Question about Sharp LC-32SH20U 32 in. LCD HDTV
I have a Sharp 32". Suddenly I have no picture. Sound is OK. If you get up very close you can see faint picture in background. Suggestions? Had repair amatures check it out and couldn't find problem. They tried power sources etc.
  • Sharp Master
  • 8,457 Answers
Ur T-con board is the cause,this board sit right in the middle botton of the LCD panel of the screen.This board is defective must be change.
Posted on May 15, 2010
Testimonial: "Great will give it a try! "
  • 2,336 Answers
Since you can see a fainted image on the screen, the backlight inverter board or a CCFL light behind the screen is defective. The easier fix to try is to replace the backlight inverter board first. Common failure on these LCDs.
Check this link to find the backlight inverter or T-con board.
Let me know if you require further assistance.
Posted on May 22, 2010
Hi, I have a Goodmans 32" TV LD3255HD. we have a
start by checking capacitors, if the have exploded replace them
if not then may be another board probem
Aug 25, 2013 | Televison & Video
Volume but no picture exept for a second when powers on
hi. your set requires a new inverter pcb,which powers the backlights.if you look very closely,maybe using a torch,you will see a faint picture.prices are around 35.00 on ebay for a used one.
regards,steve
Apr 07, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
No picture but sound
Turn on the set and get a strong light and bring it up to the screen. Do you see a faint image on the screen? If you do, then your backlight has failed. It may be one of the many lamps, or the inverter circuit or the power supply for the lamps.
The colored lines usually indicate a broken screen from an impact...unlikely unless someone hit the screen just before the picture went out.
Apr 22, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sound but no picture?
Take a strong light and place it very close to the screen when the set is on and tuned to a channel. Look for a faint picture. If you see it, the problem is with the backlight. May be power supply, inverter board or lamp(s). Not a repair job for the DIY'er.
Apr 14, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Image goes to black on Sharp flatscreen.
An LCD unit? Sounds like the backlight is failing. When it goes black next time, use a strong light next to the screen and look for a faint image on the screen....
If it is the backlight, its a service shop issue.
Mar 23, 2010 | Sharp 19 in. LCD HDTV
Sharp Aquos 32" LCD Screen goes black!
Main digital board fault. Check and replace it. Contact any service technician. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 05, 2017 | Sharp Aquos LC-26P70E 26 in. LCD...
No Sound
When your turn on your TV, do you hear a faint popping sound from your speakers? If so, the heat sink underneath the audio IC has melted and is shorting the audio circuit. Its a complicated job, suggest contacting your local sharp authorized service center.
Dec 21, 2007 | Sharp LC-32D4U 32 in. HD-Ready LCD...
Static 'white' sound
Good day.
Try to remove the cover of your unit and clean the tube with a dry cloth. try to look for the anode cap. the one tht is connected to your tube if there are holes in it. This causes the problem.
response is highly appreciated,
chris
Nov 21, 2007 | Sharp 32F-830 32" TV
Sony KV-32S36 32" suddenly stopped working, no picture or sound
Check soldered in fuse R607 in power supply circuit =
If open, replace it and bad converter xistors ( 2SC4834)
Next, replace shorted horizontal output transistor w/ first Quality.
Solder any / all bad connects,esp.horiz drive to base of horiz.
o / p xistor. Soldering is critical or it will blow up again......
Oct 27, 2007 | Sony KV-32S36 32" TV
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
Sharp LC-32SH20U 32 in. LCD HDTV Logo
428 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
