Question about Mitsubishi WS-65869 65" Rear Projection Television
65869 blinking, Where is this board with the capacitors located ?
  • impushstart May 15, 2010
    Im trying to find out where the board is ?? Seems like the links to get to the board are too old and missing, I have a pic of the board, I just need to know where it is ? Left side/Right side ?? Thanks in advance
  • Mitsubishi Master
  • 8,457 Answers
Try website like Tvrepairworld.com to buy the kit they'll tell u where it exactly located on the DM power supply board.
Posted on May 15, 2010
Mitsubishi 65" WS-65869 Blinking Green Light 3-2 pattern,
two ideas:
Make sure you tested the pico fuses inside the unit with the caps==two or three of them.
Also from front of set behind speaker grill unplug both plugs that go up to front keyboard--set will still work with remote===if set functions now then the reset micro switch is bad/damaged.
Mar 12, 2012 | Mitsubishi WS-65869 65" Rear Projection...
My 65" mitsubishi rear projection TV stopped
Try website like Tvrepairworld.com they sell these capacitors kits put toghether for most of the DLP tvs DM power supply board repair.Talk with them they should help u further.
Jan 14, 2011 | Mitsubishi WS-65869 65" Rear Projection...
Blinking green light on my mitsubishi tv....model ws-65869
Replace the Capacitors on the DM board. You can get the WS55859 DM repair kit which covers your model from www.tvrepairworld.com which has the caps and the CD with repair instructions
Jul 14, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Have the blinking light of death on my Mitsubishi WS 65869
i would try unplugging the front control panel, it can also lock up the dm board.. i have a bulletin on it.. open up the panel behind the speaker grille and unplug dz connector.. then unplug the tv for 2 minutes, plug it back in and wait 2 minutes, and then try it with the remote. if it works, you'lll just have to go without front buttons.. it could be a dm board but thats rare. maybe he put in the wrong capacitors, he should have used 680uf @ 16v to replace the 1000uf caps
Jun 07, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Timer light keeps blinking tv wont turn on already pushed system reset
Capacitors inside of your TV are gone from bad to dead. TV is trying to reboot after power disconnection and can not complete sequence. Sometimes even other components may be affected. You have to take rear cover off and locate DMD module on the left hand side if you look from the back of TV. It's vertically mounted board with aluminum cover. It have to be taken out and all electrolytic capacitors that have bulged (instead of flat) top should be replaced. This repair requires soldering skills. And even after this procedure it's 50/50 chances that TV will be resurrected.
Mar 10, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Mts ws 65869
Replace the dm power board . Its inside the metal box on the left (looking at the back with the back removed). p/n 935C986002
Or if you can solder then replace the 7 electrolytic capacitors on the DM power board. value 1000uf16v
Nov 22, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Blinking green light stays on and TV won't turn on.
Check for open pico fuse in power supply caused by bad convergence I.C.Get pro help-you have a good set to save.Remember--practice visual acuity technique!And,above all else,do no harm!!
Aug 26, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
97 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
