Question about Legacy Audio LDVD74 Car DVD Player
Where can i find replacement wires for legacy stereo ldvd84
    President:
  • 2,317 Answers
I would check on e-Bay. You can usually find wiring harnesses from sellers on there.
Posted on May 15, 2010
Free wiring diagrams
google it my good man
Aug 25, 2014 | 1991 Subaru Legacy
I need to replace the stero and speakers in my 1993 Subaru legacy, help?
in-dash units require removal of the cosmetic cover before much of anything else..usually the screws are at the sides and bottom of this facing..once removed the front mounting for the radio should be visible..most have bolt flanges on both sides and some have a security bolt in back behind the unit thats hard to remove.requires reaching up and behind the unit to take off. then disconnecting the wires from the unit..and reconnecting whatever youre putting in its place..
Feb 10, 2013 | 1993 Subaru Legacy
Installing aftermarket Kenwood stereo on 1991 Subaru Legacy. The subaru stock wiring does not have a red ignition wire. Can i simply connect the kenwood ignition wire to the Accessory +12v (Yellow/red)?...
Hi, according to my source, there should be an accessory wire that is blue with a yellow stripe. If your is yellow/red, that's fine. You actually should prefer an accessory wire to an ignition wire as there may be less static on the accessory wire. Just make sure the wire does not have power when the key is off. Don't use the illumination wires--they are not needed for the aftermarket head unit and should be taped off.
1991 Subaru Legacy Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/Green
Car Radio Switched 12v+ Wire: Blue/Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Blue/Red
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Blue/Black
Rear Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Yellow/White
Left Rear Speaker Negative Wire (-): Blue/Red
Right Rear Speaker Positive Wire (+): White/Blue
Right Rear Speaker Negative Wire (-): Blue/Black
May 31, 2011 | Car Audio & Video
Front door speakers in my 2004 legacy do not work. tried fade on stereo still nothing,please help.
your may have blown your speaker of you might just want to pull them out and check to make sure that the wires are run and didnt fall out.
Apr 21, 2011 | 2004 Subaru Legacy
Installing aftermarket stereo. cannot locate a
BEST BET IS TO GO TO A STORE THAT SELLS &INSTALLS.... I,VE HAD THEM MAKE A COPY OF A SCHMATIC BEFORE... ,CHARLIE
Mar 02, 2010 | 1997 Subaru Legacy
Need stereo wiring diagram
Constant 12V+ Red/Green Switched 12V+ Blue/Yellow Ground Black Illumination Red Dimmer n/a Front Speakers 6 1/2" Doors Left Front (+) Yellow Left Front (-) Blue/Red Right Front (+) White Right Front (-) Blue/Black Rear Speakers 6 1/2" Rear Doors Left Rear (+) Yellow/White Left Rear (-) Blue/Red Right Rear (+) White/Blue Right Rear (-) Blue/Black
Apr 29, 2009 | Car Audio & Video
Radio install
http://www.modifiedlife.com/1991-subaru-legacy-car-stereo-radio-wiring-diagram/
Mar 05, 2009 | 1995 Subaru Legacy
I have an american legacy series 2 1000watt apm
Check and see what size fuses it uses. Your watt power means nothing without good fuses. My suggestion would be to go buy 40a fuses and replace the ones you already have.
Feb 27, 2009 | Legacy Audio American Legacy II LA290 Car...
Legacy Audio LDVD74 Car DVD Player Logo
47 people viewed this question
Top Legacy Audio Car Audio & Video Experts
Mark Skinner
Richard Lukszys
Richard Lukszys
Are you a Legacy Audio Car Audio and Video Expert? Answer questions, earn points and help others
