Question about Baby Gear
How to remove / refit door mirror on ford focus
How do I remove & refit manual operated door mirror?
  • 50 Answers
Take the mirror pannel off the door inside undo 3 screws or bolts mirror falls off
Posted on Mar 31, 2008
Door mirror housing wobbly
open the door there is a panel remove and you will see the nuts for the mirror.
Sep 18, 2012 | 2003 Ford Focus
How to replace rear view mirror
Instructions
Disconnect your negative battery cable, if your Ford Focus has power side mirrors. If it has manual side mirrors, disconnecting the battery is unnecessary.
Pry off the wing mirror's inside sail panel (shaped like a triangle). Insert a trim panel tool between the door skin and the plastic panel to pry it off.
Carefully pull the sail panel away, minding the wiring if the mirror is power-operated. Unplug the electrical harness and set the panel aside.
Open the door and hold the outside part of the wing mirror steady. Remove the mounting bolt with a socket wrench, and then remove the mirror screw with a Phillips screwdriver (the mirror bolt and screw is visible with the panel removed).
5
Pull the wing mirror assembly from its mount (from the outside). Insert the replacement mirror assembly in place; tighten the bolt and the screw.
6
Attach the wiring connection to the replacement mirror. Position the sail panel in place and push it against the door to snap it back on.
Apr 18, 2012 | 2005 Ford Focus ZX3
Loose wing mirrow
Check this guide as reference for solve ypur problem; this is one DIY about replace Wing Mirror...
1.- Disconnect your negative battery cable, if your Ford Focus has power side mirrors. If it has manual side mirrors, disconnecting the battery is unnecessary.
2.- Pry off the wing mirror's inside sail panel (shaped like a triangle). Insert a trim panel tool between the door skin and the plastic panel to pry it off.
3.- Carefully pull the sail panel away, minding the wiring if the mirror is power-operated. Unplug the electrical harness and set the panel aside.
4.- Open the door and hold the outside part of the wing mirror steady. Remove the mounting bolt with a socket wrench, and then remove the mirror screw with a Phillips screwdriver (the mirror bolt and screw is visible with the panel removed).
5.- Pull the wing mirror assembly from its mount (from the outside). Insert the replacement mirror assembly in place; tighten the bolt and the screw.
6.- Attach the wiring connection to the replacement mirror. Position the sail panel in place and push it against the door to snap it back on.
Hope helps (remember comment and rated this). TY for using Fixya.
Jun 26, 2010 | 2000 Ford Focus
Need to change the wing mirror on my ford focus c max but dont know how
remove the plastic cover directly behind the mirror on the inside of the door, it just clips off normally with a flat blade or knife (Blunt knife if possible as a sharp one may cut the upholstery)
Once removed you should be able to see the retaining bolts that hold the mirror to the door.
If you have electric mirrors there should be a multi wire electrical plug you will have to disconnect before removing the mirror.
Hope this helps
May 30, 2009 | 2005 Ford Focus
2000 Ford Focus ZX3 Passenger Mirror Replacement (Manual)
remove the defroster vent, it just clips in. Remove the conections for power window. there might be two small screws nere what would be the corners of the mirror assembly,remove them. There is 1 large slotted type screw dead center of the mirror assembly.Remove that screw taking care not to drop it into the door. Done.
May 19, 2009 | 2000 Ford Focus
2008 Ford Fusion Wing Mirror Replacement
I checked Ford Focus mirror replacement and it seems to be the same. This is for the manual, unheated mirror.
Remove the mirror cover inside the door - slide a screwdriver behind the cover and pry loose carefully.
Remove the single 10mm bolt and the mirror comes free.
NB. Do not drop the bolt into the door.
Apr 02, 2009 | 2008 Ford Fusion
How to replace passenger mirror on 2007 Ford Focus
it has 2 screws. remove the pblack plastic triagle shaped cover for access. inside of the door.
Jan 18, 2009 | 2007 Ford Focus (3 Door) Hatchback
? Ford Focus Mirror replacement (manual)
there are two screws that hold the mirror on one is at the edge of the door frame and the other is behind the trim piece by the window the knob cover just twists off no adhesives needed
Nov 16, 2008 | 2007 Ford Focus (3 Door) Hatchback
Need to replace driver side manual mirror, I have a replacement, what is the process?
remove rubber boot lockingring remove interior cover remove mirror fixing scews remove mirror assemble may have to take out door trim screws to allow you to get cables in and out then reverse to refit takes about 30 mins a bit fiddly trev uk
Jul 17, 2008 | 2003 Ford Focus
Baby Gear Logo
873 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
