Question about Frigidaire GLER341A Electric Dryer
How does the top come off. snap off?? - Frigidaire GLER341A Electric Dryer
  • Frigidaire Master
  • 4,655 Answers
Unplug, take a butter knife and under the front right and left corners of the top pry it up. Then pull away from wall enough that you can lean top against wall and it will not fall down on your hands. They work like spring clips when pushed inside slot they lock but just enough pressure up on corrners wil release them, Sea Beeze
Posted on May 15, 2010
  • 494 Answers
After you've unplugged the power cord, pull up on the top a little and look for 2 metal snaps under the top lip approx 6" from the front corners. Use a standard flat screwdriver to push against the snaps and release the top from the unit. Watch out, the front will come forward and the drum may fall out of place, so have an extra hand there when you do it. Good luck.
Lost instructions for Snap card game.
Snap is an easy-to-learn card game for two or more players. Players must race to be the first to yell "Snap!" after noticing a match on the table. If you are the first player to yell then you win more cards to add to your pile. The first player to collect the entire deck is deemed the winner.
Setup
Shuffle a standard deck of 52 playing cards then deal them one by one to each player. It does not matter if some players start with more cards than others. Each player should keep their cards face down in front of them.
Gameplay
Starting with the player to the left of the dealer, each player flips the top card from their pile and starts a second, face-up pile next to their face-down pile. This process continues one by one for each player going around the table clockwise.
Snap
All players race to yell "Snap!" when any player turns up a card that matches a card that is already face up on another player's pile. The first person to yell "Snap!" gets to add the two piles under the matching cards (including the matching cards) to the bottom of her face-down pile.
Snap Pot
If multiple players yell "Snap!" at the same time, the two matching piles are combined and put face-up in the center of the table creating a "Snap Pot" and play continues as normal. If a card matching the top card of the snap pot is played then players must race to yell "Snap Pot!" The first to yell "Snap Pot!" gets to add the snap pot and the matching pile to the bottom of their face-down pile.
False Snap
If a player ever yells "Snap!" or "Snap Pot!" when no matches are played that person must give their top card to the last person to play a card.
Objective
The player to collect all of the cards is the winner.
Jul 20, 2011 | Cycling
How do you install part# 8193768 spinner for kenmore dishwasher model#66517364300?
You should have 3 parts. The spinner, a cone shaped insert and the snap pin. The cone shape insert is the first part to install. Look at the upper spray feed tube in the top of the dishwasher where the old part used to be. Place the cone shaped insert on top of the spray tube through the hole with the flat part on top. Now take the spinner and snap it into the cone shaped insert from the bottom of the hole. Be sure that the swirling vanes are facing upwards. It should snap in. With the snap pin, push it into the insert underneath the spinner. This is what holds the spinner to the insert. Good luck.
Jun 20, 2011 | Dishwashers
No suction on my Pro heat steamer
You may want to check to see if the removable nozzle is correctly placed into its place. This is the plastic part where the water is sucked up through by the carpet cleaner. The nozzle notches must fit into the groove on the cleaner correctly and the metal bar need to snap back on top of the removable nozzle, Also sometimes if you have hair trapped in the nozzle or the bristle, it will affect the suction power of getting up the dirty water. The dirty water tank need to snap in place by making sure the top of the gray snaps on each side is over the top groove of the dirty tank on each side and the the gray snaps are pushed down and pushed into the tank to until it is snapped in place.
Super Simple answer could be: The Dirty water tank could have bubbles in it causing it not to **** too.
Mar 03, 2011 | Bissell Carpet Cleaner Powerbrush Deep...
Snapped timing belt on 1.8t audi tt engine. Belt snapped not possible to mark bottom pully. help
just fixed my Audi TT ... timing belt snapped so the head had to come off to replace valves. used dial guage on top of piston !
if head is on then there is a plug you can remove that allows you to see top dead center..
Jul 14, 2008 | 2002 Audi TT
HP PhotoSmart 7550 printer - how to get the top off?
There are three special types of screws on the back of the printer. Using a TORK BIT T-10 screw driver remove the two top screws that holds the gray top on. There are several snap connections on the bottom edge of the gray case.
Jan 02, 2008 | HP PhotoSmart 7550 InkJet Printer
Ge xl44 I think pilot not lit. no more snap - snap and does not light
relace spark module if no snap snap from all burners.If one is just bad replace ignitor.
Nov 21, 2007 | Hotpoint RGB745 Gas Kitchen Range
Converting to a buggy/ user manual
Under the foot **** there is a bunch of fabric. Take that out pull it over the top of the bar and snap to the side. One the Top there is a piece that is tucked behind the back of the seat at the top. unfold that and snap each side to the side of the stroller where the sun shade is. Then snap the sun shade the outside of those snaps.
Aug 06, 2007 | Maclaren Global Buggy Atlantic Umbrella...
Frigidaire GLER341A Electric Dryer Logo
208 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
