When you use the netbook with an external monitor the computer shuts off when you close the netbook display. How can you use the netbook as a desktop and be able to close the book?
  • geoff_cook_2 May 15, 2010
    I have accepted the solution. I still can't close the netbook but shutting down its display is acceptable.
    Thanks
  • 4,281 Answers
For that make sure that display settings resolution is set to 1024*768 and installed graphic driver working fine.
then connect your external monitor to laptop and press Fn key +F2 or FN+F5 to toggle the screen so you can use external monitor with it.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 15, 2010
    Krishma....the external monitor works fine with the netbook. The problem is that when I close the netbook it turns off. I would like to use it closed with and external monitor as you can do with other laptops?
    Thanks...Geoff
  • If you want to turn off the lcd screen of laptop then want to use external monitor then press FN+F2 or Fn+F5 so you can see display on external monitor.
How do i fix white screen on my kav60 acer aspire one
The KAV60 is also the AOD250.
Netbook OFF, monitor OFF, connect an external monitor to the netbook's VGA port.
[You can use a VGA monitor. Looks like a small TV.
This is an example of a VGA port,
VGA connector Wikipedia the free encyclopedia
Note* VGA port doesn't have to be blue in color ]
Turn the monitor on. Turn the netbook on.
If there is no image shown on the external VGA monitor, press and hold down on the Fn key, and at the same time tap once on the Display Toggle-Over key.
(The F5 key is the Display Toggle-Over key)
No image on external VGA monitor?
Hold the Fn key down once more, and tap again on the F5 key.
Still no?
Problem is internal in netbook. Probably graphics chipset soldered to the motherboard.
Replace motherboard.
Image shows on external monitor?
Problem is with Video Cable or laptop LCD screen.
MOST of the time it's the Video Cable.
The Video Cable connects to the motherboard, in an area under the Keyboard. It then routes up under the left Hinge, and into the Display Panel.
Inside the Display Panel it then connects to the LCD screen.
With frequent opening and closing of the netbook, the Video Cable can be pulled on. This can cause damage to the Video Cable.
(Stretched/broken wires inside the sheath of the cable)
And/or it can cause the connection at the motherboard to be loose, and/or at the LCD screen.
Example of Acer Aspire One video cable,
For ACER Aspire One D250 LCD Screen Cable DC02000SB10 KAV60 New
You can remove the Video Cable, and check it's continuity with a multimeter, or if the cost is reasonable to you simply replace it.
8 to 10 dollar video cable is not the problem? Then problem is the LCD screen itself.
My money is on a loose video cable connection, or damaged video cable.
For additional questions or to have me clarify/simplify anything in my solution, please post in a Comment.
Regards,
joecoolvette
Jan 15, 2015 | Acer Computers & Internet
How to switch the meso lap top to external monitor
If you have an external monitor with VGA interface and you have a VGA monitor cable then should simply plug it into the netbook VGA socket and reboot. The monitor should then start up and can be used as a screen. If you are using Windows then you can right click mouse on screen to select display properties and configure the resolution and profile of the setup.
Sep 02, 2014 | Sylvania G Netbook Meso Netbook
Very dim LED screen on Acer One D255E netbook
The laptop video circuits are good and the fault lies with the display or the power feeding the display.
Go for the display since they do go bad.
Aug 25, 2017 | Computers & Internet
Where can i find a display screen for my acer liqiud mini e310? all what i find when i search is touch screens and i want the display one!
I'm assuming you want to hook up an external monitor? If that is the case than any with a VGA hook up, which is most monitors will work. You simply plug in the VGA cable from the netbooks vga port to the port on the monitor. You will need to from the FN key + one of the F# keys that says LCD or has a monitor icon. You can toggle to netbook only, netbook + external mirrored, external only. You can also configure it for extended display and use both displays at the same time.
