I have been trying to switch on my desk PC but it goes off automatically with a message saying ' no signal output'. please help
  • 4,281 Answers
When you power up the computer then check num lock led on key board if it is on and off when you press num lock then your cpu gives display to monitor .
For that when you power up the computer press F8 key then enter in enable vga mode and go to display property then change screen resolution to 1024*768 then apply and ok.
but if num lock led is constant on or off when you press num lock key then you need to opon cpu cabinet .
Then reattach the ram memory pull cmos cell from motherboard for 10 minutes then check.
Also reconnect processor and it's fan then check.
Also reattach pci card or vga card if any.
Make sure motherboard is not ground with cabinet cover.
Let me know if you need further assistance.
thanks for using FixYa.
Posted on May 15, 2010
How to switch from analog to digital mode
Any contemporary monitor is able to switch analog/digital mode automatically if connection from signal source to monitor is set up properly.
Connect digital output from your graphic card to DVI input of the monitor. Disconnect any other signal cables from monitor and switch on both devices (PC & monitor). Wait a while. Monitor checks its inputs and a activates digital DVI, because it is only one active input on it.
If none picture excluding error message of monitor is displayed, go through these steps:
1) Check whether your monitor is set for automatic input selection. If monitor buttons have no response try to use analog input to activate screen (any picture, desktop background...) and then get monitor menu access by pressing menu button.
2) Find out what connector type has your graphics card in PC. Possibilities are: DVI, HDMI, DisplayPort and some their options. See Wikipedia for connector look if you are not sure.
Remember that blue D-SUB (VGA) connectors are analogue and you cannot activate digital mode through analog VGA cable.
3) Use appropriate cable to connect monitor to PC.
Example: Your PC has HDMI output. Use HDMi-to-DVI cable. Your monitor input is DVI and common DVI-DVI cable is not suitable in case you have PC with the HDMI.
Note that DVI-to-DVI, DisplayPort-to-DVI etc. cables are available. You must buy right one.
Be aware that "Auto" button is inactive in digital mode of monitor.
Nov 18, 2013 | Belinea 1930 S1 Monitor
LG 2542T goes dark after showing "analog power saving mode" message
Can you try the screen in another computer? I beleave the screen goes into power saveing mode when there is no input signal, thats what both my screens do.
Is your computer working?
May 16, 2008 | LG L1717S-BN 17" LCD Monitor
Unable to switch from "Norm" audio track on old tapes
Hello, this problem is because of the nature of previously recorded signal. The recording made in an older way (mono) has a separate head and the solution for your problem can be to clean the head. This head has two functions, for control pulses and audio signal. If you need more info please advice. Arpi
Jun 03, 2007 | JVC HR-DVS3 Mini DV/S-VHS VCR
No signal message on monitor
try reconnecting your monitor to your PC.
see if any cables are broken.
Could you please say what model is your monitor?
Apr 08, 2013 | Computers & Internet
A friend of mine have a sony vaio vgc-rb38g desk top and she has a video card in her unit which was being used since purchase and it started giving her the message no input signal and the unit goes to...
Please check your video card for dirty conection ports and has it cleaned . Retry your PC. If problem persist, your video card is defective and need for replacement.
Regards
Sep 28, 2011 | Sony VAIO VGC-RB38G PC Desktop
Trying to connect my pc to tv have a message on screen of tv saying unsupported signal adjust your pc output.how do i do that
Your TV you are trying to connect to the pc may not be compatible with the connecting device or the connection output to the TV is incorrect.
Please provide more information as to you issue such as :
a. model number
b. year manufactured
c. Has the manual to the TV been viewed
d. PC information needed (out puts/inputs)
Jun 21, 2010 | Computers & Internet
Need help my desk top monitor is showing a sign flashing saying no signal detected need to see how to fix or what might be the issue with desk top
This is the message shown when you power off your computer but you leave the monitor on. If your PC is on but you still see this message then it is a video problem. It could be as simple as a loose connection somewhere in your video cable (either where it plugs into the monitor or where it plugs into the PC). It could also be the monitor-many have different input modes and maybe the input mode changed somehow. Then again something could be wrong with the video card-are components loose on it? Check all of these, in that order (easiest to hardest), and I think you will have found the problem.
Hope this helps.
May 19, 2010 | Computers & Internet
How to set pc to samsung 42' sp-s4243
You need to set the TV to input from the source that the computer is connected to.
You also need to make sure the computer is set to output a signal to it's S-video or video out port (usually Fn F5 or something like that, or there may be an software switch in your desk tray where it is to be tripped.)
Jan 27, 2009 | Samsung SP-S4243 Television
Acer Monitor boots up w/computer then "no signal"
you must have disconnected it while the pc was running.damage can occur while doing this as can a keyboard (they are not like USB devices that can be plugged and unplugged while "hot".)
Jul 20, 2008 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
