Replacing robertshaw thermstat 9520 with a Robertshaw 9420. On older thermostat there was a switch for gas or electric backup. There doesn't seem to be one on the newer model. have wiring labeled from old thermostat. Wired correctly-Display just blinks-Have heatpump with gas backup. Any suggestions appreciated Don
2 Suggested Answers
  • 25 Answers
SOURCE: Wiring Amana Heat pump to inside unit and 9520 robertshaw
colors can vary. you should be able to locate a wiring diagram inside the airhandler and out door unit. you will have to remove the panels. generally though Green is fan RED is power WHITE is reversing valve Blue is common YELLOW is the contactor (usually have to jump w and y terminals at robertshaw tstats. PLEASE DOUBLE CHECK AT SYSTEM DIAGRAMS!!
Posted on Nov 22, 2008
Can I replace my robertshaw thermostat 9420 with an Emerson 1F83-0422
Robertson 9420 is a multistage thermostat designed to control 24V heat pump systems,while the Emerson does that and more. So it seems it should be a possible replacement. However, the wiring may be more complex, depending on the layout and system.
Here is the info on both:
Feb 15, 2017 | Emerson Heating & Cooling
HOW TO TROUBLESHOOT ROBERTSHAW GAS VALVE
check the pressure switch if voltage to both sides its ok then check the gas valve to see if voltage at brown and yellow wires
Oct 14, 2014 | Honeywell Robertshaw Grayson Gas Valve Lp...
Replacing 9420 robertshaw hooking up 6300B honeywell. I have a wire (W2) i don't know what to do with?
If you have a single stage furnace, you do not need that wire....if you have a two stage, then you cannot use that thermostat because it will not do 2 stage...
heatman101
Apr 28, 2010 | Honeywell Focus 6300B 5-2 Days...
We had a reverse problem with our Robert Shaw thermostat we left the thermostat setting at 52 so the pipes wont freeze we wore gone for a week, when we got back the up-stairs wore over 100 the thermostat...
Same thing happened to mine, it was replaced and the new one did the same thing about a year later. Needless to say it was no longer under warranty, which is no problem as I will not have another Robertshaw 9420 installed in my home. Very dangerous, especially if you are not home and it goes up to 99 or higher...
Feb 04, 2010 | Shaw Robert RS-9420 Thermostat
My Robertshaw 9420 thermostat keeps flashing, it won't let me set a temperature.
my robertshaw 9420 wont let me set a temp and two snowflakes are flashing
Dec 23, 2009 | Heating & Cooling
No display on Robertshaw 9600; unit seems dead/furnace works
have you checked to make sure you have a fresh battery in it
Jul 25, 2009 | Shaw Robert RS-9420 Thermostat
Robertshaw 9420 thermostat engages inside fan in OFF position
check with the company u brought it from and check if you have not put the correct conector to the right temals on the back of the switch.
Jun 09, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
