Question about Samsung Cell Phones
Problem paring a Samsung Convoy Bluetooth-capable phone
I paired a Samsung Convoy Bluetooth-capable phone with the UConnect system in my Dodge Avenger. The pairing worked. However, I have to manually activate the phone to seek the UConnect system each time I get in the car. Is there a way to have this automatically connect as my previous Samsung phone did?
SOURCE: Pair Bluetooth Stereo
put the music player on and press down on the jogwheel, select 'Play Via' and change it to Bluetooth stereo headset. It'll prompt you to open the swivel and take you to the bluetooth devices screen where you select the correct device, it'll then prompt you to close the swivel and will start playing through your headphones :-) Is that what you mean?... It's a bit of a pain really :-(
Posted on Aug 15, 2007
  • 5 Answers
SOURCE: How do I pair my Jabra Bluetooth -48D
well what you have to do is to go to the bluetooth menu turn  it on and select add new device now on you jabra headset it has an answer button wich you can press untill the blue light stays on that when the env can find and paire the device
Posted on Nov 01, 2007
SOURCE: samsung sch-s870 not pairing with uconnect on my cell
same phone same problem, possibly software update might help
Posted on Feb 25, 2008
herodog909
  • 98 Answers
SOURCE: Samsung SGH-t8089 : With bluetooth enabled and
Make sure your phone is on the "Discoverable" setting. Fish around your settings.
Posted on Jun 09, 2009
SOURCE: Phone disconnects from Porsche PCM bluetooth
disable the power saver option in your bluetooth, it wont get dissconnected, and add your car kit to my device menu
Posted on Jan 05, 2010
Why won't uconnect work in 2013 chrysler200
There are a few things to note. The pairing has to occur between the Uconnect device in the Chrysler 200 and the Samsung S3 using bluetooth. I noticed there are 4 possible Uconnect systems available. Depending on which one you have you can check the recommended cell phone to go with it. Samsung S4 is defnitely compatible to all of the of them and SIII also with some. But that does not mean SIII will not work with others. It just means it may not have been tested.
Go to this link and select the vehicle model and year and then follow the instructions to get to the correct pairing instruction. If SIII is not listed I would still check S4. Should not be much different.
Chrysler Uconnect
Aug 07, 2014 | Chrysler Cars & Trucks
I have bluetooth device (wireless headset) and i want to pair it with my Samsung B5722... Can you give me detail instructions? Is my Samsung B5722, capable of pairing to bluetooth wireless headset?
yes, your samsung is capable of pairing to bluetooth wireless headset. all you have to to is go to music player, go to options and select play with bluetooth devices or search for visible bluetooth devices.
May 11, 2011 | Cell Phones
I have a Samsung SGH-c417 cellphone and a 2011 Jeep Grand Cherokee Laredo with Uconnect. What is the pin number to pair the bluetooth with the UConnect?
If your UConnect system is Mopar's, the passkey is hardcoded to '0000' (four zeros). Nevertheless, if it is factory mounted (i.e. the one which comes mounted in the internal mirror), you will be prompted to choose any four-digit number you can think of (e.g. the same '0000'), provided that you enter that same number on your phone when pairing them with each other.
For further instructions, please, take a look at this page, select your car's year and model, click on the 'OWNER SUPPORT' tab and select the UConnect system present in your car.
Hope you are able to sort your problems out soon.
Regards, Carlos
Nov 07, 2010 | Samsung Cell Phones
Need set-up Information for Blue Tooth phone in Chrysler Pacifia 2005
I found the link below containing a download of the .pdf file and also pasted the phone pairing portion below it. These instructions are exactly the same as when pairing to my system in my '08 Caliber,so they're probably universal. Keep in mind, though, that the system just may not be fully compatible with your phone. EVERYTHING that Chrysler makes is EXTREMELY finicky-and you may be doing everything right! Before you begin, set your phone into its pairing or "find me" mode, then press the UConnect button. I hope this helps! Good luck.
http://dcxtraining1.com/dcxtraining1/docs/ExperienceFreedom_UConnect.pdf
Linking to UConnect – Required for First-time Use of Each Mobile Phone
To complete the pairing process, the mobile-phone owner’s manual will need to be referenced. One of the following vehicle-specific Web sites will also provide detailed instructions for pairing with the phone: www.chrysler.com/uconnect, www.dodge.com/uconnect and www.jeep.com/uconnect.
• Press the Phone icon button to begin
• After the Ready prompt and subsequent beep, say Set Up Phone Pairing
• When prompted, after the voice or beep, say Pair a Phone
• You will be asked to say a four-digit PIN that will be needed later to enter into your mobile phone. You can use any four-digit PIN. You will not need to remember the PIN after the initial pairing process
• For identification purposes, you will be prompted to give the UConnect system a name for your mobile phone. Each mobile phone that is being paired should be given a unique phone name
• You then will be asked to give your mobile phone a priority level between one and seven, one being highest priority. The priority allows the UConnect system to know which mobile phone to use if multiple mobile phones are in the vehicle at the same time
Making a Phone Call
• After the Ready prompt, say Dial
• The system will prompt you to say the number you wish to dial
Making a Phone Call Using Your UConnect Phonebook
• After the Ready prompt, say Call followed by the name and designation of a phonebook entry you wish to dial – for example Call, then John Doe, then Work
Terminating a Phone Call
To end a call in progress, press the Phone icon button. All calls in progress will
be terminated.
Phone Redial
• After the Ready prompt, say Redial
• The UConnect system will call the last number that was dialed on your mobile phone. This may not be the last number dialed by the UConnect system
Answering or Rejecting an Incoming Call - No Call Currently in Progress
When you receive a call on your mobile phone, the UConnect system will interrupt the stereo audio to ask if you would like to answer the call. Press the Phone icon button to answer the call. To reject the call, press the Phone icon button until you hear a single beep indicating that the incoming call was rejected.
UCONNECT
CHRYSLER GROUP TECHNOLOGY 17
Dec 29, 2009 | 2005 Chrysler Pacifica
Samsung a177 bluetooth help??????/
I'm sorry buddy because there is no way for your phone to pair up with other BT capable phones because eventhough the phone has bluetooth, it is only capable of pairing up with a bluetooth carkit & bluetooth headset.
The SGH-A177 does not have a File transfer profile (FTP) under the bluetooth profiles that ur phone is supporting.
U need to have another higher model but call Samsung first to inquire if the other Samsung phone you want to buy has a file transfer profile.
check this bluetooth article.
that info is straight from Samsung....
Dec 16, 2009 | Samsung A177 Cell Phone
Phone will not find other phones on bluetooth
I'm sorry buddy because there is no way for your phhone to pair up with other BT capable phones because eventhough the phone has bluetooth, it is only capable of pairing with a bluetooth carkit & bluetooth headset.
The SGH-A177 does not have a File transfer profile under the bluetooth profiles that ur phone is supporting.
I cannot connect my cell a177 to another device via bluetooth
Dec 14, 2009 | Samsung A177 Cell Phone
Samsung sch-s870 not pairing with uconnect on my cell
Feb 01, 2008 | Samsung SCH-a870 Cellular Phone
Cell Phones Logo
1,051 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
