Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Can I use a converter box to get local stations with Sony Model KV-34HS420. Serial number 9033706.
  • Sony Master
  • 6,993 Answers
converter box varies, so I wouldn't know precisely the type of converter box you are using. But here is the tip, if your converter box has "RF IN", then it means you can use it for local stations, but if it does not have "RF IN", it means you cannot use it to get local stations.
Therefore, check the back of your converter box for "RF". If you find RF, you can use it to get local stations, if you don't get RF, you cannot use it for local stations.
RF is mainly used for local stations.
Good luck.
Posted on May 15, 2010
Sony kv-34hs420
How many times do this light flashes. Count it. These blinks are fault indications. From these number of blinks, you can get an idea about the faulty circuit section inside. It will make troubleshooting more narrower. If you wish to get more details about the blinking codes to Sony TVs, check this link. Pull up older posts there.
Mar 08, 2013 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Can not tune tv since change over
The KV-32FS100 only has an analog tuner (NTSC). Unless there is a low-power analog station still broadcasting in your area, you will not be able to watch OTA stations. (I've got one in my area that barely comes in.) If your local cable still sends an analog signal, you won't need a set top box to watch that subscribed service.
Otherwise, you need a set top box to watch TV. A digital to analog converter (the boxes that were available with the government coupon before the switch over) will give you over the air stations. The basic models only provide SD output; there are a few HD models available. Otherwise, you can use a satellite reciever, cable box (for digital cable service), or something like the Boxee or Sling with tuner. (There are a few different models of the Boxee; one added a tuner with a USB dongle. The newest model of the Boxee has the ATSC tuner built in.)
Note: OTA digital signal quality is either a strong enough signal for the tuner or no signal will be present. You need to point the antenna in the correct direction to receive the signal from your local transmitters. The type of antenna and its placement will also change the number of watchable channels. You can use antennaweb.org or tvfool.com to get more information. Antennaweb assumes an outdoor antenna but gives a conservative list of stations. If the signal is split to several devices, you may need an amplifier to get a watchable signal. (Sometimes amplifiers fail and you won't receive any stations, so test without the splitter or amplifier by using a direct cable to one TV.)
I hope this helps.
Oct 26, 2012 | Sony FD Trinitron WEGA KV-32FS100 32" TV
SONY TV. STANBY TIMER FLASHING
Hi Frank,
Please let me know if it has a pattern of blinks (separated by a pause) or it will flash an exact number of times. Your unit (KV-34HS420) has a built in self diagnostic software that will indicate the probable caused of the fault by flashing of the LED at the front panel.
Jdvillanueva
Nov 30, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Stand by
I have the indentical tv and problem. Cost to repair was about 250.
Aug 19, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I am now on dish network but i want to cancel them now i will need a box to recieve local stations off an antena.can you help me please.
Hi pattinick, I was going over your post and see where you're not ableto receive your locals with DISH Network. I would like to view the account tomake sure you are able to get locals in your area; I will need to look at thenotes and equipment on the account. If you can please e-mail me Michael.houston@dishnetwork.comand I will be able to assist you further in getting your locals.
Feb 04, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Do i need digital converter box for my KV-32FS120 Sony Wega made in 2005?
You will need a digital receiver box to have digital on this television.
Feb 01, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Two color variant spots in the middle of my Sony KV-34HS420 34 in
your tv needs to be degaused or demagnetised.it cant be a bad picture tube unless it was dropped.
you can call a local shop to degause it in your home.rather easy and inexpensive to fix.
Sep 24, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Can we get local channels if we can't find the anttena?
if you dont have cable,or sattelite you need a converter box because all stations switched to all digita signal on june 21 you can get on at wallmart
Jul 27, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I was able to program my Comcast remote to control the volume of my tv, but was unable to get it to change channels. Is there something else that I should do?
Controlling the TV power and volume is probably all you'll be able to do with that control. The Comcast remotes are meant to be used with their converter boxes, and normally people want to change channels on the box while the TV stays on the box output channel (usually 3, sometimes 4). The remote's channel up and down buttons and number keypad only send out the codes recognized by the converter box. You'll need to fall back to the TV remote if you want to control more than power and volume.
May 04, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
55 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
