had fallen out of its mount. Where is the internal reset or breaker located, and how do
There are fuses inside the unit. No internal breaker. A lot of the time that damages the main circuit board too. Blowing the trace that supplies the power to the bulb off of the board. will probably need a new baord, or someone to repair that one.
Sep 24, 2017 | GE JVM1750DM Microwave Oven
No power to microwave
Hello
Check the Power Cord
Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
Switch the Outlet on
Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
Reset the Oven
Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
Check the Fuses and Breakers
See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
Oct 04, 2011 | Microwave Ovens
Model rvm 1335wc001 outlet has power, unit is dead
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 16, 2010 | Hotpoint RVM1435 Microwave Oven
G.E. ADVANTIUM 120 JUST WENT DEAD NO POWER AT ALL.
Bill,
I have the same unit. It just happened to me. DId you find a resolution?
I was using it on the oven mode and it just stopped working. It's completely dead.
Thanks
Bob
Apr 11, 2010 | GE Advantium 120 Convection/Microwave Oven
How do I remove my Hotpoint microwave RVM 44004? Two bolts visible from the cabinet down into the microwave. Removed them with zero result. No other fasteners visible in top or side cabinets.
It is much easier for two people to remove the microhood. If attempting alone, please move the range out so you can get under the micro to support the weight. If the range stays in place, protect the top from damage.
1. make a landing site to the side to protect the floor when putting the micro down after removal.
2. Disconnect the power cord in the cabinet above.
3. loosen the two screws in the bottom front corners of the cabinet above. When removed the front of the micro will drop, be ready for the weight. Busy times, tools in hands microwave coming down in front.
4. tilt the front down. pull the cord out of the upper cabinet.
5. with micro still tilted down in front, lift the back of the unit upward to free it from the wall plate.
6. remove the fasteners in the wall plate and remove.
Congrats, begin celebration.
Jan 20, 2010 | Hotpoint RVM1435 Microwave Oven
No power in the microwave. It is as if you unplugged it. Is there an internal fuse in the unit? There is power to the unit. The unit shows nothing on the panel and when you open the door, no light comes...
If you look at the back of the oven there are usually small fuses or breakers back there. Check to see if that is the issue. Also if you haven't already make sure the wall outlet is functional.
Dec 14, 2009 | Jenn-Air JMC7000 Microwave Oven
WE have a Hotpoint Microwave mounted over the stove and it is not vented to the ouside! It's model #RVM 1435! Can it be vented outside?
yes,
you will need to tzke the unit down
look on the back upper middle
you will see your vent fan
open the cover
pull the fan up
and rotate it 90 degrees, but you will need to install a vent for it
you can also turn it 180 degrees if you on an outside wall and the ven is directly behind the machine
Oct 26, 2009 | Microwave Ovens
Spacesaver powers off 2 seconds after resetting clock and time...
The clue is that you have to reset the clock. You are losing power somehow. the Main Board thinks it is being unplugged and it resets the clock and you have to start all over. The fact that after so many times it will finally work tells me that whatever bad connection you have is finally getting hot enough to expand and make a good enough connection to keep working. Intermittant connections are the worse to find. A lot of trial and error to find the problem. can be bad fuse and fuse holder ( in the unit), bad outlet, loose wire at circuit breaker, loose wire at outlet. Even a loose breaker where it snaps onto the buss bar in the Breaker Box. Etc, it an really drive you nuts trying to find it. Try the unit in a totally different area making sure it is on a compleately different circuit breaker and see what it does, if the problem follows the unit, the problems is in the unit. If not, electrical problems, outlet, breaker, panel,
Aug 18, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
533 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
