Question about Kenmore 73952 Gas Dryer
Heating problem my dryer doesn't heat up as much and by the end of the load you smell gas coming from the vent
  • Kenmore Master
  • 494 Answers
If you are smelling gas in the house, stop using the dryer, close the shutoff valve on the gas line behind the dryer & call your local gas co to repair it. It may not be a leak, but a problem with the burner lighting properly, but better safe than sorry.
Posted on May 15, 2010
Whirlpool dryer will not heat
Gas or electric? If gas check for flame. If electric check the heater element. Go online and get a replacement. Doesn't really matter which watts you get. Should always run dryer on low setting and let the air do the work not the heat. Check the air vent and clean as necessary. You can save energy by doing loads and then adding wet clothes to dry clothes. Break up the wash load into managable sizes. Let me know.S
Apr 11, 2012 | Dryers
The drum turns. It heats up. But only small loads of cotton get dry! We have changed the vent tube. Vacuumed the vent the lint catcher area and around the drum to remove lint and hair. Still not...
A very typical problem with GAS dryers is the soloniod coils that open the gas valve . When the coils are cool they operate just fine,but once the dryer gets warm from running the coils dont open the gas valve wwhen they are warm. If that is what your experiencing,the dryer heats when its cool but doesn't heat when it's been running for a while,the coils on the gas valve will need to be replaced.
GENE
Aug 16, 2011 | Roper RGX4634KQ Gas Dryer
Maytag mdg6700aww dryer clicks to start the igniter. Sometimes the burner ignites, other it doesn't and I can smell raw natural gas from the vent. Not drying. Help
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | Maytag Neptune MDG6700A Gas Dryer
My gas dryer doesn't heat very well, if at all. Do I need to replace parts or are there ways do check and clean parts.
First i would clean the dryer vent. If the vent is clogged then the dryer cannot circulated the air inside the dryer. This will cause long dry times. If the dryer heats at first then doesnt heat anymore after about 10 min you probably need new coils
Jul 15, 2011 | Amana ALG443RAW Gas Dryer
Dryer starts to dry comes up to temp then goes out and will not reheat but you can see ignitor come on but gas will not come on then some times you can smell gas out the vent and its cool what gives
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 24, 2010 | Whirlpool Dryers
Hotpoint nvl333gyoww gas dryer's timer stopped working and ran for an extended length of time (about a day). After looking over the dryer, i noticed that during the no heat cycle the timer would work. So...
the timer : if you use time dry the timer should always move and complete the cycle. if you use auto dry the timer uses a sensor to tell the timer to move. If your not getting any heat your sensor might not tell the timer to move.
So lets start with the no heat problem. First make sure your Vent is clear or just disconnect the vent and put a pair of womans stocking over the end to keep the dust down, This will ensure you do not have a blocked vent. ((( If you have a blocked vent on a gas dryer the safty sensor will shut off the gas valve and you will only get a little bit of heat))) Now try the dryer for small load, ((( if this solved your problem then you have a cloged vent )))
If this did not solve your problem then the coils on your gas valve in the dryer are probably bad.
Sep 02, 2010 | Hotpoint NVL333GY Gas Dryer
The dryer tumbles however there is no heat. I have checked the venting, the gas line and the internal vent...also the settings. When I remove the rear venting hose, I smell gas. Led to believe that the...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Jun 17, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Gas dryer smells like gas heats up a little bit
The most common problem with gas dryers is the ignitor going bad....
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Apr 05, 2010 | Frigidaire FGQ332ES Gas Dryer
1. ) not heating up / cleaned heating sensors mounted on the lint vent holder with ALCOHOL last week ....we had an ink pen in the load ...since then /subsequentially its not heating up...? could that...
If you use a flashlight and look down the filter housing you may be able to see the scock and remove it with a coat hanger.
Rotate the drum both ways with you hand while looking if you cant see it.
Dont worry about the sensors they are ok.
No heat?
May be several things...
Plugged vent
Bad ignitor
Bad gas valve coils
Bad main pcb.
Jan 18, 2010 | LG DLG3788W Gas Dryer
Gas smell from dryer
your igniter needs to be replaced.
Jan 26, 2007 | Kenmore 74842 Gas Dryer
Kenmore 73952 Gas Dryer Logo
87 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