Monitor Link
Jan 26, 2013 | Acer Computers & Internet
I have tried to fix my mini notebook but my screen is just blank,i cant even see the start menu..what can i do?
Hi, if you cannot see a display on your monitor, there are a few things you can do. The easiest and first thing you should do, is plug an external monitor into the VGA port on your netbook. That way, you will know if your computer is still working. Also, make sure the power lights are on when you turn the computer on. Next, you can try this. Find the function button that corresponds with one of the F# keys i.e. F4 or F8 that controls the LCD display. It will either say CRT/LCD or will have a picture of two monitors on it, something like that. Then, press the Function key (Fn) and that corresponding key at the same time and see if the display comes back. Press it once and wait a minute, if nothing happens press it again and do the same thing. Do it a few times. You may also have to do that when you plug in your external monitor as well to get a display on it. What that does is tell the computer to display the image on an external monitor.
Jun 16, 2011 | HP Mini 1000 Netbook
Have a ASUS VW222U LCD monitor and works fine with the DVI input using a Macbook. Now I want to connect the VGA port to a ACER netbook and all I got is 'No signal'. The on screen menu don't work if no...
That is because the Netbook has its own screen. You have to go into Settings for the Display Adapter and choose Multiple Displays, click Detect and add the External Monitor.
Jan 29, 2018 | ASUS VW222U Monitor
I am using an acer aspire one netbook on xp. i can not make the external monitor that i attach to the serial port to work. is just shows, "no signal" When i press fn f5, it still won't work. please help.
Hi, Could you please post the Model Number of the computer.Are you trying to connect using a VGA cable or a HDMI ?Fn+F5 key combinations are used to toggle the display between the laptop and the External Monitor.Try these steps
1.Remove all cables,Turn OFF computer and Monitor
2.Start the computer and wait till it boots to windows nrmally.
3.Start the Monitor,then plug the cables between laptop and Monitor.
4.Check with Fn+F5 to toggle display
Jun 30, 2010 | Acer Aspire One Netbook 8.9" Notebook
The computer boots but there's no display
check the display properties for dual monitor settings in
display properties>settings> check all options
I think it is set for external display u change to dual display. then both displays can work. or there is some display symbol of some function key. check that and press
Jun 17, 2010 | Acer Aspire One Netbook 8.9" Notebook
I have connected my old dell laptop to this TV with VGA cable and audio cable and it worked with no problem. Have new Acer Aspire one netbook- connected to computer with same cables - can see windows...
First, you want to make sure the laptop's internal/external display mode is set properly. On Acer netbooks, this is usually changed by holding the "Fn" key, and pressing "F5". Either the TV or the computer display should flicker when you do this. There are 3 modes:
1 Computer only
2 TV Only
3 Computer and TV
If changing between thos emodes doens't work, continue on.
I am going to assume you are running Windows XP. Please correct me if I am wrong.
To display your desktop on an external monitor, you'll need to change/check some settings. Your netbook is most likely attempting to set it's display settings automatically, but it is expecting a computer display, not a television, so the resolutions and refresh rates are conflicting. That's why it will only display on one and not the other. Before Windows loads, the netbook is using a very low resolution,so it displays on the TV. Once Windows loads, it switches to some non-standard resolution that your TV cannot display and defaults back to your netbook screen.
The solution is to find a resolution that your television will display:
1.Right-click the desktop, and then click Properties.
2.In the DisplayProperties dialog box, click the Settings tab.
3.Click the Display list and select your external monitor (..the TV. It will most likely be display #2).
4.Select the Extend my Windows desktop onto this monitor option.
5.Select 640x480 in the "Screen Reolution" section for Display #2.
6.Click Apply or OK.
Note: If you see the background change on your television, mmove your mous there to make sure it's working. If it DOES work, go back to the "Screen resolution" section for Display #2 and find the highest resolution your television will display
Sep 19, 2009 | Westinghouse SK-32H540S 32 in. LCD TV
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
