Question about Panasonic 15.6v Ni-mh Cordless Drill - Ey6432gqkw
How can the Panasonic drill Ni-mh battery be rated at 15.6V? It contains 12 cells. Isn't all Ni-mh cells rated at 1.2V? Are there 1.3V cells available? Where can I purchase cells to rebuild my battery?
    Habit-Forming:
  • 57 Answers
13*1,2v=15,6 v. There may even be cells located inside the part of the battery pack that is protruding inside the stem of the drill. Could this be the case here? Battery cells can easily be found on Ebay, although good quality cell are quite expensive. You can also try your local hobby/model-plane-car-boat dealer, which usually have a good stock of battery cells. Make sure it is the type with soldering lugs, and that they match you charger. I.e Nicad vs NiMh vs li-ion and so on
Posted on Nov 29, 2010
Is the Dewalt DE9108 battery charger suitable for charging Ni-Mh batteries?
  • For Battery Type: Ni-Cd Ni-MH
  • Input Voltage: 110V-240V
  • Smart Charger for Dewalt 7.2V ~ 18V Ni-Cd Ni-Mh Li-ion Battery
  • For Brand: DEWALT
  • Color: Black
  • Brand New: A brand-new, unused, unopened, undamaged item in its original packaging
May 04, 2015 | Dewalt Drills
Which battery cell is better for ntl cordless vs2000?
Please replace with same rating/type as given on cell that is normally NI MH, Rating current rating - 600ma, 900ma, higher ma means lasts longer after charge. Brand- panasonic, sanyo, any standard brand, initially charge for 10 to 12 hours. Pl do not keep hand set always on dock, this overcharges the battery, shortening cell life.
Jan 07, 2015 | NTL VS2000 Cordless Phone
How to CHARGE CORDLESS DRILL
First, you should know your battery is a Ni-CD / NI-Mh or Li-ion battery. If it is a Ni-CD / NI-Mh battery, please fully discharged and fully charged it to prevent "Memory effect".
If it is a Li-ion battery, please charge it before you use it.
Please keep in mind that, please fully charge a battery when you store it. And, charge it again every two months.
If your old battery is dead, you can replace it with a new one. Ryobi Power Tool Battery
Oct 05, 2014 | Drills
How to change a keyless chuck dw958
DEWALT DW958 Power Tool Battery Replacement
  • Type: Ni-MH
  • Volt: 18V
  • Capacity: 3000mAh
  • Color: Black
  • Weight: 1160g
  • Dimension: 136.80x85.43x113.00mm
http://www.drill-battery.com.au/buybatteries.php/dewalt_DW958_power+tool+battery.html
  • Type: Ni-MH
  • Volt: 18V
  • Capacity: 3000mAh
  • Color: Black
  • Weight: 1160g
May 05, 2014 | Dewalt 18 Volt Compact Drill Kit
Can you use 18v lithium battery in old 18v drill
Yes you can. On tools, 18 volts is 18 volts. Tools don't 'know' how the power is being created, either by Ni-Cad or Li-Ion means. Chargers are totally different. Most Li-Ion chargers can charge older Ni-Cad and some Ni-MH batteries but older Ni-Cad chargers will charge Li-Ion battery untill they overheat and sometimes start on fire because older chargers can't detect when the Li-Ion batteries are full.
Jan 14, 2013 | Black & Decker 18V Cordless Drill/Driver
What kind of batteries do I need? can I use duracel Ni-MH rechargables?
The operating manual specifies to use only Ni-MH AAA batteries and warns to not use Alkaline/Manganese/Ni-Cd batteries. Panasonic web site lists replacement batteries at 19.95 for a pair.
Duracel Ni-MH AAA batteries will be fine.
Dec 10, 2010 | Panasonic (KX-TG1032S) Phone
Camera indicates low battery even for fully charged battery.
I have connected my PowerShot A2000IS that was doing the same thing for me and I discovered the following:
1) The unit works fine even down to 2.5V providing the supply source (i.e. batteries can deliver 500 mA for a short burst during startup, i.e. when the camera's lens is extended). The camera draws 300mA with screen on after the initial startup current has settled. This means that the camera may not work with batteries like normal alkaline as these don't normally supply large currents, like NI-MH and NI-Cd can.
2) I found that if I lowered the voltage down to (using my bench power supply) that the low power indicator come on at just under 2.5 Vs, BUT once it has indicated low battery, turning the voltage back up to 3V didn't remove the low battery indication.
3) Finally I connected my fully charged (with combined voltage of 2.7V) Ni-Mh rechargeables (old and well used) using wires to allow me to measure their voltage and I found that when I turned on the camera the voltage dipped to 2.3V, but come up after the lens was deployed.
Conclusion and recommendations:
a) Get some new high quality Ni-Mh cells.
b) Don't use Alkaline cells (even Duracell brand might not handle it).
c) Forget Ni-Cd as terminal voltage would be at best 2.6V which doesn
Oct 03, 2010 | Canon Powershot A2000 IS Digital Camera
Switch and bateries
Makita makes two 12V Ni-Cad pod batteries: Battery 1222/2.0Ah (PN: 192598-2) and Battery 1220/1.3Ah (PN: 192681-5). Makita's universal charger (PN: DC1804) will charge any Ni-MH or Ni-Cad pod or stick battery from 7.2V to 18V.
Aug 18, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
Camera will not work after Ni-MH and Ni-Cd batteries used
Its not good for the batteries to combine different types but it shouldn't have affected the camera as the voltage they produce is the same. Try a couple of Eveready AA lithium batteries.
Feb 10, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
What is the wright technique in Charging NiMH AAA and AA Cells?
Should work. As long as the voltage is correct the components of the charger should work. Depending on the type of "end of charge", i.e., time, voltage drop, temperature, it may take longer to charge with lower power ratings.
Aug 27, 2008 | Panasonic CR2016 Lithium Coin Battery
Panasonic 15.6v Ni-mh Cordless Drill - Ey6432gqkw Logo
175 people viewed this question
Top Panasonic Drills Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Joseph A Howard
Level 1 Expert
Are you a Panasonic Drill Expert? Answer questions, earn points and help others
