Question about Whirlpool LSN1000LW Top Load Washer
Machine not spinning. im not sure how to take the old belt off,the motor is good.
  • 4,066 Answers
Based on this diagram of your model you don't have a belt. You have a motor coupling instead. It's part 13 on the diagram. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=504857&diagram_id=132297#d132297
Posted on May 15, 2010
Maytag washer (about 15 years old, 2 speed) starts to spin and then stops. Hot smell but the motor is fine. Is there a fuse it is tripping? Some other problem?
the belt or clutch slipping most likely if it has no belt send it to junk donate it whatever if it has a belt check it make sure no lube or water is leaking onto it make sure tensioner is keeping it snug if its just the belt change it don't use a car belt the 1 u need is called a fractional horsepower belt like a evaporative cooler belt that's an old machine too bad u don't live near me i got a good 1 for $80 bucks u can pick them up cheap in the classifieds
Apr 21, 2012 | Maytag Washing Machines
Clothes do not spin as much as they used to when i use the gentle cycle It seems to spin much more effectively on the main wash cycle but I do not use this cycle much.This machine is 20yrs. and has given...
If your washer is a front loader it MIGHT be that the belt is slipping, although I would expect it to slip more on the main wash spin cycle than the gentle spin cycle! Sorry to ask but are you sure that it doesn't spin as much on gentle as it used to?
Just in case it is a belt problem, here are my guidance notes on having it changed ;-0)
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If it turns out to be the motor, it is false economy to just have the brushes changed. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished.
Hope this is your problem solved.
Good luck,
John C
Mar 04, 2011 | Washing Machines
The drum wont rotate, is it belt driven from the motor, if so how do you get in to change? cant get lid off
take the back panel off to get to ure belt, but first put ure hand inside ure machine n spin the drum if there is no strain wen tryin t spin the drum n the drum feels very light to spin ure belt has snapped if there is abit of strain u will need ure motor brushes changing
Feb 03, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Old Washer won't spin or agitate
You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
Feb 15, 2009 | Whirlpool Washing Machines
Doesnot spin or agitate.
if you have the front panel off and you can see the motor is spinning the belt is turning then your transmission has failed.waring keep hands clear of all moving parts! transmission pn wh38x10002 for around $185 if mtr is not moving pn wh49x10040 for about $240 depending on what you need and how old your washer is it might be time for a new one
Dec 13, 2008 | Washing Machines
How to replace the belt on a Samsung J845 frnt loader washing machine
If you stand in FRONT of the washer, leaning over the top, the drive wheel is underneath the main drive motor, on the RIGHT hand side.  Loop the belt over the drive motor wheel, then over the main pully, and it should be good to go!
May 20, 2008 | Samsung WF337AA Front Load Washer
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
Error F 04
im not up to speed with the codes. BUT if you are able to open the door this suggests the bulk of the water has pumped away, so I suspect motor or belt problems. Can you hear the motor spinning when it should be? ie on spin cycle. If not suspect carbon brushes in motor, or even a broken/burned out wire to motor. Replace belt if broken
Oct 15, 2007 | Hotpoint Aquarius WD640 Front Load...
Wash but no spin
1st of all is there a spin cancel buuton on this machine and has it been activated, or is there a spin speed selector knob and has it been turned down...is inner drum easily turned by hand.if it is ok then belt tension could be suspect (tighten)im sure there is an out of load balance detection circuit on the main circuit board....also is it draining ok because it wont spin until it cant dectect low or no water prior to final spin.....also if it has a programme dial the select a spin programme on another section of selector dial.........hope this is of some help...
May 08, 2007 | Zanussi F1045W Front Load Washer
GE washer spins slowly -Clothes still wet
Doesnt make any sense why the motor goes off and on. If I read your email correctly. some typos on your email. but, sounds like the belt is too big. Or the spring device that keeps the belt tight is not working properly. You need to make sure what ever it is that keeps that belt tight is working properly or not damaged. The belt is very important to making the spin work good. Match it up with your old belt. The old belt will be slightly longer because of being stretched over a period of time. Get your unit number and model number and go to your nearest dealer and get the correct belt.
Sep 18, 2006 | GE WSXH208A Front Load Washer
Whirlpool LSN1000LW Top Load Washer Logo
48 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
