Question about D-Link DIR-625 (790069292637) Wireless Router
No internet access
I have the router setup my laptop says conected but no internet access, i can connect to the internet on my home pc but not on my laptop, i have installed a new ethernet card, i have reset my router, still, no internet access
  • 93 Answers
Configure the Router 1. Step 1
Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
Posted on May 16, 2010
I dont have internet i just want to share music around the house i just want to conect my wireless laptop with my non internet pc, but cant install on my comp due to not having internet access at home. How...
Use the windows home network setup utility and create a home network. You will have to tell windows to share the files on the computer providing the source material. Both computers would have to have wireless capabilities in order for this to work as well.
Aug 05, 2010 | Belkin Computers & Internet
Computer does not connect
NEW LAPTOP? Noticed a lot of post for same Laptop as same time.
If try to use wireless - you need to set-up wireless part of router and wireless part of laptop (Wireless Software).
Setup your network same it is on the PC.
Use Network setup wizard, if not know how in system manager, in the control panel.
Network Name is same on both, MYHOUSE is good.
The only thing different should be NAME, like SYS02,
PC would be SYS01, and IPaddress ( first 3 sections same as PC - Last section is indivual system - example follows:
PC = 192.168.1.40 then LT = 192.168.1.41
Suggest you hard wire laptop to router to verify network connection then work on wireless connection setup after you get connected thru hard line.
Mar 17, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Smc setup cannot be accessed but have network
login to your router and go to wifi and check for the mac address of your laptop, if its require to change anything do it according to it.
To know the mac address of your laptop go to command prompt and type --> getmac
Mar 11, 2010 | SMC Barricade g SMCWBR14-G (662698582192)...
Laptop does not detect wireless from Zyxel 660 router
Dear! You will have to enable wireless conection to access the router and internet. Check your adapter settings and enable wireless conection. Your problem will be solved.
Thanks
Jul 28, 2009 | Zyxel Prestige 660HW Wireless Router...
I am getting internet signal if I plug in the cord from the wireless router to the laptop. The laptop says we have signal and we are connected to our home network but then we cannot use the internet. It is...
You have set up some kind of security on your router, you have to do the same on your laptop.
Se it as a key that have to fit the lock in order to open the dor.
When you access the router, USE A CABLE, do NOT access the router with a wireless conection.
/Teis
Vote :-)
Nov 30, 2008 | Microsoft MN-700 Wireless Router (p5308j)
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
WIFI
You can go for a wireless router, so that you can access internet anywhere in your house, ,
Jul 18, 2008 | Dell Inspiron 5100 Laptop
Wireless Internet
yes you can purchase the router
Wireless-G Broadband Router
satellite?blobcol=urldata&blobheadername1=content-type&blobheadername2=content-disposition&blobheadervalue1=image%2fjpeg&blobheadervalue2=inline%3b+filename%3dwrt54g.jpg&blobkey=id&blobtable=mungoblobs&blobwhere=1193783379233&ssbinary=true
  • All-in-one Internet-sharing Router, 4-port Switch, and Wireless-G (802.11g) Access Point
  • Shares a single Internet connection and other resources with Ethernet wired and Wireless-G clients
  • Wireless data rates up to 54Mbps -- 5 times as fast as Wireless-B (802.11b), but also interoperable with Wireless-B devices (at 11Mbps)
  • Advanced security: Wi-Fi Protected Access™ (WPA), wireless MAC address filtering, powerful SPI firewall
May 02, 2008 | Dell Inspiron 6400 Notebook
Wireless connection with work laptop
have a look at the book that came with the wireless router and see what is the ip address. it should be 198.162.1.254. type this into your home pc internet explorer address bar. you should get the router settings page. then go to the wireless setup page and you will find the wep key there
Apr 21, 2008 | Dell Latitude D610 Notebook
D-Link DIR-625 (790069292637) Wireless Router Logo
132 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
