Question about Dryers
Whirlpool Duet dryer won't start F30
Whirlpool duet dryer...I hit the power button and it lights up like it supposed to and then I hit start, the "Sensing" light comes on but nothing else...I went into service mode and it flashes a F30...there is no F30 in the owners manual. It only goes up to F29...The door switch is fine and my voltage is also correct...HELP
  • 3 more comments
  • Potsie1 Mar 30, 2008
    I Hit the power button then I hit the Start button for 3 seconds...When the start button for 3 seconds I hear something like a switch or solenoid engage and the sensing light comes on...that's it...it does nothing else but the timer counts down like it does when it is working correctly...When I go into Diagnostic mode it switches between code F30 and F25..
  • Potsie1 Mar 31, 2008
    The tech log said F25 is an inlet thermistor so I either need the thermistor or the thermal switch. Thanks!!
  • jonesy28 Apr 05, 2008
    Whirlpool duet dryer...I hit the power button and it lights up like it supposed to and then I hit start, the ;Sensing; light comes on but nothing else...I went into service mode and it flashes a PF...The door switch is fine and my voltage is also correct...HELP
  • Anonymous Apr 07, 2008
    my dryer wont turn on i hit the on botton then the start and it just beeps wont turn on helllllllllp
  • robert samples May 11, 2010
    the sensing light is supposed to come on then to start cycle you need to hold down the start button for three seconds give that a try then let me know what it does
My problem was the load was too light. The washer didn't think there was anything in it. Added a blanket and it worked perfectly.
Posted on Mar 03, 2010
    President:
  • 1,314 Answers
Well the sensing light will stay on till it feels wet clothes against it if you in auto dry mode it says it wont start without feeling wet clothes against the silver bars in the vent housing it says it will run in manuel mode even if it doesn't feel them pull the top off the dryer and on the right hand side is a tech service sheet in a plastic bag see what it says
Posted on Mar 30, 2008
  • robert samples Mar 31, 2008
    your too welcome does it show you where it is i was going to send you a service manuel but its too big for e mail
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 | Dryers
Whirlpool duet sport f30
Get the top off there and check the mechanical arm on the dispenser motor. then check that motor. F-30 = dispenser failure.
DUET SPORT SERVICE MANUAL
Sep 24, 2012 | Whirlpool duet Washing Machines
I have a whirlpool duet # gew9250pw1 it won't
my whirlpool dryer has power but does not start
Jul 02, 2011 | Whirlpool Dryers
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool duet front loader dryer....sensing light won;t shut off
I have a whirlpool electric dryer and it cuts off and shows E 1... What is the problem?
Apr 01, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Nov 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer will not start
all the lights are on but when i hit the start button on the dryer it just clicks any idea why this happens
Oct 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GEW9200LQ0 Dryer
can oyu oppen the door nad physically push in on the door switch( little grey switch atop the door opening). do you hear it clicking on/off??? if not you have a bad door switch.
Mar 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F30 error code...what is this problem?
F30 is a dispenser failure code on the Duet Sport washer.
It means the dispenser motor will not go to the proper position.
Remove the top of the washer and inspect the dispenser linkage to see if it is binding up.
Post back with what you find and we will check from there.
Thanks/Mike
Nov 03, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
4,096 people viewed this question
Top Dryers Experts
