Question about IBM ThinkPad T23 Notebook
Batter charging problems
I have tried 3 new batteries and each will not charge. The PC runs on AC and the battery is listed as 0%, but windows indicates its charging but its not. I suspect it has to do with the firmware on the T23, but I can't update it without a battery?
  • Matusai May 15, 2008
    The Same problem here !!!!!
    Sergeant:
  • 349 Answers
It sounds like a component within the laptop may have failed, that controls the battery charging ,but allows it to run the laptop when plugged in.
unfortunately its not something that can be fixed via text messages, you need to take it to a pc shop to be fixed.
good luck with that
Terry
Posted on Mar 31, 2008
I have an nv5468u with Part Number LXWDG02030. My laptop wont charge the battery, I can still turn it on using the ac adapter but it wont charge the battery, the battery light indicator just alternates...
Hi there. Your problem seems to be the battery. Usually when the battery is at the end of its life the indicator stays at 0%. If you are still unsure you can go to download.com and get free battery testing software. Good luck...
Mar 30, 2011 | Gateway NV5468u Notebook
Battery is listed at 3%, plugged in - not charging. Can run on battery about 5 minutes - max. Can run on power indefinitely. Is this a battery problem or possibly charging system?
first change the battery. the battery is likely to be damaged.
so try with a valid batter.
if it doesn't work:
sorry but The "Supply Center" of your Laptop is gratly damaged so take it to a guarantee center.
Jan 15, 2011 | Acer Aspire 5500 5570-2609 Laptop
Battery totally exhausted. Direct power line is not working. Is there any relation between battery exhaustion and non-operation of direct power line? Whether installation of a new battery will solve the...
Step 1 - Disable the Windows Power Management
In Windows, right-click the Desktop and select Properties in the menu list. 2. Click the Screen Saver tab and then click the Power button. 3. Under Power schemes, select Always On in the drop down menu. 4. Under Settings for Always On power scheme, select Never in each of the drop down menus. 5. Click OK on the Power Options Properties window and then click OK on the Display Properties window.
Step 2 - Fully charge the battery
Connect the AC adapter to the notebook.
Charge the battery until the Windows battery meter is at 100%.
Step 3 - Fully discharge the battery
Remove the AC adapter. Keep the notebook on until the battery has completely drained and the notebook automatically turns off. Connect the AC adapter to the notebook. Keep the AC adapter connected to the notebook until the battery has completely charged.
Step 4 - Enable the Windows Power Management
In Windows, right-click the Desktop and select Properties in the menu list. Click the Screen Saver tab and then click the Power button. Under Power schemes, select Portable/Laptop in the drop down menu. Click OK on the Power Options Properties window and then click OK on the Display Properties window.
Jan 31, 2010 | HP Compaq Evo n610c Notebook
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
Will not run on AC power or charge battery
If issue occurs with a known good AC adapter then next is replace the motherboard. Around $150 on EBay
Oct 03, 2009 | Dell Latitude D600 Notebook
I had a GPU issue so i searched in google to find a solution and i found a solution it was needs to open the laptop , the motherboard the GPU problem solved now but there's a new problem that i didn't have...
I would check to make sure the AC adaptor connection on the motherboard was not damaged when you opened the pc. ( I have done that a few times.) I'm uncertain of what you have done to solve the problem. Since you have the new battery, again try to charge the battery. when it show the charge is complete, let the pc run until it goes off, when it does, keep powering your pc on until it will no longer power on. (You want to make sure the battery is completely drainned.) Once complete, try plugging the AC to your pc and monitor the charge. You may need to let the pc charge for at least 2 hours before powering the pc on.
Good Luck
C2Solutions
Aug 17, 2009 | HP Pavilion dv2000 Series Laptop Full...
Dell inspiron 1525 will not charge the battery
This problem has arised because your motherboard hasn't identified your battery. So, this is motherboard problem.
next time when you chat with the dell representatives, tell them that your motherboard is not recognizing your battery. They would arrange a pickup and would have it repaired in their center.
Good luck,
~regards,
Jegan
Jun 03, 2009 | Dell Inspiron 1525 Notebook
Battery won't charge
If the battery is not charging, then the charging circuit of the motherboard is bad.
Page 3-22 lists the spare part number for the motherboard. (4 versions depending on options)
Chapter 5 covers disassembly and reassembly
http://www.hp.com/ctg/Manual/c00212209.pdf
May 21, 2008 | Compaq Presario R3000 Notebook
Battery is not charging
From HP website- worked immediately for me.
This document pertains to HP Notebook PCs with Windows Vista. Understanding battery charging issues If the notebook battery is not charging or the notebook does not indicate that the battery is charging, the most likely scenario is that the battery itself is operating correctly, but its power management software may have become corrupt. In order to correct the problem, you will need to uninstall and reinstall the power management software by using the Device Manager. This document will explain how to uninstall and reinstall the ACPI Battery listings in Windows Vista, as well as how to obtain and install updated BIOS files, if needed to correct other battery issues. Uninstalling and reinstalling power management software in Windows Vista In order to correct problems with the battery's power management software, follow the steps below.
  1. Click Start and type device in the search field, then select Device Manager .
  2. Expand the Batteries category.
  3. Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall . WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
  4. On the Device Manager taskbar, click Scan for hardware changes c01176420.gif . Alternately, select Action > Scan for hardware changes .
Windows will scan your computer for hardware that doesn't have drivers installed, and will install the drivers needed to manage your battery's power. The notebook should now indicate that the battery is charging.
Oct 19, 2006 | HP Pavilion zd8000 Notebook
IBM ThinkPad T23 Notebook Logo
60 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
