Question about Panasonic NN-S954WF Microwave Oven
Shuts off after approx 5 - 7 sec. some smoke
Shuts off after approx 5 - 7 sec. some smoke coming from vents underneath turntable area. one white conn on door switch has brown scortch mark.
  • Panasonic Master
  • 9,047 Answers
If it stops after 7 seconds, it has a problem with the inverter.
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If you prefer to replace the inverter yourself, you can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Posted on May 16, 2010
Have the same issue with a panasonic s954wfr after 8 years of use. Last year the door switch microswitch burnt out due to totally inadequate 24 gauge wiring. Early on symptom was that the turntable tray would start rotating back and forth whenever the door was opened. Finally stopped all together. Pulled the lid and the melted wiring leads on the cracked open switch was a definite clue. Replaced it with a generic and it worked great ... for 6 months. Then it started shutting down after around 10 seconds of cooking blowing smoke from the bottom vents. Didn't see the turntable rotating so I assumed the motor had burnt out. Disconnected turntable motoro and the cook cycle ran on for the full cook time. But when I put the new turntable motor in it ran for about 30 seconds and then started spewing smoke and shutting off again. I'm looking for a circuit diagram for this thing. The panasonic web site is un-navigable. Suggestions?
Posted on Jul 07, 2013
  • Stewart Champion Sep 11, 2014
    Bad news. Looks like the motor burnout fried part of the powersupply that's integral with the invert assembly. Too expensive and I don't like debugging running microwaves without shielding. Retired it for parts.
Making humming noise when plugged in. won't stop until I open the door. underneath light doesn't come on. right front corner inside of the microwave gets hot. replaced turntable motor same problem
Sounds like the vent to the outside is rattling or not secure or the door seal is not sealing properly. let us know Bruce if you need parts or anything else. thank you and leave feedback
Jul 13, 2016 | Microwave Ovens
Maytag Model MMV1153AAW vent won't turn off; we have to unplug it and plug it in to use it so the vent won't run 24/7. When we plug it back in to use it, the vent comes on within 15 seconds and might shut...
Either your thermostat or relay to the blower has faulted. Thermostat is cheap but the relay is on the control board. So either replace the thermostat P#53001373 or replace the microwave as the control board is discontinued according to the information you provided. Good Luck
Jan 02, 2015 | Maytag Microwave Ovens
Microwave starts to work then cuts out after a problem I had.
MICROWAVE RUNS ABOUT 5 SECONDS AND SHUTS OFF AND SMOKE FROM UNDERNEATH CABINET
Apr 15, 2010 | Bosch HMT9626GB Microwave Oven
Model # OGB81201 approx 1 month old. Microwave does not work turntable does not rotate, Convection and grilling apprear to work and turntable rotates when using these features. When i push the quick...
Approximately 1 month old? Should still be under warranty. Before doing anything else, contact the store where you purchased the oven and see if they'll exchange it as defective. If not, they may take the unit in for service there. Failing that, check your owner's manual to see what to do for service.
Feb 27, 2010 | Microwave Ovens
My nnsn977s shuts off 5 secs after started
This is a problem with the "magnetron". The magnetron part number for panasonic is 800-833-9626 worth 45$ approx.
Let us know if you need further assistance.
Thanks for contacting Fixya.com
Jan 14, 2010 | Panasonic NN-T964SF Microwave Oven
Microwave Smokes
the problem is in the magnetron try to replace it.
Jan 27, 2009 | GE JVM1660 Microwave Oven
Can't remove a1985 GE Microwave Mode3l jvm61001 fro0m the wall.
this microwave oven slides out of its casing. here's how: first shut the power to the unit by the breaker from your main panel. on the mw oven remove the underneath rightside vent filter. unplug the large white connector that you see in through where the filter was . Dont break it. its locked and keywayed. next remove the top front plastic horizontal louvered front vent by one phillips screw on each end of the vent left and right. then remove the next two phillips screws you see under where the vent screws were. then remove the 3 shoulder screws underneath the front edge of the case bottom then slide that piece of **** oven out of its casing. I'm sure you will know what to do next. Good luck!!
Oct 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Purchased GE Microwave, JES1142 in March, 2008. Recently I am having problems when heavy items such as cup of coffee or heavier is placed on turntable. The turntable does not turn and the light does not...
hi nurse becky,
have you put the roller that comes with it?.. normally there is this plastic frame that you place at the bottom of the microwave and it has three rollers that would your turntable motor turning even if you put heavy loads on it. if has one, kindly check each roller if they are turning smoothly.
i hope i was able to help
kindly rate me please
tnx,
drcool
Jul 19, 2008 | Microwave Ovens
Panasonic NN-T694SF smoke, shuts itself off
In most cases, this is a problem with the inverter or a bad transfotmer.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Oct 20, 2007 | Panasonic NN-T694SF Microwave Oven
Panasonic NN-S954WF Microwave Oven Logo
332 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
