Question about Yard Machines 11A08MB006 22Inch 139cc MTD OHV Gas Powered Side Discharge
Mower starts then cuts off after a few seconds
Mower starts but cuts off checked and cleaned air filter.
KMusselmann
  • 247 Answers
SOURCE: Honda Mower i2y 16'' 4.5 BHP
Do you have fresh gas in it? If not drain it and put fresh in it. Also the carburator could have gotten gummed up while in storage. Try some carburator cleaner from your local auto parts store
Hope this helps
Kurt
Please rate the answer
Posted on Mar 18, 2009
hunter19_46m
  • 7482 Answers
SOURCE: My lawn push mower will
Check to make sure you are getting fire/spark at the plug, if so then do the following:
Check/Clean/Replace your fuel filter if you have one, normally they will be located in the fuel tank.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Apr 16, 2011
  • 97 Answers
SOURCE: Engine runs 2-3 seconds then stops
Drain float bowel
check for water .
Posted on Mar 19, 2009
  • 23 Answers
SOURCE: i already cleaned out the carb. the mower will
still sounds like not getting fuel ,did you soak the carb in something overnite,this is what I do ,sometimes just a spray out wont help.how old is mower?
Posted on Apr 23, 2010
01fordeb
  • 1033 Answers
SOURCE: Mower starts after priming, then quits. new
Evan though you cleaned the bowl, the float isn't "floating" correct in the bowl to raise the needle for gas to flow into the carb. The float and needle can be replaced. When you prime an engine the gas shoots straight to the carb. As when the engine is running the floating goes up and down to raise the needle for gas to flow.
Posted on Jul 07, 2010
My 1 yr. old mower will not remain running, cuts off after a few seconds and is hard to start
the air filter is connected to the carb. when you take it off you should see the carb.
May 11, 2014 | Measuring Tools & Sensors
Zero turn mower is sputtering and dies
Check everything is clean. Check the air filter is clean, check that the engine cooling fan, cutting blades and cutting deck are free of grass. Check all the drive belt pulleys to ensure accumulated grass is not jamming anything. Check the fuel filler cap is clean and the breather hole works.
Jun 27, 2013 | Husqvarna Zero Turn Mower Z5426
Toro Mower wont stay running
The main reason why a mower starts up and then cuts off after a short period of time is because of poor air flow to the carburetor and is most likely a blockage somewhere.
First you should try this. Remove gas cap and filter then place a really thick rag over the top of the carb where the filter was and either blow into the gas tank or wrap a rag around a tapered air chuck and then place the air chuck in the gas tank (with rag fitting snug around chuck) blast it a few times and listen for bubbling, if it's bubbles then you have removed the blockage..
Take the carb off of the mower and clean the carb / jets with a thin piece of wire.
Be sure to clean the gas tank completely and the fuel line.
Check the oil level, some mowers have a low-level oil shut off.
Change the plug out with one thst is reccomended for your engine.
I wouldn't reccomend running the mower without the filter, that causes dirt and grass debri to enter the carb, fuel line and tank.
This should fix the problem, if it don't you should find a lawn mower repair service.
I hope this helps.
May 11, 2013 | Garden
My lawn mower will start then it will die after a few seconds, what could be the problem
If the mower was tipped it is quite possible oil from the engine has traveled up the breather and soaked the air filter in oil, this would richen the engine up and stop it running, remove the air filter and check for oil saturation.
Jul 18, 2012 | Garden
I have a troybilt mower with a honda 160 engine (#gcv160an5a) that will not start. I have cleaned the carb, replaced the spark plug, cleaned the air filter, new gas and oil. The spark plug is dry after...
You may have to replace the carb.But before you do.Check the the fuel line.There is a small screen in the carb,it may be clogged.Inside the tank is a small cylindrical filter,make sure it is good.Break the fuel line at the in line filter,to make sure gas is getting to there,if it is the problem is in the carb.
May 20, 2011 | Honda Garden
Running problems with Mountfield HP454 petrol lawnmower
First thing to check is the air filter. It may be plugged.
May 28, 2010 | Mtd 22" Yard Machine Push Mower
Honda 160cc mower engine starts and dies.
Your carbeurator is crudded up. Get a can of aerosol carbeurator cleaner at any auto parts store. Remove the air filter and spray two squirts of cleaner into the air intake. Start the engine and keep it running by squirting more carb. cleaner into the air intake. WIth a little patience you will clean your carb. and solve your problem.
Sep 14, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Mower won't keep running after 10-15 seconds.
check the air filter & also spray some carb.clean in the carb see if that helps
Jun 06, 2009 | Toro Lawn Mower With Toro Power Tools
Yard Machines 11A08MB006 22Inch 139cc MTD OHV Gas Powered Side Discharge Logo
238 people viewed this question
Top Yard Machines Garden Experts
Phil Walker
Phil Walker
Dean Gruber
Tim Whalen
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
