Question about Panasonic Diga DMR-EH75V DVD Recorder/VCR/HDD
DVD recording problems
I have a Panasonic DVD Recorder Model No. DMR-EH75V. I've had this unit a couple of years and any problem it has had I've been able to work through until now. I was attempting to record from the HDD to a DVD. Approximately halfway through the recording something went wrong. It never finished recording and it errored out saying there was something wrong with the disc. I may have lost part of the recording to use another disc. Since then the machine believes there is a disc in it when there isn't. It tells me it can't read any disc that I put in it. I've put in blank disc. I've put in previously recorded and finalized disc. I put in a purchased movie disc. It will not read anything, but shows that a disc is in the machine even if there isn't.
I've tried to reset the machine by holding the off button for 10 seconds. I've tried removing the power supply for awhile. Nothing works. Got any ideas?
  • 2 more comments
  • zta469 Apr 14, 2008
    The exact same thing happened to me a couple of weeks ago. Does anyone know how to fix this without having to send it to be repaired?
    Please help! Thanks
  • akluge Jun 25, 2008
    Same problem ... will not recognize or play DVDs. Tried resetting but no luck.
  • Anonymous Aug 05, 2008
    I've had my DMR-EH75V for about 3 years. Today the DVD drive stopped working. It sounds as though it is trying to "detect" the disk, but is unable to read any DVD's that I put in - blank ones, ones I recorded with the unit itself, regular store-bought movies...nothing.
    I took the drive out, popped the cover off, and cleaned the optic "eye" with canned air. No luck.
  • suleske Sep 21, 2008
    I read the "solution" to this problem and it's not really the solution per se, but a remedy. I'd like to know what is wrong with the unit, if possible.
    Disassembling the unit, I noticed the optical drive is not a generic unit, but something particular to panasonic. I was hoping to find something to replace it with. Alas.
  • 3 Answers
I have the same unit with the same exact problem. I ended up taking it in for repair and it's now working perfectly. I paid $100 for the repair. I dropped the unit off and picked it up myself. I think $30 additional is charged for shipping and handling in US.
PANASONIC CAMERA & DIGITAL SERVICE CENTER
1590 Touhy Ave
Elk Grove, IL 60007-5319
EMAIL [email protected]
888-439-2676
Part Number
RFKNEH75VP
Description
RAM/DIGITAL PCB MODULE
Posted on Jun 28, 2008
6ya staff
SOURCE:
Panasonic DMR-EH75V DVD recorder time shows when OFF, but unit won't turn ON.
Do a hard reset first and then check. If it do not help, it's main system control memory ic will be faulty. Contact any service technician to get this set repaired. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Jan 28, 2017 | Panasonic DMR-EH75V - DVD recorder / VCR...
How do I stop my Panasonic DMR-EH75V DVD Recorder from automatically turnig itself off after 75 seconds?
It could be overheating.. Is it fairly consistent at 75 seconds? To test put the unit in the fridge for 30 minutes then quickly connect it up and test. If it is longer then 75 seconds then something is getting to hot. I've put hard drives (especially laptop ones) in the freezer if I need to copy off data but it clicks/stops working at room temp.
Aug 10, 2014 | Panasonic Diga DMR-EH75V DVD...
Can my Analog reciver Panasonic DMR-EH 75 v be converted to a digital reciever
I bought a set-top converter box from Dish Network, which will operate with the DMR-EH75V through the remote control cable that was provided with the recorder. It tunes in all the available digital channels and uses the RCA A/V cables to connect to IN1 on the back of the recorder. TVGOS is now provided through channel 2.1 (CBS) in our area and it also provides the time signal that keeps the recorder's clock updated. NOTE: ONLY the Dish Network boxes work with these functions. I've had occasional issues with the box after some period - a few weeks - it needs to be rebooted or reset to manual and then back to automatic (which causes it to reboot anyway.) Model no is DTV PAL PLUS.
Jan 06, 2011 | Panasonic Diga DMR-EH75V DVD...
Dvd in set2 mode cannot clear panasonic diga model
If unit display set2 (the number that display set1, set2, or set3), hold down 2 and enter button at the same time while unit is on for more than 6 second.
Sep 05, 2009 | Panasonic Diga DMR-EH75V DVD...
What a story ! Clean your laser eye with Rubbing Alcohol and a Q-Tip. Down updates to your Recorder from Panasonics Website., and install in your Recorder. Order your replacement parts from Panasonic but I do doubt you will need them.
Jun 03, 2009 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Can the panasonic dmr-eh75v copy a vhs tape to DVD?
Yes, that's mostly what I use mine for. You actually copy your VHS to the Hard Drive, then copy from your hard drive to your blank DVD. I'm about 1/3 of my way through reformatting my VHS library (800+ tapes.)
Nov 25, 2008 | Panasonic Diga DMR-EH75V DVD...
ekimt,
Yes, it would not recognize any type of disc. The disc icon was always present on the display even though no disc was inserted. Also, mine went out while recording from HDD to DVD. Panasonic had mine repaired in two business days and it' s working great.
mjs8
Aug 04, 2008 | Panasonic Diga DMR-EH75V DVD...
I have the same unit and luckily there is a service center here in dallas tx called bayard electronics. I just dropped mine off there. check out the website at www.bayardelectronics.com
Mar 29, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Hard Drive to DVD-R recording
Can I record what is on the Tv to my panasonic diga through some kind of hookup?
Oct 26, 2007 | Panasonic Diga DMR-EH75V DVD...
Panasonic Diga DMR-EH75V DVD Recorder/VCR/HDD Logo
1,394 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
