Question about Maytag Neptune MDG5500AW Gas Dryer
Paddle came off dryer drum. How do I reattach?
Paddle came off dryer drum. How do I reattach? Can I do this from the top/front so I do not have to uninstall dryer?
  • 4 Answers
SOURCE: remove front panel of maytag MDG7400Aww gas dryer
You have to remove the front panel first to access the clip that holds the front of the top down. Instructions:
crosstip medium screwdriver
1/4 inch socket
5/15 inch socket
  1. UNPLUG DRYER
  2. TURN OFF GAS
  3. Disassemble by taking apart the FRONT of the dryer:
    a. Remove the door and opposite side door plugs (crosstip screws)
    b. Remove the front panel - this exposes sheet metal bolts (5/16 inch) some with crosstip on left and right of unit. Set panel aside (right side) WITHOUT unplugging wires
    c. Unscrew all the exposed bolts.
    d. Top bolts left and right secure the unpainted metal hooks which secures the top of dryer. Unscrew these bolts and wiggle the metal retainer hooks off. Lift top and support to create 6 inch gap in the front (top unit hinges in back and has electrical connections - do NOT disconnect wires)
    e. Release belt from pulley by reaching left and under drum (this is out of sight)
    f. gently lift out drum and belt and set aside
  4. This has exposed the interior.
Posted on Nov 01, 2008
SOURCE: Dryer Paddle Loose
Take the four screws, out of the door and remove it. The front of the dryer will fold down and lift off, you will be able to see in side the dryer. If you want to lift the top remove the screws that are now exposed. Along with the brackets the top will now lift up.
This should allow you to access the tumbler.
Posted on Dec 19, 2008
arikrom
  • 528 Answers
SOURCE: A paddle inside drum is loose, need to open top of dryer
first take the door out from the hinges then the frame around the door the you can open the top or the front of your machine...
Posted on May 02, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Dryer stopped spinning. Opened
http://www.applianceaid.com/images/belt-config.JPG
If you hear a loud bang while your dryer is working, and you notice that the
drum has stopped turning, chances are the drivebelt has snapped.
Fortunately, replacing the belt is a fairly straightforward operation that
can be handled with a few simple tools.
First, unplug the dryer. Lift the lint-screen cover and pull out the lint screen
If your dryer has a lint screen on the inside of the door, skip this step.
Then remove the two screws that are under the cover. To unlatch the dryer top,
insert a thin-blade putty knife between the top and front panel,
about 2 1/2 in. in from one corner. Push in on the knife to release the locking
clip, lift the corner, then release the clip on the other side. Swing the top
up and lean it against the wall.
Next, move to the lower toe panel. Slip the putty knife between the lower panel
and the door panel at one side and twist the knife to release the clip
Then release the opposite clip and lift the panel up and off the hinge springs.
To support the dryer drum while the belt is being replaced, place scrap wood
under the front of the drum.
Loosen the two screws at each side of the bottom of the front panel.
Move to the top of the panel and remove the screws from the inside of the
cabinet that hold the front panel to the sides.
Slide the old belt off the drum.
Installing the belt
Lean the front panel out slightly and allow the drum to rest on the scrap wood
support. Drop the new dryer belt between the front panel and the drum, and
loop it over the drum. Then, lift the drum slightly while pushing the front
panel back into position.
Replace the screws at the top inside of the front panel, tighten the lower panel
screws and remove the scrap wood from under the drum. Check to make sure that
the rear drum seal fits properly over the lip on the rear bulkhead.
Position the new belt where the old belt was, with the grooved side of the belt
facing down.
Now, move to the motor area and pull out the old belt. To route the new belt
around the idler and drive pulley, first pass the entire belt, doubled up,
under the idler pulley. Then, push the idler belt toward the motor, slip the
belt around the motor pulley and release the tension on the idler pulley.
Open the dryer door and rotate the drum counterclockwise a few times to make
sure the belt is tracking properly. Lower the top and press down at each
corner to engage the clips. Lift the lint-screen cover, replace the two screws
and reinstall the lint screen. Finally, secure the lower front panel and turn
on the dryer for a test.
