Question about MicroBoards Orbit (ORB-4201-01) Burner
My Orbit Manuel Sprinkler Sytems is not working all of the sudden. Its says power off and I can not get to turn on. All connection are plugged in. Any ideas ?
    Genius:
  • 1,354 Answers
Hi
thank you for using Fixya
if possible just open case there will be fuse for power just chack that may be fuse is gone just chack and replace that hope fully it will wirk if not then contact me
m42153
Posted on May 16, 2010
My orbit is wired right, but only sprinkler number 2 will work. It comes on when I push for 1 3and 4
If indeed it is wired correctly, and your wires go where you think they do, then your Orbit is defective.
Test by removing wires 1,2,3, and 4.
Push for 1, and touch wire 1 to the connector for 1. Sprinkler 1 comes on? Touch wire 1 to the connector for 2. Sprinkler 1 comes on?
If yes to both, then Orbit is broken.
Sep 06, 2016 | Orbit Hardware & Accessories
Where do I get a new gear box for traveling sprinkler Orbit
Once again a couple simple GOOGLE searches...
Here is the item on the ORBIT website.
Orbit Irrigation Traveling Sprinkler Motor Assembly
I've never bought anything from these companies so I don't know how legitimate they are. Use at your own risk!
Orbit Traveling Sprinkler Motor Assembly
Aug 02, 2016 | Orbit Garden
"my orbit easy dial 6 station quit working in auto
Does it work manually? If so, which is rare and almost unheard of I would replace the timer. You can't buy a less expensive timer $20 for a 4 station. Which explains why it is not working. If it doesn't work make sure it is plugged in and outlet has power.
Aug 11, 2013 | Orbit Irrigation 57856 6 Station Easy Dial...
Model# 57874
Copy following links to identify timer manual and general wiring illustration:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
http://waterheatertimer.org/images/orbit-connections.jpg
Do not connect voltage directly to COM and Pump terminals... these terminals have their own 24Volt AC output when timer turns ON. When timer turns on, the 24V flows to Relay. This action will cause electro-magnet to pull two points together, and that will turn on the pump.
Same with the sensor terminals. Do not connect power to rain sensor terminals. The rain sensor plugs into outlet, and produces it's own 24V ac output. So when rain sensor activates, this cuts power to timer, and then timer will automatically bypass the watering schedule until rain sensor again resumes power output to timer.
Gene
Jul 25, 2013 | Orbit Hardware & Accessories
Orbit Problems
Most likely timer is not plugged in or outlet has no power. Should display a plug with a circle around it with a line through it. If not. Check the wiring be sure the same color wire used for Common in the timer is used in the field. Should have 1 wire from each valve connected to it.
May 26, 2013 | Orbit 58872n Complete Yard Watering Kit
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
My Orbit 57899 is saying no ac but the outlet to where this goes is working fine
I believe that you plug a transformer into the outlet. If this transformer is not working, no power goes to the timer. Remove the battery and if the timer display goes out (and it may take some time, possibly hours) the transformer is in need of replacement. They are available at sprinkler suppliers and maybe even a local hardware.
Gary
Jul 03, 2011 | Orbit Sprinkler System Power Source...
I have an Orbit WaterMaster Sprinkler control, it is hooked up, but there is a light bulb that says power off and the sprinklers won't turn on. They will turn on manually at the sprinkler station. Can...
There are 3 things this "off power" "light bulb" could be. Blinking red light? means fuse has gone out. Check the power source where the unit is plugged in to. Is the GFI popped out? plug something else like a fan or something into the socket to test. the third thing is a short internally. Call orbit technical assistance. they're great.
Apr 11, 2010 | Orbit Sprinkler System Power Source...
Orbit sprinkler system
Have you programmed the new one with all the info for date and time? Did you set the zones for the days you want and watering times?
Jun 16, 2009 | Orbit Sprinkler System Power Source...
MicroBoards Orbit (ORB-4201-01) Burner Logo
393 people viewed this question
Top MicroBoards Computers & Internet Experts
Rick Moore
Rick Moore
 Grubhead
Grubhead
Are you a MicroBoards Computer and Internet Expert? Answer questions, earn points and help others
