Question about Linksys Wireless-N WRT150N Router
I can not change router ip
I can not chagne my router (WRT150n) ip address; i wonder why i need to change it when i want to connect it to DSL modem?
  • 71 Answers
You need to change the router's IP to avoid conflict with the modem's IP address. You just need to access the router's setup page , default is 192.168.1.1. Default username should be left blank and default password is admin. Once logged in , first page you will see is the Basic Setup page. Just look on themiddle part of this page and there you will see the IP address of the router. Most of the time, if the user has DSL connection , Linksys' IP should be changed to 192.168.2.1. Dont forget to click on Save Settings at the bottom of the page. It will then say Settings are successful. Now click on continue. You can then power off then power back on the router for the changes to apply
Posted on Jun 14, 2010
Talk talk, technical assistance
How did you connect the computer to the router. If you are using a DSL modem it will have a DHCP server in it that is allocating IP addresses across your network. If you added the router to the computer via a hub or network switch what is the computers ip .
address. Remove the WI FI router - turn off P.C and then Go to cmd or dos prompt if windows based system and type in ipconfig and press enter to see if ip addresses are 10.0.0.2 if they are your dlink router uses 192.168.0.1 so you need to make the dlink router ip addressand subnet setting to match the Modem ip addresses of the DHCP server. Change the ip address of the dlink router to be 10.0.0.2 and change the modem to allocate DHCP IP addresses from 10.0.0.10 to 10.0.0.255. Only do this if IP addresses are 10,0,0,1 to 10.0.0.,254 on the desktop p.c with the dsl or cable modem connected.without the router being involved. (you may need to ask the ISP what the user name and password is of the modem and it should be ip address xx.xx.xx.1 so type this into a browser to change the modem settings. 10.0.0.1 or 192.168.0.1 just remember if the modem is 192.168.0.1 so is the Wi router from d-link and you will have an ip clash problem)
. How do you do this by ethernet connection from only the desktop directly with only the Wi FI . router. Go to a internet browser and type in the URL 192.168.0.1 and then change the router ip address to match what the DSL modem DHCP issues..
Page 14 of Router instructions see http://files.dlink.com.au/Products/DIR-615/Manuals/DIR-615_C2_Manual_v3.10.pdf
in the manual it states to use a direct ethernet connection for the setup program but you need to be connected to the internet for it to work but if the IP addresses are wrong or clashing will have no internet. You also want to set the modem as the DCHP server and disable the DHCP server in the set up of the wi fi tand set the WI FI router default gateway as the ip address of the Modem. if any DHCP server options in the WI FI router sert to the modem ip address. .
Sep 08, 2014 | D-Link D Link Dir 615 Wireless Router...
Linksys wireless N WRT150N Router showing limited or not connectivity
Hi.
If you have a cable modem or DSL modem, try to unplug power on it and your router too. Then plug the power back to the modem and wait until you see almost all the lights on. If your unsure just wait about 1 min and it should be ok. Next plug power back to your router. This will create an new IP address which could resolve your problem.
Feb 08, 2011 | Linksys Wireless-N WRT150N Router
How to hook up the Linksys Wireless-N WRT150N Router to DSL?
Connect the dsl modem to port on the router that says Internet
connect 1 pc to any available port on the router(1,2,3,4).
Open your browser and type 192.168.1.1 in the address bar
It will prompt for a username/password window. leave username blank,password admin. Press enter
Normally if you have dsl, you need to set the internet connection type to pppoe and put in your username and password that your ISP provided you. then save the settings.
Oct 04, 2010 | Linksys Wireless-N WRT150N Router
Im trying hook up a wireless router and it ask what kind of conection I have static ip ect... How do I know what I have? Im using DSL.
Most residential subscriber services use dynamic IP addressing. Dynamic IP addressing is automatic from your Internet Service Provider (ISP). Linksys home based products such as the one you have should be setup up for this configuration out of the box by default, and require no adjustments to the IP configuration of the wireless router.
You should power down the DSL modem and Linksys, then connect them, then reapply power. This will clear the DSL modem if it was connected to another device such as a PC. This is important as most cable and DSL modems use something called MAC address binding that will only allow one device to connect to it directly at a time.
Feb 06, 2010 | Linksys Wireless-N WRT150N Router
I have Lynksys WRT150N wireless home router i want to connect it with 512Kpp dsl modem . i tried to setup from CD but i'm getting message ( the router is not able to connect to internet.Try to switch DSL...
connect it by the LAN cable and then it should come with a default IP address found on the box or the bottom of the the wifi router enter that in your address bar and you will need to type a username and password that is also found on the box of the wifi router then you can then configure it from there. good luck
Oct 10, 2009 | Linksys WRT150N Wireless N Router -...
I am installing my new wrt150n router and no internet
Turn off modem and router. Connect router to computer. Turn router on. Connect router to modem. Power up modem. When it discovers the modem it will assign to it the new IP address.
Hope it helps.
Sep 25, 2009 | Linksys Wireless-N WRT150N Router
Change ip
Your IP address is assigned (leased) to you from your internet service provider. With that being said, you could possibly call them and ask to release your old IP address and have them assign a new one. If you happen to have a static IP address assigned from your ISP you can call them as well and ask to have your IP address changed too. It would be up to them to change it though.
Sep 14, 2008 | 2wire (1000-400108-001) Router
Installed WRT54G2 With ATT Motorola DSL and cannect to internet. dsl worked fine before installing the Modem had AT&T recheck the dsl and was configeration correct was advised that my problem in...
hi there ...
your isp is at&t? please verify the ip address straight to the modem if its is 192.168.1.1 and if your modem from your isp is set to DHCP or BRIDGE mode.
IF IP address is 192.168.1.1 (DHCP)
... change the LAN IP address of the router to 192.168.2.1 or 5.1 to prevent any IP conflict
by doing this :
1. access setup page of router usually 192.168.1.1
2. under setup tab look for the ip address, change it, then save
3. click on the status tab , and look for a VALID ip address
IF MODEM is set to BRIDGE mode
.... please ask username and password from your ISP coz we would need to set your router to PPOE...
2. under setup tab look for INTERNET CONNECTION TYPE
3. select PPPoE
fill in username and password
select "keep"alive
save
4. click on status tab
look for LOG in TYPe ===> click CONNECT
if connected : check a valid IP address
if authentication failed verify again your username and password from your ISP
Aug 07, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Setting up a wireless router
first you have to check the ip address of the dsl modem you used and see to it that it is not the same ip address of the router to avoid conflict. the default ip address of dlink router is 192.168.0.1.if in case your dsl modem has the same ip address with the router, you have to change firs the ip address of the router before connecting the router to your dsl modem.
next you need to know your internet connection whether it is DYNAMIC or PPPOE, depending on how your internet provider configured your modem. for PPPOE connection, you have to know the USERNAME and PASSWORD that your provider provides you.
good luck.
carlmali007@yahoo.com
Nov 30, 2007 | D-Link DI-624M Router (DI624MRE)
Linksys Wireless-N WRT150N Router Logo
123 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
