Question about LG WM-0532HW Front Load Washer
Water goes in very slow so my wash cycle is twice as long as the timer says. We switched the prewash/wash relay and that worked for awhile but now the prewash relay seems not to be working.
  • 343 Answers
It sounds like the inlet valve has failed..Not an uncommon problem. Replace the inlet valve and all should be well. Make sure that the filters on the inlet valve(s) are not blocked before replacing... Good luck....Nomess
Posted on May 15, 2010
Commercial maytag front loader starts high spin when money is put in
It's A You Drain Pump is bad. What a guy! He did not know that!? Replace the drain Pump and it will a Happy washer again!
Jan 19, 2014 | Maytag Washing Machines
Affinity washer wont work on a normal cycle only delicate
looks like the windings on motor are burnt out , motor has different winding for different cycles
Mar 20, 2012 | Frigidaire Affinity ATF7000E Front Load...
MIELE W412 PREWASH INDICATOR FLASHING
If your PreWash is flashing then you have a pressure problem. You can dry using a washer machine cleaner or doing a hot cycle with white vinegar. If that doesn't help the electronic would have to be changed.
Jan 08, 2012 | Miele W412 Front Load Washer
Whirlpool washer will occasionally be filling with water and pumping water out, problem will last until i turn timer knob to next action, after turning timer to "sweet spot" washing machine will...
These timers are normally sealed units (crimped and pressed sheet metal) and replaced as a unit.
If you could open one up, you'd find
that the contacts causing the intermittent problem are burnt from arcing. All washing machine timers
will eventually get this problem with enough use. As an electrician, you'll recognize that all switches
(washing machine timers are a series of switches oriented around a slow (timer) motor) are rated
for a given number of make/break cycles. Washing machine timer contacts are no different.
If you could actually "shine up" the offending pair of burnt contacts, another pair would soon
show the same symptoms, since all the contacts in your timer have endured the same number of
make/break cycles.
Feb 21, 2011 | Washing Machines
During the first cycle of quick 30 i.e.in wash cycle water flow is very slow & no sufficient water flows through the detergent drawer.After some time it throws out water & both prewash n crease...
Remove the inlet water hoses to the washer and check the screens going in the ports for buildup and verify good flow coming out of hoses into a pail
Jan 28, 2011 | Washing Machines
Kenmore machine won't do more than fill on SOAK setting;won't run
I'm unsure how the normal operation was restored. I attempted to correct it by setting the machine to SOAK+PREWASH overnight to assure that the SOAK timer had run out. Then My wife (who never uses SOAK or PREWASH options) made a clockwise trip around the TIMER control stopping at each of the "detents" (I did not witness this) one of the spin entry points worked to empty the washwater and the NORMAL wash cycle resumed normal function.
I'm not confident that my description above contains all the essential information needed to correct this problem and am disappointed that
I cannot find SUPPORTING LITERATURE that shows how to use these alternate cycles and combinations without another hang-up like these two that I have experienced. That which is supplied with the washer is pathetically inadequate and the Sears site has little else to offer. Document #8566913 was not delivered with the machine but I did find it somewhare on the INTERNET printed parts of it for additional help. *ALERT* #1: Just now I discovered that it does cover the Model series 110.2692* of which my machine is part ... and it ALONE warns of the 20 minute mandatory wait when two controls are set to obtain SOAK+PREWASH function.
*ALERT* #2: Last nite I discovered that the lid switch makes NO SOUND when the lid is lowered normally but can be made to click by pressing on the left rear of the lid. Feeling under the lid, I found no switchpad (?) on the operating arm as shown in diagrams found elsewhere.
FINAL QUESTIONS: 1) could failure to FULLY operate the lid switch allow partial function of this machine, e.g. to fill, agitate, rinse and spin normally but not to soak or prewash? 2) can anyone direct me to a place where I can obtain breakdown diagrams repair directions for this machine?
Dec 28, 2009 | Kenmore Washing Machines
P801front load washer
put on prewash cycle. note which tray water enters and that is the prewash tray.
put on wash cycle which has no prewash. note which tray water enters and that is main wash tray. remaining tray is rinse
Sep 06, 2008 | Samsung WF337AA Front Load Washer
Wf340 hotpoint washer
it will be to do with the pressure switch it may be faulty, but more often than not there is a blockage in the pressure chamber which is located at the bottom of the outer drum, check the chamber and the tube that goes up to the pressure switch to see if they are blocked if they are clear of obstruction then test the pressure switch,to do this unclip the pressure switch from the side of the machine but dont take the wires off once off pull the tube off that goes down to the pressure chamber once off blow in to the nossle on the pressure switch, you should hear it click and then when you release it should click again, if it doet click twice then that is your problem, hope that helps.
Feb 14, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
61 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
