Question about Refrigerators
Side-by-side Frigidaire...PLHT219SCB9....fridge not nearly cold enough; ice maker not making ice but freezer is keeping things rock solid; when i press on the inside back panel of the freezer (because i saw frost building up slightly on it) i feel what seems to be ice breaking behind the panel. took all food out of the unit and let it defrost completely...repowered and still not solved. help would be appreciated! BTW, when i checked, the coils looked like a polar bear there was so much dust and hair on them...cleaned them completely last night...still no better...HELP! Thanks!
  • briankwilkie May 15, 2010
    Thanks for the info...excellent detail. BTW, you are correct - not sure why I wrote side-by-side, it is freezer on top.
  • Refrigerators Master
  • 19,396 Answers
Hi.
The defrost system is failing. This allows formation of ice on top of the evaporator coil. The condenser goes under stress and produces insufficient cooling. The problem will typically affect the fridge section more than the freezer compartment.
Parts in the defrost control assembly must be tested to find the fault. The defrost assembly is located behind the top compartment firewall, as illustrated in diagram.
Parts that can easily be tested are the heating element (Side-by-side Frigidaire...PLHT219SCB9....fridge no - _.gif PS1150464 part 16 in diag ), and the defrost thermostat ( PS469510 part 21 in diag ). Both parts are tested removing them from circuit, and reading Ohms at their contact with a multimeter set on impedance, at Rx1.
If the components are working, they must read continuity. If a part reads infinite Ohms, then it must be replaced.
When problem is element or defrost thermostat, after doing a complete defrost by allowing ice to defrost at least for 24 hours, the unit will restart coling, at least for a couple of days before new ice formation on the coil start reducing the cooling power.
If the defrost control is also defective, defrost from panel may not be effective.
Try doing a complete defrost by disconnecting power cord or tripping circuit breaker, you will need to move the food in the freezer to a different appliance.
If you already did a complete defrost, and immediately after defrost the unit was still not cooling, then the gas pressure in evaporator coil (part 15 - PS726193 ) must be tested. This test is done piercing the coil and using a gauge in lines, then welding the coil. The test must be done by a technician.
As first line of action I suggest doing a complete defrost, so to ensure that all ice had been removed.
After that call Frigidaire to check your warranty status, and eventually ask a quote on repair.
Here the diagram, click to enlarge:
Here parts and diagrams.
Note: parts and diagrams are for Frigidaire PLHT219SC , as requested. This is not a side-by-side, but a freezer on top. The procedure ifflustrated will be the same in case of a Frigidaire side-by-side. Component location and components part number will be different.
Regards.
Ginko.
Posted on May 15, 2010
  • Ginko
    Ginko May 15, 2010
    Hi.
    You are wellcome.
    Thanks for the feedback.
    Ginko.
Freezer not making ice
Is it an icemaker? Either the water valve is bad or the freezer isn't cold enough or the ice maker is bad. Is it just a ice cube tray? Then it's not cold enough.
Aug 25, 2016 | Samsung RSH1DTMH American Style Silver 524...
Frigidaire Refrigerator PLHT219SCB9... Freezer will not shut off.. cold.. ice maker very slow..
Hello Myles, thank you for your post!
Based off the information you have provided your Frigidaire refrigerator is not shutting off and it is making ice very slowly. If your refrigerator is too cold ice production will slow down. I would recommend turning your refrigerator up to the factory setting of 0 degrees inside the freezer and 37 degrees in the fresh food side. You may also have an issue with the thermostat and I would suggest performing a reset to help clear out any miscommunications within your refrigerator. In order to reset your refrigerator you would need to unplug the power cord for at least ten minutes. I hope this information is helpful. -Matt
Mar 25, 2015 | Frigidaire Refrigerators
Why won't by ice maker make ice?
The icemaker will not harvest if the temperature isn't cold enough. this may be why you are not getting ice.
Oct 04, 2014 | Frigidaire FRS6R4E Side by Side...
Frigidaire frs26h5asb5
Hi Gary,
If your evaporator is not completely frosting over (top to bottom) this normally means the unit doesn't have a proper charge or the compressor can't pump all the freon as it needs to. I would check the charge, this should read "0", if less not enough, if higher than the compressor is failing. I hope this helps.
Aug 17, 2014 | Frigidaire Refrigerators
Fridge & freezer are cooling on bottom but not
when you open the freezer door do you hear the fan blowing?sounds like the air isn't moving,there's also a damper on the fridge side,the door opens to let the cold air in and then closes,make sure the door is opening,you can take the cover off and put an ice cube on the twirled up metal part to close it and put your hand on it to open it to see if it's working
Mar 21, 2010 | Frigidaire FRS26H5AS Side by Side...
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Freezer and Fridge are both not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
hhsg
Jan 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire side by side doesn't make ice
If the Temperature in the Freezer is not cold enough, the Ice maker will not make ice. Make sure the freezer is below 10 degrees or so. Zero is where you want it for the best ice production. What was the reason for defrosting in the first place? Should be frost free?
Jan 31, 2008 | Frigidaire FRS3R5EMB Side by Side...
Freezer not cold enough to freeze items solid
Here are some things you can check yourself. Does it run all the time almost non-stop? if so check the vents under the front of the frig and make sure they are clean. Aslo check the condenser coil (either in back of the frig,or under the frig)Make sure that coil is clean. The condenser coil has to have contact with the outside air in order to release the heat it removed from inside the freezer.
Make sure you frig has plenty of ventilation ( wall too close on sides and back) Hope this helped. If not then you should have a pro look at it.
Jan 28, 2008 | Frigidaire GLRS264ZA Side by Side...
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
