Question about ASUS PG191 LCD Monitor
The monitor screen go to black after 5 seconds, when I turn the monitor off and again on its working again for aprox. 5 sec.and go to black again ???
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 16, 2010
Monitor works ok then suddenly loose picture(black screen) turn monitor off then turn it back on works for approx 5 secs then goes back to black screen
there are many reason why a monitor suddenly turned off then back to work again , over use may over heat that cause the soled parts on the printed board of your CRT go loosen , try to re sold it, sometimes your PC might stop viewing so the monitor automatically shot off stby mode , loose connection due to basted parts , capacitors,power regulators,resistors , even the cables also might be.
Jul 10, 2011 | Fujitsu Siemens MCM 173V (White) 17" CRT...
Monitor flickers and goes blank after 5 seconds and keep repeating this very often.
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 26, 2010 | Acer AL2016W 20" LCD Monitor
My LG Flatron L1717S wen I power up it flashes good for 2 sec
are you getting a check signal cable message? any on screen instructions?
try the cable, if it works on another monitor, then sorry to say but your monitor is fried
Sep 01, 2009 | LG Flatron L1750S 17" LCD Monitor
Screen goes black, but power light is on (not blinking)
The problem is not with your screen. Its the problem of Video Card of your system which is unable to send Video Signals to the Screen.
Apr 23, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Monitor E172FP only fashes on then turns black.
its a bad solder/heat problem with the power board you need to repalce eaither the board or parts on the board the parts on the board are:
Q743 - FU9024N
Q741 - FU9024N
Q759 - 2SC5707
Q739 - 2SC5707
Q760 - 2SC5707
Q740 - 2SC5707
and part PF751 the black fuse - 3A 125V
i don't promise that this will fix it but its worth a shot
Apr 10, 2009 | Dell E173FPb 17" TFT LCD Monitor
Monitor goes black after 5 seconds but has power.
Power Supply inside the monitor is bad, needs replaced. Compare cost of replace or repair. Usually best to just go get a new monitor.
Mar 17, 2009 | HP Compaq FP5315 15" LCD Monitor
My microtek 517m lcd monitor it keeps going blank
the monitor its self has no problem but try installing the drivers again
Feb 06, 2009 | Black Box Computers & Internet
LCD display Proview
If the screen is pinkish chances are the panel is defective.Should follow-up with Company Proview and do some correspondence.
Samir
May 23, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor black screen
Your first step in troubleshooting this problem is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is shot.
May 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
ASUS PG191 LCD Monitor Logo
107 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
