Question about Philips Health & Beauty
My FlexCare toothbrush seems to be on Easy-start all the time. I have followed the instructions for deactivating and activating this feature, with no change in the power. The toothbrush sits on the charger 24/7.Any suggestions? M. Thomas marjohnthom@yahoo.com
  • 661 Answers
Call the manufacturer and notify them that your brush is defective. If your symptoms are true for all brushes then they are selling something that does not match with their advertising. If you dont get satisfaction report them to the FTC and possibly the BBB.
Posted on May 15, 2010
Why is it making a loud noise after reacharging,never before
Are you sure the brush attachment is "tight" to the handle? Do you have a new brush to try? It should confirm handle is bad or it is the brush attachment "tightness" .
Mar 11, 2015 | Sonicare Phillips Philips Sonicare...
I am currently using the electric Phillips toothbrush. Would like to change the batteries but having problems removing batteries with all the glue. Did not want to damage circuit board. Need more...
Take a look at this video from YouTube; hopefully it will help you to remove the battery from your philips toothbrush.Good luck
http://www.youtube.com/watch?v=UdWX155Kmq8
Feb 10, 2013 | Sonicare Phillips FlexCare RS930 / HX6932...
I need to deactivate the immobilizer on my car
There is a small switch that activates/deactivates the anti theft security feature on your car. It is located near the hood release. Flip the switch off. Try to start. This should reset. The security system is activated inadvertently by locking and unlocking the doors. If the correct series is not followed the system will be armed and silent, often resulting in a dead battery.. no fun! I went through the same problem for a month before I found the solution- jump starting the car will also bypass the system, however it's not the ideal long term solution :)
Jan 25, 2013 | 1996 Nissan Maxima
I have the 2010 Samsung Washer/Dryer 10kg and it is stuck on child lock. I can not get it off. Help?
Follow this instruction............. ACTIVATING/DEACTIVATING
If you want to activate/deactivate the Child Lock function, press the Soil Level and Signal buttons at the same time for 3 seconds.
How It Works: 1. "Child Lock" can be activated while your Washer is running. 2. Once you activate "Child Lock", all controls (except for the Power button) will be locked until you deactivate "Child Lock". 3. The Child Lock button will be lit while it is in effect. When buttons, other than the Power button, do not respond, please check if the "Child Lock" function is on.
Hope this helps u out!
Nov 17, 2010 | Samsung Washing Machines
Keypad on garage door will only close if i punch in my code it won't close by hitting the enter button the temp here is minus 40 does that effect the keypad chamberlain 3/4 belt drive
Try this procedure to reactivate this feature.
Opener can be closed by pressing only the ENTER button if the One Button Close feature has been activated. This feature has been activated at the factory. To activate or deactivate this feature press and hold buttons 1 and 9 for 10 seconds. The keypad will blink twice when the One Button Close is activated. The keypad will blink 4 times when One Button Close is deactivated.
Dec 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
2005 S40 wont start. Message says key error?
Do you have the remote, i.e. The deadlock system is activated and deactivated using the remote control key fob, which allows the driver to open the car as they approach. It seems you have activated the steering lock which is for preventing thieves to make a getaway. Use the remote to deactivate it and then try starting the car.......sodeep
P.S. The security system is a built-in feature of this model
Jun 12, 2009 | 2005 Volvo S40
Auto Lock Activation
Deactivating/activating autolock
There are 3 methods to enable/disable this feature. One through your
dealer, the second with a power door unlock/lock sequence and the third
with the keypad.
Before following the activation or deactivation procedures, make sure
that the anti-theft system is not armed, ignition is off, and all vehicle
doors, liftgate and liftgate window are closed.
Controls and features
Power door unlock/lock
procedure
You must complete steps 1-5 within
30 seconds or the procedure will
have to be repeated. If the
procedure needs to be repeated,
you must wait 30 seconds.
1. Turn the ignition key to ON.
2. Press the power door unlock control three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to ON. The horn will chirp.
6. Press the unlock control, then press the lock control. The horn will
chirp once if autolock was deactivated or twice (one short and one long
chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the
procedure is complete.
Keyless entry key pad procedure
1. Enter 5 digit entry code
2. Press and hold 7/8 control
3. Press and release 3/4 control
4. Release 7/8 control.
The user should receive a horn
chirp
to indicate the system has
been disabled or a chirp followed by
a honk to indicate the system has
been enabled.
Smart unlock
This feature prevents the driver’s door from locking while the key is in
the ignition. This feature will unlock only the driver’s door if the key is in
the ignition cylinder, the driver’s door is ajar and all doors are locked
using the interior trim switch. If these conditions are met, the entire
vehicle will lock and the driver’s door will unlock within 1 second.
127
May 15, 2009 | 2002 Ford Explorer
Can't figure out how to deactivate the alarm on Umbro U564B watch
Start with watch in normal clock mode. press and hold bottom right "lap reset" - alarm time appears. Keeping "lap reset" held, I can then toggle the alarm on and off using top right "start/stop".
Qiu: Circle segment lights up (only a black point in the middle, NO ALARM)
Circle segment with a black section on the above middle point, ALARM ON.
Mar 03, 2009 | Bulova Watch
Ice and water won't come out dispenser
here is link to your owners manual subzero.com
and here are instructions for using the lock feature..
LOCK For Models 685 and 695, the lock feature is used to prevent unintended ice and water dispensing. When the dispenser is locked, all key pads on the glasswell are deactivated to allow cleaning or to prevent small children from using the dispenser. To activate the lock feature, hold down the LIGHT key pad on the glasswell until the key pad lights flash once and the red LOCK icon is illuminated (approximately five seconds). The lights will remain in the state they were in before the lock feature was activated. To deactivate the lock feature, hold down the LIGHT key pad until the key pad lights flash once and the red LOCK icon is no longer illuminated (approximately five seconds). The lights will remain in the state they were in before the lock feature was deactivated.
Thanks Peyton
Mar 02, 2009 | Sub-Zero 695/S Side by Side Refrigerator
I need a copy of teh manual for my 2004 Ford Explorer manual.
Wear your safety belt, or simply unplug the harness located at the seatbelt receptacle.
Jan 13, 2009 | 2004 Ford Explorer
Health & Beauty Logo
22 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
