Question about Whirlpool Duet GHW9150P Front Load Washer
Door lock doesn't release when wash is completed.
  • 5,081 Answers
If your door is already locked and you get an "F" error press and hold the cancel button, and select drain/spin. If this still doesn't work and your clothes are trapped inside do not resort to getting out the crow bar and a sledge hammer. (Though you may really feel like doing just that). You can manually unlock the door by following these steps:
- Unplug washer or disconnect power.
- Remove the lower kick panel.
- Reach up along the inside of the front and locate the bottom of the door switch/lock unit.
- Located on the bottom of the door switch/lock unit is a teardrop shaped tab.
- Gently pull the tab down about a 1/4˝ or until a click is heard.
- The door may be now opened.
Posted on May 15, 2010
My washing machine works but the door does not want to unlock
my moms did that once and all we dlid was put it on spin right before the off position if it has a knob and not buttons and as soon as it is done it should release it. We did do this 2-3 times before it released but it did release. When it opened we found trash and cloth pieces near the holes where the lock is located cause we cleaned it out with a pipe cleaner and our fingers but it was unpluged and completely off at that time hope it helps.
Dec 23, 2012 | Washing Machines
ERROR CODE NP AND NOW DOOR WON'T OPEN
Hello first try unplugging the machine for 7 minutes if this doesn't then allow you to open the door then you can manually release the door lock by taking off the dispenser assebly holder (bezel) and pulling on the door lock release cord you will find inside. Also as far as the nP I think the erro your seeing is ND which is no drain in which you can click this link
http://www.fixya.com/support/t340703-maytag_neptune_error_code_nd another tech has posted with pictures on this issue. IF you have any further questions message me back Thanks
Rick
Sep 25, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a whirlpool duet, new, and it is coding F01, double beeping, and the door is locked. Can we figure out what is wrong? Please? Before I..... throw this **** thing out the door. thanks :)
Remove the bottom panel and reach up to the door latch. There is a tab in there you can pull to release the door lock. Then try unplugging the machine for a few minutes. If this doesn't work you will need to replace the motor control.
Aug 06, 2011 | Whirlpool GHW9400 Duet Washer
My front loader hydrax model washing machine cannot open its door even after the washing cycle has completed I have tried to contact the local dealer and is taking a very long time to come inspect and my...
If the drain pump/alve has worked and the water has drained off the machine then you can reset the door switch by pushing the safety lever down to release the lock on the door .
Now this can be done only if you can observe very carefully using a good position and light to locate the door lock and release lock lever from the program controller.
Once this is done , check the program without clothes on a low wash and see if the door jams or if this is a fault on the program controller unit.
May 19, 2011 | Thomson Washing Machines
Door wont open
Most washing machines electromagnetically lock when on a cycle and remain so for a few minutes after it has finished. If you turn the electricity off/switch it off before it has unlocked, the door may not open.
Try turning the power on for a few minutes and see if it will release. If that doesn't work, put it on the shortest cycle, eg spin and wait for it to complete before you turn it off
or check their is no water in the drum, if their is check the drain pipe isn't creased.
If not pull out your machine if reqd , and check the pump is not blocked, more common than you think. Can be located at the front or back of your machine.
If none of these turn off your socket for 10 mins.
Apr 30, 2011 | Washing Machines
I have a front louder newer model samsung washing machine. The door was forced opened during cycle and now the lock is still in the locked position and I cannot reclose the door or get the locked to unlock...
The machine has to reset to bringg tthe lock to release, check the link to the lock settings to make the program complete the cycle and release the lock. Do not force it as you end up damaging.
Sep 01, 2010 | Samsung WF206ANS Front Load Washer
Completed cycle, door locked tho, help
you need to drain the water and the door should release ,check filter
Jan 12, 2010 | Washing Machines
Door won't open on Hoover vhd9163zd washing machine
THE DOOR MAY HAVE A TIME RELESE SWITCH CHECK IN MANUAL
Dec 24, 2009 | Washing Machines
Door Stuck after wash completed
You will have remove top cover, and release door latch from inside the front, with a screw driver pushing against the latch to open door.
It does mean that you probably have a faulty door lock, or broken door handle.
Please rate my fixya solution.
Thanks
Jan 11, 2009 | Ariston Technologies Ariston AWD12 Front...
Whirlpool Duet GHW9150P Front Load Washer Logo
16 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
