How to solve the problem file isapnp.sys caused an unexpected error (32768) at line 5882 in d:/ xpclient/ base/boot/setup.c.
But i am unable to re-install XP
Posted on Dec 19, 2012
  • 11,800 Answers
Something is wrong with the file system on the partition in which you try to install XP. Start the install again and this time when asked where do you want XP to be installed delete the old partition and create a new one.
Posted on May 15, 2010
Windows could not start because the following file is missing or corrupt: System32\DRIVERS\isapnp.sys
This usually occur when unexpectedly deleted or corrupted the files cause by a virus or a third party software. All you have to do is repair your OS using your installation CD(XP) and do not reformat your HDD. Reboot your PC using your XP follow the instruction needed then when it come to the Repair, Do Not Repair, or Don't do anything choose Repair and follow again the instruction.
Apr 24, 2011 | Computers & Internet
BOOT MGR Missing
I get a - acpiec.sys unexpected error (1024) at (5064) in d:\xpsprtm\base\boot\setup.c. - when attemping to reinstall winXP my Dell XP software for my Dell 9100 the drive has been cleaned and only on partition all the drive test passed is their a hidden partition that I can not get to but I am not showing any partitions except one I created ?
Apr 09, 2010 | Western Digital Caviar SE WD1600AAJS 160...
On linux centos it doesn work
The CT4170 SoundBlaster "Vibra" cards are old 16-bit ISA PnP cards, and were not detected at install by Linux kernels 2.16.15-27. You need to get the "isapnptools" package from the Fedora or CentOS sites, and do the following:
2. Install isapnptools using dpkg -i path-to-downloaded file .
3. Create and edit file /etc/isapnp.conf and put the following contents in it:
(READPORT 0x0273)
(ISOLATE PRESERVE)
(IDENTIFY *)
(VERBOSITY 2)
(CONFLICT (IO FATAL)(IRQ FATAL)(DMA FATAL)(MEM FATAL)) # or WARNING (CONFIGURE CTL00f4/-1 (LD 0
(INT 0 (IRQ 5 (MODE +E)))
(DMA 0 (CHANNEL 0))
(DMA 1 (CHANNEL 1))
(IO 0 (SIZE 16) (BASE 0x0240))
(IO 1 (SIZE 2) (BASE 0x0300))
(IO 2 (SIZE 4) (BASE 0x0388))
(NAME "CTL00f4/-1[0]{Audio }")
(ACT Y)
(WAITFORKEY)
4. Run "isapnp /etc/isapnp.conf". If it reports errors, you must change configuration above (it is suited to my setup). Try "pnpdump -c" and put its output in /etc/isapnp.conf file. If it does not help, you must find the correct configuration manually, for example change port to 0x220. For full list of possible values run pnpdump. Note that if you change the configuration, you must change options for modprobe below.
5. Create and edit file /etc/modprobe.d/sbvibra and put the following options in it:
alias snd-card-0 snd_sb16
options snd_sb16 port=0x240 irq=5 dma8=0 dma16=1 isapnp=0
6. Run "update-modules"
7. Run "modprobe snd-card-0". If it works OK (check if "ls -l /dev/dsp" shows that file is present), perform the steps below to make setup permanent:
8. Append following line to /etc/modules:
snd-card-0
8. Go to system configuration (in GUI) and choose "Services". Enable "isapnp" service and tick option to start it at boot.
Hope this helps :)
Ted
May 23, 2009 | Creative Labs CT4170 Sound Card
Asus K8V-8 Deluxe and SATA F6 installation issue
You might have a bad version of the text mode driver for it.You can make your own slipstreamed XP install CD with my brief instructions to include SATA drivers so that there is no need for F6. http://rapidshare.com/files/211421782/nLite_Instructions_XP.pdf
May 02, 2009 | Computers & Internet
Missing or corrupted file C:\windows\himem.sys
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
Dec 27, 2008 | Compaq Presario Notebook
Pc945gz7mc-k52h
Put your hard disk to another computer format all drives unallocate the drives and aloocate in newly again..then istall the OS newly then put back in your system and check whether it works...
Sep 26, 2008 | Computers & Internet
Acer 5570z laptop ql2200.sys error
Clean the recovery CD if you are using one.
If the recovery runs from the hard drive you may have a failing hard drive.
You can download an image of a CD (an ISO file) from
http://www.hitachigst.com/hdd/support/download.htm
If you dont have software or are unsure how to burn an ISO image get this:
http://isorecorder.alexfeinman.com/isorecorder.htm
Dec 24, 2007 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
283 people viewed this question
David Payne
David Payne
