Question about Mtd Products Yard Machines 158CC Tiller
Starts but doesn't stay running
I prime my yard machine tiller, it will start and run for approx. 5 sec., then stall out, won't stay running, but will start if I prime again
    Guru:
  • 51 Answers
I would say faulty gas .. I had same issue with a push mower and found that water had gotten in the tank some how.. same symptoms..
Posted on Aug 08, 2012
    Top Expert:
  • Mtd Master
  • 13,652 Answers
Carb needs cleaning and also replace air filter
Posted on May 15, 2010
Yard Machine 5.5 hp tiller it won't stay running unless I manually hold the governor part in the right spot until it stays running but the second and let go it dies or I prime it to keep going
Carburetor is not supplying fuel to the engine correctly. There probably is a foreign object partially plugging the metering jet inside the carburetor.
Mar 09, 2016 | Garden
Why won't my brand new tiller stay running? Starts, runs a few seconds, then stalls.
sounds like its flooding
the float needs adjustment or seat needs cleaning or replace
May 31, 2014 | Mtd Products Yard Machines 158CC Tiller
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
I cannot remember how to start my tiller
This Could be a problem? Turn the fuel on, place throttle lever to choke, prime if available and pull cord. when running move throttle to run. Good Luck, your gonna need some!!!!
Apr 20, 2011 | Mtd Products Yard Machines 158CC Tiller
Yard Machines rototiller front tine- having problems starting
Sounds like you are either losing your "prime" or your carb needs either, cleaning, rebuilding with a kit. Probably a cleaning will do it. Watch U Tube there are wonderful people who film the whole process from tear down, to replacement. Com'on! Get into it its easy and it don't take long. Then you'll always know how to do it!
May 04, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Mtd yard machine snowthrower not starting, doesn't sound even like it is firing, new gas, new plug, oil is full, emptied gas tank and ran dry before storing last year, blizzard tonight, help!
First spray a prime down the throat of the carb with the choke in the run position and attempt to start. If the motor hits and runs for a second then its a fuel related issue and you will need to remove and clean the carb. If it wont run or try to run on a prime then it may be an ignition issue. check for spark. If no spark then remove the ground wire from the module and check for spark again. If still no spark suspect the module, if spark with ground wire removed then wiring or switch is the culprit.
And make sure you dont over look little things like... does it have a fuel shut off valve and is it open? Is there a safety key and is it in -place? etc.
Dec 09, 2009 | Mtd Products Yard Machines 158CC Tiller
Won;t start
I got a new air filter for mine today, plus cleaned out the metal fuel canister under the carburator and the little brass bolt and my mower started right up. I was having hte same problems getting my mower to run and stay running. Glad I checked this site!
Sep 09, 2009 | Mtd 22" Yard Machine Push Mower
Tiller won't stay running
If you choke or prime the engine, it starts up for a second or two and dies, the carburetor need to be cleaned/repaired.
May 25, 2009 | Mtd Products Yard Machines 158CC Tiller
Mtd Products  Yard Machines  158CC Tiller Logo
732 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
