Question about Lexmark Office Equipment & Supplies
My daughter sent me her old Lexmark X4530 and the paper rollers don't seem to be working. Can you tell me how to fix that?
Lexmark X4530 won't load paper to copy
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Mar 16, 2012 | Lexmark Office Equipment & Supplies
I need to install it on my macbook pro, but i don't have the cd
Please visit the Lexmark website to download and install the Lexmark X4530 printer driver for your Mac. Select your operating system > download and execute the file. Follow the instructions on your computer screen.
Sep 15, 2011 | Lexmark X4530 InkJet Printer
Printer will not completely feed through the printer
There could be something that's blocking the paper path. This article in the Lexmark website on Paper Jam and Misfeed Troubleshooting in the Lexmark X3500, X4500, X4600 & X4800 Series All-In-One might help fix the problem.
Mar 20, 2011 | Lexmark X4530 InkJet Printer
Paper jam! paper begins to feed then goes crooked
Please do all the things that you can do before you consider buying a new printer. You can take your printer into a service repair center or computer repair center in your place. If there is nothing that they can do then you can take an option of buying a new one.
Nov 28, 2009 | Lexmark X4530 InkJet Printer
Paper won't feed from tray unless you push it through to the second rollers.
I am a HP service tech. Dust can build up on the rollers or the rollers can harden over time. Usually we replace the rollers (get them from lexmark). Also, we use a fluid called "Roller Rejuvenator/Platen Cleaner". It's made by a company called Techspray. Part number 1612-2SQ. That should clean the roller and soften the rubber up a bit. The only way to prevent this is keeping the printer in a clean environment. Dust and dirt is a printer killer. Consider getting some kind of cover for the printer when it's not in use. Good luck.
Jul 06, 2009 | Lexmark X4530 InkJet Printer
Lexmark X4530 left cartridge incorrect
You must upgrade your firmware on your printer.
Lexmark has a technical support bulletin :
Cartridge Numbers 23 and 24 Are Not Recognized on X3500-4500 Series Printers
Jun 06, 2009 | Lexmark X5470 All-In-One InkJet Printer
Paper jam
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck..
Sep 10, 2008 | Lexmark X4530 InkJet Printer
Lexmark X2470 Jam
IF this did mot work ,Please contact Lexmark as they sent you refurbished printer which may defective roller on it , ask them to send a good printer this time..............
Mar 22, 2008 | Lexmark X2470 All-In-One InkJet Printer
Old lexmark paper feeder slips
Nooooooooooo . Don't buye new Printer
It simple problem IT paper tray Relay has to be cleaned . Pls clean the Relay with the dry cotton cloth and refit it . It will Work fine ..
Thank You
Feb 18, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
