Question about Whirlpool GSC9455 Top Load Washer
I have a Whirlpool Top Loader Estate Series Washing Machine and the agitator will not spin properly?
    President:
  • 1,218 Answers
Good day,
Most models used a split agitator. If your describing the top part, then an Item called "dogs" has failed. Yes that's Whirlpool's name not mine.
Here's a link to get you up and running. Inexpensive repair.
http://www.youtube.com/watch?v=V5wIN1J70-Y&feature=player_embedded#
Posted on May 15, 2010
Whirlpool washing machine top loader will not rinse or do final spin
If your machine fills and agitates through the wash cycle and then stops, check the lid switch.
http://www.youtube.com/watch?v=bV8C6aLBL9w
Mar 03, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
My whirlpool top loader extra large washing macine
Many late model washing machines use a direct-drive system to agitate and spin. They don't use belts or pressure wheels to transfer power and motion from the motor to the transmission. The motor is coupled directly to the transmission. If the motor is running and there is no agitation or spinning of the tub, the culprit is usually a plastic coupling between the motor and transmission or the transmission itself.
Aug 07, 2008 | Washing Machines
Whirlpool top loader washing machine needs clutch
also check drive block for the inner basket to make sure it is ok.drive block is under the agitator.remove agitator with 7/16 socket.
Mar 03, 2010 | Washing Machines
Whirlpool top loader model #LA9500XTNO won't agitate
the agitator dogs need replaced sounds like.4 little comma shape pieces underneath the top of agitator
Jan 15, 2010 | Washing Machines
Kemore elite top loader won't fully agitate
If you have a whirlpool built machine th problem is probably the agitator dogs. They are located inside the agitator. My guess since you say it doesn't fully agitate. If changing the dogs does bot fix the problem then the coupler is probably bad and that connects the motor to the agitator.
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
My Kenmore series 70 washer will wash and then the machine stop. If I move it to the rinse cycle it will start agitating again and then it will shut off again. It seems li9ke the spin cycle isn't working
Welcome
Either of these three problems may be occurring.
Faulty Direct Drive Coupling (Whirlpool / Kenmore / Roper / Estate)
The Direct Drive (motor) Coupling may be broken. Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
Defective Lid Switch
Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly.
All functions operate normally except the machine will not agitate.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This wil require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Thank You Please remember to leave a rating.
Dec 12, 2008 | Kenmore 23822 Top Load Washer
Washing machine noise
check the dogs in the agitater
Mar 25, 2008 | Whirlpool GSC9455 Top Load Washer
Whirlpool GSC9455 Top Load Washer Logo
96 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
