The remote works but the aircondition dont start. the unit start working alone in the midle of the night. please help me.thank you.
  • 53 Answers
Make sure its not on a timer
Posted on May 16, 2010
Testimonial: "very good advice!!"
I have a 1995 buick century trying to take out my valet remote starter but need help disconnecting all the wires my lights dont work and my brakes lights dont work! Can someone please help thank you!
ummm you have a dandy there. sounds to me like who ever installed it cut the wires to connect the remote unit. You will have to find all the wires and reconnect them.
Nov 02, 2014 | 1995 Buick Century
Stops working, beeps and test button comes on
Have you tried pulling the batteries for a while? That alone may fix it. Sometimes, not many, there is a reset procedure for not only for the unit, but the remote also. If that doesn't work, you will have to replace it.
Next time you ask a question, please give us the type of unit, the make and model number. Without that, we would have to guess what type of product you have.
Jan 24, 2014 | Universal MX-900 Remote Control
My LG mini home theater sound system is not
Why not retrieve the instructions for your remote so you can figure out which buttons to push and which ones to leave alone?
Sep 07, 2013 | Audio Players & Recorders
TZS-2
The voltage should be good. It is possible the Infra-red emitter tube might be at fault.
The night vision can work under a full moon, so test the vision part to make sure it is working correctly. If you have an infra red/IR remote control for your TB set, you can test the might vision using that remote to see if the night vision is working.
You can use a second working unit to see if the illuminator is actually working. The illumination is not visible light without assistance.
Jan 31, 2012 | Kalinka TZS-2 'Sova-2' Russian Night...
Hi I have a starway split system air conditioner and the remote is no longer working - I have purchased an Ultra Univrsal Remote and need to know the code to make it compatible with the starway air...
In my experience, the related remote is better than universal remote, as it's not designed for particular unit, but for multi.
Anyhow, take universal remote, power on your a/c.In front of your a/c, press setting and then < or > continuously. In your remote the number will go up or down as 999.........998.997......... or 1101...102........103...104. like that. Stop, when you get response by beep sounds.That is code for your a/c to operate. Helpful?
Dec 30, 2010 | Heating & Cooling
Water / ice dispenser stopped working and then the unit shut down over night.
rwerew
Sorry to read about your problem. you can have many different problems.
1. Bad temp control
2. Failing compressor
3. Defective start cap
4. Defective overload protector
5. Defective control board
I suggest you call a service company. since i will assume you dont have the equipment to work on these issues
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 29, 2010 | GE Profile PSW26P Stainless Steel Side by...
Last night I dropped the remote for my CLT1554 tv
Please reinstall batteries in remote and check.
If still does not work then remote circuit board could be damaged and new remote is an option.
Hope this info will help you.
Thanks.
Feb 14, 2010 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
I have a 1995 ford explorer eddie bower the air works but the heater does not what could be the problem
CAN BE ONLY TWO THINGS IF THE HEATER USED TO WORK,YOU CLIMATE CONTROL UNIT OR THE ACTUATOR ON THE HEATER UNIT ASSEMBLY USUALLY ON THE BOTTOM OF THE WHOLE UNIT IN THE MIDLE OF THE FRONT LOWER END OF THE CONSOLE,AND IF YOU ARENT SURE WAS WORKING BEFORE CHECK FOR JUMPED HEATER LINES UNDER THE HOOD BECAUSE WHEN THE HEATER CORE START LEAKING SOME PEOPLES DISABLE THE HEATER TO DONT GET LEAKS INSIDE THE VEHICLE BECAUSE IS EXPENSIVE THE LABOR FOR REPLACE THE HEATER CORE IN THIS MODEL(YOU HAVE TO TEAR THE WHOLE DASH BOARD AND GET IT OUT OF THE VEHICLE)
Sep 24, 2009 | 1995 Ford Explorer
Centrex CTAR65GW reverse cycle air con. missing remote control -
Thanks for your response, but we finally found a universal remote through Andca Airconditioning in Rosebud, Victoria. It cost us $90 and worked a treat.
Thanks and regards
Wendy
Jan 07, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
