Question about Technics SCEH790 CD Shelf System
Bass doesnt work
Everythings connected but the bass isnt working.
    Problem Solver:
  • 19 Answers
It might be the main processor inside the amp. or it could be that the bass connectors have burnt out inside it only takes a little bit of soldering. will be able to find everything you need in a DIY shop
Posted on Mar 25, 2011
Problems
all the wires should be hooked up on certain decks. if they are not theymust be closed for the system to respond. does everything else work? just the volume ajusting doesnt work? if so maybe it is the unit itself
Jul 04, 2013 | Eclipse (AVN7000) Car DVD Player
My bass drum stopped working. The module wont pick up any signal and ive tried everything short of replacing it. Not sure if its the wiring the module or the drum sensor itself.. Everything else works just...
Verify the module by connecting a different pad to the bass drum and see if you can trigger the bass drum sound. This would test the module. Now connect the bass to a different input and see if it will trigger that input. SOME of the triggers have a very small potentiometer in them. I have seen vibration break this pot loose rendering the unit inoperative. Also some people have pushed a screwdriver into the pot too hard and broken it off. Once you know it is the bass trigger, open the unit and look for damage. The sensor is usually a piezo disk. These can break away from their attachment. Reattach with contact cement after cleaning the residue.
Apr 14, 2011 | Alesis DM6 Performance Electronic Drumset...
Remote bass control
there might be a hidden switch on the amp for with or with out bass control
Apr 25, 2010 | Power Acoustik GOTHIC OV2-1800 Car Amp
Bass not plaing only the small speakers, do i have it hooked up right?
I'm having the same problem, bass will cut out randomly everything is plugged in correctly if you bump the subwoofer it seems to come back on for a bit then back off, did you ever find a solution for this?
May 23, 2009 | Logitech Z-560 Computer Speakers
2005 Dodge Neon SXT Kicker Amplifier
if its a new amp there should be a problem. make sure you have your remote wire hooked up to your radio(its blue). make sure your fuse on your amp wire isnt blow and make sure you have a good ground. if your runnin the ground off the car make sure the paint is scratched off that area
Mar 08, 2009 | 2005 Dodge Neon
Behringer Bass V-Amp
In my xvamp, a strucked microbutton caused E2. I've replaced the button, and everything went right :D
Nov 29, 2008 | Behringer F-CONTROL AUDIO FCA202 External...
Sony amp 1000w
Check the wiring of the speakers (both inside the box and between the box and the amp). It sounds like one speaker is wired incorrectly at one connection point.
Sep 09, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
LIGHTS ON BUT NO BASS
Is the master/slave switch set to master? Have you tried feeding the signal into a different amp to make sure that there is signal reaching the amp?
Sep 18, 2007 | Car Audio & Video
Technics SCEH790 CD Shelf System Logo
37 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
