Question about IBM ThinkPad A31 Notebook
I have this message appear at startup my system
At least one service or drive faild during system startup
  • elwidaa Mar 30, 2008
    thank if you help me
    Genius:
  • 2,785 Answers
Dear elwidaa
you disable the system restor and update your antiviruse.boot in safe mode and scan your pc for viruse.then you have to reinstall your motherboard drivers again.if the problem is there plz report back
Posted on Apr 02, 2008
I have dell inspiron 1525, with windows 7, and this message appear whenever trying to login to my pc.. "Windows failed to start, a recent hardware or software change might be the cause. File:...
The hard drive may had a BAD SECTOR ( corrupt section )
try to format with normal mode,NOT quick format.
try using LLFTOOL ( hard disk low level format ) http://hddguru.com
quite bit longer to fix the bad section,but works.
akee.4shared.com
Aug 15, 2011 | Dell Inspiron 1525 Laptop
Why do the following messages: Del:Enter Set UP and F12:Boot Menu appear on screen after the computer is turned on?
These are things that someone with a high level of computer knowledge would use. Setup is for getting into the BIOS (Basic Input Output System) and changing low level settings. The boot menu is for booting off other devices such as a CD or a flash drive instead of your hard drive. This is also used for installing windows or running utilities such as memtest.
May 12, 2011 | Computers & Internet
Start laptop windows xp start then go welcome screan then log off, I click log on, then go log off. I try and try but faild. I would never go windows inside. please help. I would also trying windows...
Did you try booting into safe mode? if not? try taht.. press f8 before xp bootscreen appear and select safe mode..if you can log onto your pc using safe mode.. click start>run and type msconfig and press enter.. a window will appear, click startup and check if there are any suspicious applications that are enable..uncheck it.. and run a full system scan with your antivirus..once done, restart your computer with the normal process..see if it works..good luck!
Apr 27, 2011 | Dell Inspiron 1525 Laptop
Toshiba satellite L300 will not boot up. error code 0xc00000e9
What you can do is attempt to repair the system using System Restore or startup repair. I would suggest trying startup repair first.
Method 1: Use the Windows Recovery Environment (WinRE) to run System Restore
1. Insert the Windows Vista or Windows 7 installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
Method 2: Startup Repair from the Windows Recovery Environment (WinRE)
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. (Click the operating system that you want to repair), and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Hope this helps
Ray
Mar 07, 2011 | Computers & Internet
HI THERE, I AM TRYING TO INSTALL A FRESH COPY OF WINDOWS ONTO A ANOTHER COMPUTER, I AM USING THE CD'S I ALWAYS USE SO THEY ARE BOOTABLE DISKS, I KEEP GETTING MESSAGE BACK "DISK BOOT FAILURE, INSERT SYSTEM...
First you need to make sure that the CD drive is selected as the first boot device.
You can set that by going into BIOS setup by pressing Del/F2 during system startup OR during startup press F12 and select CD drive from the boot device selection menu.
Press Enter.
See if the system is able to start from the disc.
Thanks
Feb 20, 2010 | Computers & Internet
Server error
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS. When this occurs, the following message may appear during Power-On Self-Test (POST) and POST cannot continue without user input:
02a2: BMC System Error Log (SEL) Full
Press F1 to Continue, Press F2 to Setup
If the above message appears during POST, perform the following steps to run BIOS setup and delete the System Event Log:
  1. Boot the server and press the F10 key when prompted to run BIOS Setup.
  2. Select the "Advanced" menu.
  3. Scroll down to "IPMI" and press the ENTER key
  4. Scroll down to the System Event Log and press the ENTER key.
  5. At the "Clear System Event Log" selection, press the ENTER key to toggle between "Enable" and "Disable."
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup.
Mar 02, 2009 | HP Compaq ProLiant ML110 G4 Server
Cursor lockup
This just because that there are too many services running in the background of the Operating system
All you need to do is to manually disable maximum of them and disable all the startup Items
Here is how you can do that the easy way
Manual steps to perform a clean boot in Windows XP
Step 1: Start the System Configuration Utility
Click Start, click Run, type msconfig, and then click OK.
The System Configuration Utility dialog box appears.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box.
5. Click the Services tab.
6. (VERY IMPORTANT DON'T MISS THIS) Click to select the Hide All Microsoft Services check box.
7. Click Disable All, then Click on the startup tab and click on Disable All Button and then click OK..
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. Log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK:
You have used the System Configuration Utility to make changes to the way Windows starts.
The System Configuration Utility is currently in Diagnostic or Selective Startup mode, causing this message to be displayed and the utility to run every time Windows starts.
Choose the Normal Startup mode on the General tab to start Windows normally and undo the changes you made using the System Configuration Utility.
Step 4: Optional step to disable features
This step temporarily disables Microsoft features such as Plug and Play, networking, event logging, and error reporting. Also, this step permanently removes the restore points from the computer. The System Restore feature uses restore points to restore your computer to an earlier state. If you remove the restore points, you can no longer restore Windows to an earlier state.
1. Click Start, click Run, type msconfig, and then click OK.
2. Click the General tab, click to clear the Load System Services check box, and then click OK.
3. When you are prompted, click Restart to restart the computer.
Steps to configure Windows to use a Normal startup state
2. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
Aug 14, 2008 | Microsoft Windows XP Home Edition
Shutdown
Aug 14, 2008 | Dell Dimension 8200 PC Desktop
Ibm2366
ok here it is it is a auto repair sys from lenovo
This page has automated features! You can use the automated features on this page by installing a special, free plug-in. This one-time installation will not affect your computer's performance or compromise your privacy or security. fw.gif Install the automated content plug-in
chat.gif Just relax and let Lenovo Experts Live do it for you. Buy it now! New!
Some of these steps may not apply to your computer. Test for system startup after performing each step.
Select your symptom from the following list or continue to the Need more help? section:
Mar 24, 2008 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad A31 Notebook Logo
26 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