This is a FREE answer
Please RATE me
Posted on Dec 27, 2010
  • 2468 Answers
SOURCE: paddle came off inside dryer drum I need to open
remove 4 screws around the door perimeter,remove door,then the front panel will pull off towards you then remove 2 hex headed screws just under where the top and front covers meet,then you can raise the top to replace baffle/paddle screws
Posted on Mar 06, 2011
Paddle came off inside dryer drum I need to open the top so I can put more screws in
Mar 06, 2011 | Maytag Neptune MDE5500AY Electric Dryer
How to repair paddle inside drum paddle that fell off
To replace this "paddle" (It's callde a baffle), you'll need to access the outside of the tumbler (drum), by lifting the top.
Begin by removing the door. Remove the two hinge screws. You will then be able to rock the door and hinge out of the slot in the front panel. Next, remove the cover plates just opposite the hinges.
Now you can pull the front panel off the retaining clips and rock it downward, away from the rest of the cabinet. Once it clears the top, you can lift it off the bottom hooks. Just set it aside.
You will now see two screws (hex-head, 5/16 inch), just under the corners of the dryer top. Remove them and rotate the brackets that hook into the top. Removing the brackets will allow you to now swing the top upwards to expose the tumbler.
Just turn the tumbler until you can see the screw holes for the babble holding screws. You may get lucky and find the three baffle screws in the bottom of the cabinet. Re-install, check the others, and re-assemble the dryer in reverse order, and you're done!
Dec 27, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
I HAVE A MAYTAG NEPTUNE GAS DRYER MODEL 3MDE3000AYE. ONE OF THE THREE PADDLES INSIDE THE DRUM CAME OFF. I AM TRYING TO REATTACH IT TO THE DRUM, BUT THE SCREWS HOLDING THE PADDLE ARE INSIDE THE DRUM.
unplug the dryer,open the door,remove the two screws holding the door on and remove the other two screws opposite them,take off the door and pull the front panel off,spin the drum until the baffle you are trying to repair is in the bottom right hand corner and you can get at it like that
Mar 13, 2010 | Dryers
Loose paddle
Pop the top ... remove the front ... carefully remove the belt ... take the drumout - you are correct, the paddles are held onwith screws - tighten them.
reassemble
Oct 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
One of the paddles came off inside the dryer
Remove the top and front of the machine. (Look for up to two screws them pop the top.) Remove the drum (be careful of the belt) Reattach the paddle - it should be self evident once you have the drum out. You might need to add a screw of two. While it is apart, Id be changing the belt.
Reassemble
Your wife will love you forever.
Simple.
Oct 09, 2009 | Dryers
Two of the paddles came off in my Kenmore dryer. How do I reinstall them?
remove front cover then remove top cover you can then access the outer surface of drum to reinstall paddles
Sep 28, 2009 | Dryers
One of the paddles inside the dryer has come loose, how can I fix this?
remove door screws and screws on opposite side. pull front forward and down. remove two brackets at top corners to raise top (unplug machine of course). screws are on outside of drum.
Jun 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore Elite Dryer with loose paddle- can I glue?
Unplug the dryer.
Remove the lint filter.
Remove the screws at the lint filter opening.
Pop the lid clips on the left and right front corners of the cabinet.
Rotate the drum counterclockwise until a tumble vane(paddle) is at the 12 o'clock position.
Tighten the screws going through the drum.
Repeat this for the other 2 vanes.
Re-assemble the dryer.
May 10, 2009 | Whirlpool LEB6300 Electric Dryer
My kenmore series dryer is making noise as it runs. It heats but makes a noise as if coins are in the dryer. I cannot see anything from inside the dryer, is there a way to remove the front face of the...
there's 2 basic ways to removing the front panel. First is 2 screws at the very bottom of the front panel, when removed the panel can be lifted and un-hinged from the top. The other is by using a flat screw driver and prying the top up at the edges on the front side the removing 2 screws or hex screws located inside the front panel toward the top. make sure you undo door swich wires before completely removing the front panel. then in the middle of the drum on the inside of it either 1-3 screws hold the drum to the back. Remove belt first then screws then pull drum straight out. The noise may be from your rear drum bearing or coins have gotten in the paddles of the drum(inside) paddles can be removed. I had coins in one of my paddles, made 60some cents lol at same time found perfctly round lint balls. Good Luck
Mar 02, 2009 | Kenmore 63942 Dryer
Dryer Paddle Loose
Dec 10, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
22 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
