Question about Pentair Mastertemp Heater
Heater won't turn on.
There is power to the unit, but heater won't turn on. Is there a fuse to check and if so where is it located.
thanks John
1993 buick park avenue heater won,t work.checked all fuses an relays
i beleive you did more than that.? you,ll probably find all have a common earth , chech and remove it , clean with a wire brush and replace, also chance the fuse you removed and replacer reguardless of it,s appearence , ensure its put back in the correct location,peter.
Sep 03, 2012 | 1993 Buick Park Avenue
Re: Bosch Highflow Water Heater - model YS2433R. Hot water runs for 1-2 mintues and then turns cold. Burners turn off. Display flashes "14" (error?). Started when winter set in. Ph. 64 4 5666948
hi there,
have you gone checking the unit... first check the thermostat switch, and also the fan blower fuse/resistor.. It could be one of those is not functioning well now...
Let me know...
Jul 05, 2008 | Heating & Cooling
CHECK AC AND HEATER CONTROL FUSE. IF FUSE OKAY CHECK BLOWER SEE IF POWER GOING TO BLOWER MOTOR IF YES BLOWER MOTOR MORE LIKELY FAULTY.IF NO POWER GOING TO BLOWER MOTOR CHECK BLOWER MOTOR FUSE ANDRELAY.
Oct 28, 2011 | 2000 Kia Spectra
Hi.. please help me.. my minolta dialta 183 is not working.. there's a code CO5 in the screen.. please help me to fix it.. thanks
C0500: Warm-up failure
Step 1
Check:
Fusing Heater Lamp (H1) turns
ON.
Step 2
Check:
Fusing Heater Lamp (H1) is open-circuited.
<Check Procedure>
Check the resistance across both
ends of the Fusing Heater Lamp
(H1).
The Fusing Heater Lamp is open-circuited
if the resistance is infinity.
Result: YES
Action: Change Fusing Heater Lamp (H1).
Step 3
Check: Thermoswitch 1 (TS1) is operational.
<Check Procedure>
ends of the Thermoswitch 1 (TS1).
The Thermoswitch 1 is open-circuited
Result: NO
Action: Change Thermoswitch 1 (TS1).
Step 4
Check: Fusing Unit Interlock Switch (S2) is
operational.
<Check Procedure>
Check continuity across terminals
when the Fusing Unit Interlock
Switch (S2) is turned ON.
• Across S2-1A and S2-1B
• Across S2-2A and S2-2B
Result: NO
Action: Change Fusing Unit Interlock
Switch (S2).
Result : YES
Action: Change DC Power Supply (PU1).
Step 5
Check: Thermistor (TH1) is open-circuited.
<Check Procedure>
Check the resistance across CN15-2
and CN15-3 on the Fusing Unit side
with CN15 disconnected.
The Thermistor is open-circuited if
Result: YES
Action: Change Thermistor (TH1).
Step 6
Check: The following voltages are supplied
from the Master Board (copier: PWBA).
<Check Procedure>
Check voltage across a Master Board
(copier: PWB-A) pin and GND when
the Power Switch is turned ON.
• Voltage across PJ10A-7 and GND
DC24 V when Fusing Heater Lamp
(H1) is OFF
DC0 V when Fusing Heater Lamp
(H1) is ON
• Voltage across PJ10A-10 and
GND
(H1) is OFF
(H1) is ON
Result: NO
Action: Change Master Board (copier:
PWB-A).
Oct 05, 2011 | Konica Minolta DiALTA Di200 Copier
DEPENDABLE 92 WON'T START . ALL SWITCHES CHECK OUT. CAN'T DIAGNOSE CIRCUIT BOARD
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace take off the lower blower door and locate the circuit board turn the power off to the furnace. In the circuit board there should ba a small car like fuse usually 3 or 5 amps check the fuse it is probably blown replace the fuse with the same amperage fuse and then turn the power back on on the furnace and check the operation of the furnace.
Oct 02, 2011 | Goodman GMS90703BXA Heater
Purex Triton MiniMax Plus 400 power light is not turning on nor is unit. Checked for power going to unit and no fuses appear to be blown. Thoughts on what might be the issue? Thanks, Dan
if you have incoming power, you may have a bad transformer. those systems run on 24-28v. you can check from yellow wire to yellow wire coming off the transformer to see if you have anything coming out. must check wires coming out of the transformer to each other, it won't register if you check each one individually to ground. hope this helps...
Aug 11, 2011 | Pentair Minimax NT Heater
Just installed ignitor PP200 & Gma 10-R fuse, unit ran for approx 4 min & blew the fuse & burnt the ignitor up . Our parts available thru your location. Is their a troubleshooting guide...
It sounds as if you have a defective control board.
Find your exact model (example= B100T). Then, go to this page and find which board is in your particular model. Don't guess. http://www.reddyparts.com/master_heater_reference.htm
Then, go to the shopping cart for pricing & shipping cost.
Apr 20, 2011 | Master Heaters B155DST
Radio is a cobra 142 gtl s/b turned on switch and no power, check fuse is ok.
Hi, my name is John. Welcome to FixYa. Make sure that you are getting power to your unit by running the wire to the battery, hot (+) and ground (-), let me know if you still have no power and I will post solution here. Thanks for choosing FixYa....John
Nov 15, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Where is the heater and turn signal relay located 1992 caravan
These are seperate fuses and seperate turn signal falsher which evenually go into the same wiring. See my answer to your previous question. Good luck and hope it helps.
Jan 19, 2009 | 1992 Dodge Caravan
Pentair Mastertemp Heater Logo
35 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
