Question about Jabra BT350 Bluetooth Headset Headset
I want to pair my NOKIA N97 with Jabra BT350
Chau_anil@hotmail.com
    President:
  • 1,118 Answers
Turn your headset off. Then, press and hold the answer/end button until the indicator light is solid lit in blue. It is in paring mode. Now, make your phone's bluetooth application search for new devices. After a while, the BT-350 should appear on-screen. Select it and make the application proceed. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing proces is successful, the headset should enter stand-by mode. The pairing process is timed.If you fail to complete it, you'll have to start it over, from the phone turned off phase. Once paired, whenever both your headset and your phone's bluetooth radios are turned on, they should connect to each other automatically. Otherwise, just press the answer/end button, and the link should be done again.
Hope you are able to sort your problems out.
Cheers! Carlos
Posted on May 19, 2010
Can you pair the Jabra BT350 with an iPod Touch v3?
how can i connect jabra bt350 to my ipod touch 2g 3.1.3
Jun 22, 2010 | Jabra BT350 Bluetooth Headset Headset
I do not have my manual to sync my bt350 with my new phone how do I do this?
Before you use your Jabra BT350, you need to pair it with your mobile
phone.
1. Put the headset in pairing mode
• Make sure the headset is off.
• Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT350
Follow your phone’s instruction guide. This usually involves going to a
‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the
option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a
typical mobile phone in fig. 5)
3. Your phone will find the Jabra BT350
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’
or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4
zeros).
or go here http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
hope this helps
Jan 30, 2010 | Jabra BT350 Bluetooth Headset Headset
My jabra BT350
trying to pair my jabra to my lg vx8350 phone
Oct 06, 2009 | Jabra BT350 Bluetooth Headset Headset
I cant pair my jabra bt125 with my nokia n97
This is one of the mistake commonly done by many people. First you need to pair. Let me walk you through. First, the headset has to be switched to pairing mode which is done by holding the on button for a while even after the headset is switched on. Then the bluetooth headset light will remain on. You switch on the phone bluetooth, search new device. Then select it and press the option for pairing. Read the instructions which come on the phone display and select accordingly. It will ask for passcode which is usually four zeros. Then it will get paired ask you whether to connect. You select connect and you are done.
Sep 02, 2009 | Jabra BT125 Headset
It's connected fine, now it won't connect, what's up? Jabra BT350
Delete the problem unit off the phone's list then turn the phone off then back on. Next you will have to go through the pairing procedure for the headset again.
Mar 24, 2009 | Jabra BT350 Bluetooth Headset Headset
Jabra BT350 stopped connecting
BR, I had the same problem with my BT350 and my Razr V3c. I was finally able to resolve the problem by doing the following:
- delete BT350 from device list on Razr
- start Razr looking for device
- put BT350 in pairing mode while phone searching (hold answer button till solid blue light)
- phone will detect BT350 and retrieve name
- select Jabra BT350
- say 'yes' to bond with Jabra BT350
- enter passkey - 0000
- phone will connect with Jabra BT350
May 14, 2008 | Jabra BT350 Bluetooth Headset Headset
BT350
try turning bluetooth off . first erase bluetooth connections on phone. turn off phone and take out phone's battery for ten seconds. put battery back in and turn on phone. plug bluetooth into charger for ten seconds and unplug it. try re-pairing bluetooth with phone. This worked for me!
Mar 06, 2008 | Jabra BT350 Wireless Headset
Connection prob
Brand New Jabra -BT350 won't work on my Nokia 6102i, I did everything in term of setting my phone properly to paired with the Bluetooth, My Phone Bluetooth light is on, and the device blue light is flashing as well, but it still doesn't work. the phone would ring, I hit the JABRA button to answer it.....still can't answer my phone... Please send your help to me at jjkernaud@hotmail.com
thank you all.
Nov 08, 2007 | Jabra BT350 Bluetooth Headset Headset
I couldn't get it to pair this morning
From the manual )link below),,,, 1. Put the headset in pairing mode ? Make sure the headset is off. ? Press and hold the answer/end button until a solid blue light comes on. 2. Set your Bluetooth phone to ?discover? the Jabra BT350 Follow your phone?s instruction guide. This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menu on your phone and selecting the option to ?discover? or ?add? a Bluetooth device.* (See example from a typical mobile phone in fig. 5) 3. Your phone will find the Jabra BT350 Your phone then asks if you want to pair with it. Accept by pressing ?Yes? or ?OK? on the phone and confirm with the passkey or PIN = 0000 (4 zeros). http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
Jul 28, 2007 | Jabra BT350 Bluetooth Headset Headset
Jabra BT350 Bluetooth Headset Headset Logo
106 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
