Question about Lexmark X5150 All-In-One InkJet Printer
Lexmark5150 error comes up stating "close cover" !!!
  • frogs Mar 30, 2008
    my lexmark 5150 issues a message that states "close cover, cover open". I have removed it, and re-installed several times, I think that it may have a faulty microswitch on the cover loser section.
  • 23 Answers
Yes the hardwar is defective. call Lexmark tech support & get a 20% discount to buy a new printer
Posted on Jun 20, 2008
SOURCE:
Why won't it print?
need more info. is it hooked up usb or parallel? Are you printing from windows or like an AS400 or OS X. What error is the alarm light blinking or just stays on?.
Dec 16, 2015 | OKI MICROLINE 320 Turbo Matrix Printer
The screen states "close cover E" It is closed but the screen keeps saying " close cover E" ?
The Exit 2 interlock switch is either broken or off it's base or defective. If you open up the top door on left side of print, there is a push button switch that mounts on the back side. If you're standing on the left side of printer it's located on the top left. Make sure it's mounted properly and try to push the button with your finger and see if error goes away, if not replace switch, part number 110E11580.
http://www.iteminconline.com/110e11580_xerox-5500-door-b-interlock-switch.htm
Sep 23, 2015 | Xerox WorkCentre Pro 123/128 Printer
Have closed cover properly. cover vup sign still there.
Try to follow the steps below to identify and fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Open the printer cover and remove the cartridges.
  3. Close the printer cover.
  4. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  5. When the printer turns on and comes back with the error on the display screen, please contact Lexmark Technical Support Center for additional assistance. If no error appears, reinsert one cartridge first.
  6. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new cartridge.
  9. If no error appears, try to print again to verify that the problem is fixed.
Oct 12, 2011 | Lexmark X3470 All-In-One InkJet Printer
Printhead is not supported by the all in one
A firmware update for the Lexmark Prospect Pro205 will help fix the printhead issue you are experiencing. Please follow the steps below on how to successfully update your printer:
  1. Open the printer cover and remove the printhead and tanks (if installed). Note: Carrier will come to the center automatically with this error message as the cover is opened. Remove the ink tanks > open the printhead latch and remove the printhead > close the printhead latch, close the printer cover and confirm the error message goes away from the operator panel.
  2. Proceed with the firmware update. Please visit the Lexmark website to download and install the Lexmark Pro200 Series Firmware Update.
After successfully updating your printer, open the printer cover > re-insert the printhead > close the printer cover. If no printhead error comes up, continue with normal installation steps for cartridges. If error comes up again, please contact Lexmark Technical Support Center for further assistance.
Oct 06, 2011 | Lexmark Prospect Pro205 Wireless...
My printer keeps stating printer cover open when it is closed please help
Try to remove the sheets of paper from the feeder. Open the printer cover and remove your cartridges. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges. Make sure they are properly inserted and secured. Load some paper. Check for the error again.
Apr 10, 2011 | Lexmark X1270 All-In-One InkJet Printer
Since I have changed the cartridge, Whatever I try there is a message displayed :"cover open".
Hello there
Not know your printer that much but I do know with printers with this fault it is the cover sensor or the switch that is at fault try to look where the cover closes there will be some sort of plastic there that comes between the sensor or switch this may be broken or not push in far enough, it broken you can stick some thing there to make it think it closed.
All the Best Pineworks
Feb 18, 2010 | Lexmark X3470 All-In-One InkJet Printer
Trying to copy something and this error 2200 pops up and states refer to user guide
Hi
This is a scanner lock issue. You may try the following:
Power off the All-In-One (AIO) off and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Try a test scan now. If the error reoccurs, then try the below:
Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover and check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
Open the top cover of the AIO and using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
If the error still occurs, you may insert the cartridges one at a time and re-check..
hope the above info is of use to you.. try out..!!
Apr 22, 2009 | Lexmark X7170 All-In-One InkJet Printer
T640 printer put toner in the error message states please insert
Please remove the cartridge and then re-install it to make sure it is seated properly. Then close the front cover door and make sure it latches completely. Now turn the printer back on.
Mar 31, 2009 | Lexmark T640n Laser Printer
I have a Lexmark5150. My new Dell - Vista won't run. I get an error
You may need updated drivers to run with vista. You can download them from the lexmark website.
Dec 16, 2008 | Lexmark ImageQuick SIMM (15W0000) for PC,...
When attempting to print, I receive an error message which states "Inner conver is open. Close the inner cover and press OK". However, the inner cover is closed...? I have opened and closed...
Are you looking at the canon error window picture that show up on your monitor: It is the front inner flap you see after you open up the two top "covers". I forgot I opened this one looking for a paper jam. The printer cartridges would not even move to the front with this flap opened. After I closed the inner flap it all works (after opening and closing the top two "covers" many times!
Apr 16, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Lexmark X5150 All-In-One InkJet Printer Logo
122 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
