Question about Janome 8080 Computerized Sewing Machine
The needle and thread get stuck at the bobbin and the lo light come on my 8077
    Genius:
  • 1,116 Answers
Turn the power off and replace the needle with a new one, making sure the install is as described in the manual for your machine - on most newer models, this is with the flat side of the needle shank facing the back of the machine.
Before turning the power back on, raise the needle to it's highest position. Remove the face plate, bobbin and bobbin case. Clean the area in and around the shuttle from lint and/or threads that may be tangled there.
Posted on May 15, 2010
Testimonial: "thanks. Once when I turned the machine off for awhile and then turned it back on it worked. "
Model 4075 white sewing machine problem with thread from bobbin
1. Replace thread with good thread. (Check by holding to light to see if there is fuzz).
2. Adjust the bobbin tension. The tension on top is set to three and the bobbin tension should be equal to this amount.
3. Replace needle.
4. Check the top tension with tension foot down to see if the thread can move or does it get stuck? If it gets stuck the tension control may need adjusted or cleaned.
5. Pull the bobbin thread above the throat plate and pull on the thread. It must have some tension but not get stuck.
TENSION TENSION TENSION IS THE PROBLEM!
Sep 30, 2016 | White Sewing Sewing Machines
How to fix time hook on special adition XL5700 the needle not picking up the bobbin thread
CHECK THESE FIRST::
NEW NEEDLE.
MAKE SURE NEEDLE IS INSERTED THE RIGHT DIRECTION. LOOK AT YOUR INSTRUCTION BOOK.
MAKE SURE INSERTED IS TOTALLY INSERTED.
CHECK TO SEE IF THE BOBBIN THREAD IS STUCK. ALSO, ENOUGH LENGTH OF BOBBIN LENGTH EXTENDED TO ALLOW THE NEEDLE TO PULL IT UPWARDS.
MAKE SURE THE BOBBIN THREAD IS INSERTED THE RIGHT DIRECTION AND SET WITH CORRECT TENSION.
CHECK TOP NEEDLE TENSION TO INSURE THERE IS TENSION ENOUGH TO PULL THE BOBBIN THREAD ABOVE THE THROAT.
IF THESE DON'T WORK YOU MAY NEED TO GO TO YOUR LOCAL REPLAIRMAN.
Jun 18, 2016 | Sewing Machines
Bobbin thread is jammin up after about 3 rotations of wheel on my janome 8077 - is this a timing problem?
try changing the needle
make sure the thread has not come off the thread take up lever
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin is not over filled
make sure the bobbin is not damaged
it's very possible that the machine could be slightly out of time
Sep 01, 2012 | Janome Sewing Machines
Thread breaking
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Aug 13, 2012 | Janome Sewing Machines
The needle is stuck in the Shark 612C model sewing machine, any solutions?
Try http://www.fixsewingmachine. com I also suggest that you clean bobbin case. Now, when needle is "stuck", this requires patience and care in "jiggling" the hand wheel to and fro until needle point begins to clear the jammed area. Carefully snip one thread that moves up under needle and jiggle hand wheel by carefully turning hand wheel toward you to see if you can move the take-up lever all the way up to the UP position. Look at bobbin case area and remove bobbin. Cut bobbin thread and remove bobbin case. Sweep gently with brush underneath case and carefully, gently sweep over the feed dogs, poking very ends of brush bristles into "teeth" area to remove lint, fuzz ball/s, and any loose thread/s. Raise presser foot, remove (possibly bent) needle. Insert new needle of appropriate size for fabric weight. Make sure needle pushed all the way up into needle bar groove, at side to back. Keep presser foot RAISED while rethreading. This allows thread to locate tension discs, and HOLD THREAD TAUT. Replace bobbin, making sure thread is EVENLY distributed on it. Imablanced bobbins cause jams, and bobbins with burrs and scratches can real havoc as well as the hook part of the shuttle where the bobbin fits. Smooth such areas with emery cloth carefully, ever so gently. Hope my suggestions are a solution for you. Jimmy
Apr 06, 2012 | Euro-Pro Shark 60 - 384
When i start to sew on my Janome sewing machine model Sewist 525S it does a couple of stitches on any stitch type then bangs then sews then bangs then stops. I look to see the problem and the bobbin and...
There has to be a problem in your threading or your needle. You may have the needle inserted backwards, flat side has to face rear or the needle is bent. Totally unthread your machine and make sure that there are no tangles and that it feeding the right way. Watch how they show your for threading and winding the bobbin, plus threading the bobbin. Good luck, but I truly think it is in your threading.
Sep 25, 2010 | Brother LS-1217 Mechanical Sewing Machine
I have a Janome 6260. My machine sewed great, but this time when I went to use it the knob on the side of the machine that makes the needle go up and down suddenly got really hard to turn and then when...
I've had the Lo come on my screen of my sewing machine also, but normally when I turned it off it corrected the jam up.
Lo- A button is pressed when the machine halts due to a overload
wait 15 seconds to recover
if thread jamming causes the overload, remove the tangled thread
check the bobbin area for lint & loose threads
also check to see if the bobbin is warped
check you needle to see if it's bent-roll on a flat surface to see if it rolls correctly
if it's blunt it makes a popping sound when going thru fabric
let me know if these suggestions help
Sep 23, 2010 | Janome 6260QC Computerized Sewing Machine
Thread getting caught in bobbin area
If you are seeing the needle thread in loops and birdnests then its the needle thread you need to check. The main reason is it is not threaded through the takeup spring(the one that moves) This action is critical as it is how the thread is pulled up tight. Also make sure the needle thread is between the discs and that it has sufficient tension that you do not see it on the bottom of the material. Try this: Use two different color threads for needle and bobbin. If you see the needle color on the bottom then the needle thread is not tight enough (or in 5% of the cases the bobbin is too tight or hung up). Let me know how it does. Jay
May 28, 2009 | Sewing Machines
Janome 8080 Computerized Sewing Machine Logo
260 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
