Question about Plantronics Bluetooth Headset 610 Wireless Headset
Plantronics bluetooth headset 610
I would like to pair this device to a new phone please can you tell me how to do so?
  • lakisha May 06, 2008
    i cant remember the code to connect bluetooth device to my new phone i turned on my bluetooth phone and when it found the device it asked for a code and i cant remember it
  • 30 Answers
Hi. First the code. Almost every headset uses the code 0000 (that's 4 zeros).
Now the pairing. You didn't say which phone you are using. I'll assume you know how to get into "Options" (if not, please let me know what model you are using and I'll give you more specific instructions.
To connect your headset, start on your phone.
Open "Options"
Open "Bluetooth"
Open menu within Bluetooth.
If not already on, click "Enable Bluetooth"
Open Bluetooth menu again.
Open "Options".
Turn "Discoverable" to "Yes"
Now to your headset.
Start with your headset turned off.
Press and hold down the silver call control button.
After 6-10 seconds, the light will flash blue, then it will flash red, then blue.
Release the buton when you see the red/blue.
Back to your phone.
Again open "Options"
"Bluetooth"
Open the Bluetooth menu.
Click on "Add Device".
Your phone will search for your headset.
If you are prompted for a Passkey, use 0000 (that's 4 zeros).
After a short time, your headset will appear on your phone.
It is now ready to use.
Make sure you go back into Bluetooth Options and change "Discoverable" back to "No".
A tip: If you will not be using your headset for a while, "Disable" Bluetooth to save battery life.
Posted on Dec 28, 2008
I dont know how to able the bluetooth of blackberry curve 8520??
Here are the pairing instructions for the Discovery 610 to your mobile device.
Bluetooth Pairing Instructions:
Look in your mobile phones manual for the section that describes how to set up a Bluetooth wireless connection.
1. Move through the menu selections on your phone until the phone display shows "Look for Devices," or equivalent, as a selection.
2. With your headset turned off, hold down the call control button until the headset status indicator briefly glows blue, then flashes red and blue. The headset is now in discovery mode and will stay that way for 30 seconds.
3. On your phone, highlight and select "Look for Devices", or equivalent, to activate the scan for the headset.
4. When the phone display shows the scan results, select "6xx Plantronics". The phone will continue to search for the headset.
5. When the phone display asks for a passkey, type "0000" and press Enter.
Your headset is now linked to your phone.
I hope this helps.
Good luck from Headsets Direct - 800-914-7996.
Aug 03, 2011 | Plantronics Bluetooth Headset 610 Wireless...
Plantronics 925 Discovery won't connect with Droid 2
  • Turn on Bluetooth within your phone - Consult phone instruction booklet
  • Put phone into pairing mode - Consult phone instruction booklet
  • Put headset into pairing mode - With headset off, press and hold Call Control Button
    until the headset begins to flash red and blue.
  • Select "Add new device" on your phone.
  • Select the Plantronics headset when prompted. Enter "0000" as passcode.
  • Your 925 headset will now have a continuous blue light blinking.
  • Choose "Yes" if your phones asks if you want to bond to the 925 headset.
  • Your phone is now paired with the Plantronics 925 headset and ready for use.
  • Please leave me a good rating!
    Sep 04, 2010 | Plantronics Discovery 925 Bluetooth...
    Unable to pair LG GM200 bluetooth 2.0 A2DP with Plantronics Pulsar 260. Error: "Request Failed" Please help in connecting this two devices
    Each pair of BT enabled phone and headset is a particular world. I don't have the Plantronics, but my LG phone pairs fine with my Lubix stereo headsets. I'll tell you how I managed to pair them: I put my headsets in pairing mode. Then, on my phone, I go to 'Connectivity > Bluetooth > Device list > Options > New'. If my bluetooth stack is off I'm prompted to turn it on. It starts to search for devices, and comes up with my BT headsets' name, I press 'Pair', it prompts me for the pairing code. I enter '0000' (the same code for your Plantronics' headsets, by the way) and Ok. Then, back to the Device list, I select the BT headsets and go to 'Options > Connect'. I'm good to go. After listening to music, I use to go again to 'Connectivity > Bluetooth > Device list', select the headsets and press 'Options > Disconnect'.
    Hope it works for you.
    Cheers! Carlos
    Apr 18, 2010 | LG GM200 Cell Phone
    I am trying to pair my Plantronics Explorer 330 headset to my new phone, an HTC Eris. the phone does not recognize the device. Do you have any ideas?
    When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
    1 Turn on the Bluetooth feature on your phone.
    2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
    3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
    4 If prompted for the PIN code or Passkey, enter 0000.
    Pairing is successful when the indicator on your earpiece flashes white.
    Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
    Good luck from Headsets Direct!
    Dec 21, 2009 | Plantronics Explorer 330 Headset
    Need to repair my plantronic 230 to new phone
    you should be able to pair it to at least three devices passcode is 0000
    May 01, 2009 | Plantronics Explorer 220 Bluetooth Headset...
    I have samsung sgh-a707 phone cannot pair plantronics 521
    I have samsung sgh-a707 phone cannot pair my new plantronics 521blue tooth.I search but get "no devices found".is it the phone or bluetooth?Help
    Dec 23, 2008 | Plantronics Hama Voyager 520 Bluetooth...
    Plantronics specific to ATT?
    You have paired your phone to another device. Your phone will not recognize the new device, as it is looking for the old one.
    To solve, look for your instructions on how to ADD your headset to an existing connected device.
    Or you can hold down the button on your headset until the colors turn red/blue, go to your phone connectivity, search for bluetooth device, once found, then connect and add your password, most likely 0000.
    Try that, in that exact sequence. Please rate me!
    ManOwar
    Jul 28, 2008 | Plantronics - Bluetooth Headset Plus Base...
    Cannot connect my cell phone to my Plantronics Discovery 610 Bluetooth Headset
    I got a plantronics discovery 610 but I'm unable to pair it with my phone motorola rizor
    Jun 01, 2008 | Plantronics - Bluetooth Headset Plus Base...
    you have to first put bluetooth headset in pairing mode by holding the phone hook button down until blue indicator on headset goes solid blue not flashing then set your phone to find bluetooth device by looking under your phones menu and look under bluetooth or connections make sure to turn on bluetooth function and choose find or add device phone will detect bluetooth device and will display the type of device on your phones display tell it to bond or connect once you select yes thats it the bluetooth headset will start to flash and its ready to go.
    Jan 14, 2008 | Plantronics 510 Voyager Headset - PLN-510...
    Plantronics Bluetooth Headset 610 Wireless Headset Logo
    289 people viewed this question
    Top Plantronics Radio Communications Experts
    LeAnna Mathews
    LeAnna Mathews
    Level 1 Expert
    shaun taylor
    Michael Vincent Cruz
    Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
