I just have a question
My son is wanting something of this sort yet he is all about HD quality. What sort of resolution does the Proxima 1500 have?
Thanks.
  • 563 Answers
Hi there
I could unfortunately not find a Proxima / ASK 1500 , the closest I get is a 1300. Of which the resolution is WXGA (1280x800)
This is not near HD resolution , but will none the less give you a great image quality.
Posted on Mar 31, 2008
SOURCE:
Records & dubs but very poor resolution
You've got a Dish Network's HD DVR and a Toshiba 720P HDTV - so this part of the mix will maintain the HD pictures and high quality digital audio that you're used to seeing.
The trouble begins when you introduced the Magnavox VCR / DVD device. The highest quality video content that this device can record is the 480 type, regardless of the input or source quality - which in your case would be 720P via HDMI cables. 480 is considered "SD" or "standard definition". This is the weakest link in your setup and is responsible for your unsatisfactory results.
The Magnavox will "upconvert" to 1080 lines of resolution. The key here is the term "upconvert" True HD recordings are taken of a scene and capturing either 720 or 1080 lines of resolution in the image or video (such as a camera taking a photo or video); or recording the playback of a previously recorded 720 or 1080 lines of resolution source. Recording a 480 lines of resolution source with a an 720 or 1080 lines of resolution device will not make the image HD. The recording can not possibly be better than the original. In fact, due to losses, each generation of copy becomes worse and worse. Upconverting simply "fills in" the missing parts between the 480 source and 720 or 1080 output with what it "thinks" is missing data. The results are what you see on the screen. The original capture did not save more info that 480 lines of resolution so it is really impossible to improve it.
The recording can not ever exceed the quality of the original (the Dish Network DVR at 720 or more) and will only be as good as the weakest link (the Magnavox DVD / VCR at 480). Additionally, the moment you change from digital to analog, you lose quality instantly. Digital signals - both video and audio will always be faithfully reproduced do to error correcting technology, etc. that simply isn't available in the analog world.
You need to use a digital recorder capable of capturing and playing back of 720 or 1080 lines of resolution video and AC3 audio for optimum video and audio on a Blu Ray recorder or other device with hard drives or memory such as MP3 recorder. Otherwise you'll have to accept reduced quality of standard L & R analog audio and 480 lines of resolution of SD video. You can not expect HD audio and video if you try to save to equipment designed for SD / analog.
Dec 19, 2013 | Magnavox ZV427MG9 DVD Recorder VCR
If i use a 128 MB card how many pictures will it hold
That depends on the image resolution and image quality. At the highest resolution and best quality you may be able to hold about 30 pictures. At the lowest resolution and least quality you may be able to hold about 1500 pictures.
Mar 31, 2012 | Casio EXILIM Digital Camera
Hi,i actualy bought an aoc 2243fw2k led monitor,i hav a nvidia geforce 220gt graphic card,even though i installed the latest drivers for both graphic card n the monitor,i stil cant experience high...
1920x1080 resolution is the starting point for HD video. If you have set your desktop resolution to that or anything avove then you should be running at HD resolutions. Maybe the image/video you are watching is not at a HD resolution, therefore it will appear distorted and streched (poor quality). To fully experience HD playback use video files and imaged that are at the 1920x1080 resolution and above.
Dec 16, 2011 | Computers & Internet
Is the integral Freeview on my 32 inch Full HD TV HD or Not
Simple answer. No. But please read on . . .
Full HD Freeview, i.e 1080p does not exist. The four HD channels currently available on Freeview all transmit at 720p resolution. There is insufficient bandwidth in the TV transmission range for the HD channels to transmit at 1080p. It could be done, but it would be at the expense of other channels.
Your TV, however, is Full HD, as indicated by the 1080p in the specifications. This means it can display a full HD picture from a device which outputs at 1080p resolution. Devices which generally output at 1080p resolution include Blu-ray DVD players, games systems and PCs.
When viewing a Freeview HD channel, your TV will display the picture in 1080i (interlace) resolution. This is not true/full HD. The transmitted picture comprises of 720 horizontal lines and the software inside the TV is creating the additional 360 lines and interlacing them between the 720 lines from the original transmission in order to create a 1080 line picture which fills the entire screen.This process is commonly known as 'upscaling' and can cause deterioration in the overall picture quality, most noticably on poor quality, cheap TVs.
Hope that explains it for you sufficiently!
Nov 10, 2011 | Televison & Video
I pc maniac...but i have a problem and can´t solve it. Theu say this is a full HD lcd, but how come i can´t use the higher resolution (1920x1080) in the desktop??? I really don´t understand...
Does the monitor support this resolution? Does your video card? Usually it will be one of these. What resolution do you have it at?
Thank you,
Lee
Mar 27, 2010 | LG M227WD-PZ LCD TV
Just bought the Samsung 550 Plasma Hd Tv can you tell me if we just use a regular cable from the wall to the Tv will the picture quality be sort of off.. WE have an HM MI cable from the cable box to the TV...
unfortunately cable does not give you the best quality picture and "fuzziness ' is the reduced resolution being displayed on the tv.
the easy way to check the picture quality is to get a decent hd antenna and scan using it for free hdtv signals, if these are also fuzzy, on all channels then the tv has a problem but if it is only on a few lower resolution channels then its just the way it is until everyone is hd 720 or better.
Jan 31, 2010 | Samsung 50 in. Plasma TV
Picture quality for gaming
Match the PS3's output resolution to your TVs (in this case 720p).
Don't sit too close, otherwise you'll start to see individual pixels.
Make sure the HDMI cable is good quality.
As for picture settings, they will very so much according to the viewing conditions that i cannot give you settings that are gauranteed to work for you. But sharpness should always be 0 when dealing with HD content.
If you want to really get the best picture from your TV, try using a THX disc to calibrate it. Luckily these are normally included on Disney PIXAR DVDs, so go find yourself a copy of CARS or something. Follow the instructions of the THX setup, and you should have youself a sweet looking picture in no time.
Hope this Helps.
Apr 28, 2009 | Samsung PS50A457 50 in. Plasma TV
Wobbly screen image
Are you connected to a PC (DIGITAL SIGNAL)or a video source?
If you are getting a jumpy screen from a digital source like a LATTOP/PC you many be feeding a signal that's not equal to the resolution of the projector itself.l There is circuitry in the projector to attempt to convert the resolution of the picture received into the screen resolution. It's an imperfect process, especially if you have a higher screen resolution going in than the 1024 x 768 native resolution of thie LX-1.
What you need to do is set the video output of the computer to that resolution.
The original LX-1 Infocus units had a less capable resolution resolving circuit than their later units.
In a portable, it's possible to setup two resolutions - one for the Laptops own screen resolution and another for the auxilliary (external) resolution of a secondary display or a projector attached there. Modern Laptops usually have a resolution of 1400 x 800 pixels or higher (mine are 1920x 1200), The LX1 can not handle that resolution well at all. If you set the external output to something slightly higher like 1200x800 it will handle it better, but you still will have problems, especially on the older units from Norway.
(I seem to remember some control over phasing in the LX-1 setup, too. but this might be more applicable to a video input rather than a digital one.)
Jun 05, 2008 | InFocus Proxima UltraLight LX1 Multimedia...
Open Questions:
122 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
