Question about Car Audio & Video
Installed a radio (cy-620) from a 2005 sentra into a 2002 sentra (cy-358) now i have no sound from left side speakers.
SOURCE: Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
Posted on Aug 28, 2007
  • 12 Answers
SOURCE: both rear speakers on my z540 system play only the left side rear
Hmmm, this sounds like either a driver issue, or a card/compatibility issue. you might try reverting to old drivers(last resort), making shure you have 4.1 enabled in sound control pannel(do this first), triple checking connections/connectors on both the speakers and the card(remember, you only have 5 speakers, not 8) and if you have the headphone-type phone plug for your speakers, you might try making shure that they are compatible with the jacks on your card, although, I would have to know more about your setup to be completely shure.
Posted on Dec 27, 2007
shaggyrat
  • 1224 Answers
SOURCE: 2004 Harley UC Radio - no sound on Left side
how about the antenna this could be the main problem im not a motorcycle expert but radios i do know and if your getting static the antenna which is called the aireal << spell check is not picking up enough signal
also head phones could be also a bad set
Posted on Jun 10, 2008
thaurfen
  • 623 Answers
SOURCE: Left Side of the car Speakers not working
yes there is a short for sure re install all wires
make sure all connection are properly attached...
Posted on Aug 31, 2008
techprogrami
  • 57 Answers
SOURCE: No sound comming from the left side speakers in my 04 Envoy XUV.
first> road vibrations can cause cable connections to come loose so you can start by taking out your radio and making sure all of the questions in the back are connected as they should be.
Second> if this doesnt seem to work then the next step is to check the wires going to the speakers that arnt working (this will b quite a job, but if you can do it, it will save u quite a bit of money) .. checking the wires your checking for >bad connection to the speakers >cuts in the wire or if any part of the wire is touchin any other metal object
Was This Helpful ?
Posted on May 29, 2009
2002 nissan sentry xe radio wiring color code
2002 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
Oct 18, 2016 | 2002 Nissan Sentra
yes there is certain chance for short circuit so better check whether the connections are proper ............
Aug 31, 2008 | Car Audio & Video
I am installing a CD player in a 2004 Nissan Sentra and I need to find the wiring diagram to show me how. Can you help?
see connection colors below and let me know if you have questions.
2004 Nissan Sentra wire colors aftermarket radio wire colors
Car Radio Constant 12v+ Wire: Pink, yellow
Car Radio Switched 12v+ Wire: Blue, red
Car Radio Ground Wire: Gray, black
Car Radio Illumination Wire: Red/Green, N/A (tape off factory wire)
Car Stereo Dimmer Wire: Red/Yellow, N/A (tape off factory wire)
there is no factory amplifier wire, blue (tape off radio wire)
Left Front Speaker Positive Wire (+): Pink, white
Left Front Speaker Negative Wire (-): Blue, white/black
Right Front Speaker Positive Wire (+): White, gray
Right Front Speaker Negative Wire (-): Black, gray/black
Left Rear Speaker Positive Wire (+): Light Green, green
Left Rear Speaker Negative Wire (-): Violet, green/black
Right Rear Speaker Positive Wire (+): Blue, violet
Right Rear Speaker Negative Wire (-): Pink, violet/black
Aug 21, 2011 | Car Audio & Video
Replacing oem car radio/CD (Clarion PN-2165M I) from 2002 Nissan Sentra GXE. I ordered Scosche Car Stereo Connector to avoid cutting OEM connector. Im confused about the OEM Radio/CD wiring colors as to...
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Rear Speakers Size: N/A
Rear Speakers Location: N/A
May 25, 2011 | Clarion Car Audio & Video
2002 nissan sentra radio wire diagram
Oct 03, 2010 | Car Audio & Video
I just bought a 2004 Nissan sentra 1.8 S...I have two issues 1) my service engine light came on one day after I drove it off the lot. 2) there is no sound in left side speakers and both the right side...
the slimeball, um, person that sold you the car knew about the ck eng light. He cleared the codes, and after clearing the codes the ecm has to run tests, if a component fails the test 2 times, it turns the light on. You will need the trouble code to see what has failed. As for the speakers, did you find the balance knob on the radio?
Jun 11, 2010 | 2004 Nissan Sentra
My sentra car stereo left rear speaker does not work. i pulled the speaker and plugged it into the rear right wire connection and the speaker works fine. does this mean my stereo is going bad ?
No it means the other side has come disconnected or is bumping up against another wire and shorting the speaker out. You need to trace the wire in question and I would hook the speaker back up and take the radio part way out of the dash. Then with the radio on move aroung the wires with your hand behind the radio and see if you hear that speaker coming off and on. If so your close. Just trace it to the problem by continuing to move the wires. If it is not back behind the radio then start at the speaker end and follow that wire with the radio on until you come to either a broken wire or a bare spot in the wire touching metel and fix it accordingly. Let me know how this turns out and please leave me a good thumbs up for trying for you. Raz
Apr 20, 2010 | 2003 Nissan Sentra
Radio wiring diagram for a 96 thunderbird with premium sound
1996 Ford Thunderbird Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Black/Orange
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Dimmer Wire: Light Green
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: Dark Blue
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Green
Right Front Speaker Wire (-): Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Jan 13, 2010 | Car Audio & Video
No sound out of left side speakers, front and back.
easiest way to see if the left outputs have gone is to swap the right and left speakers over. if the left works out of the right channels you know if the set has had it.hope this helps
Apr 22, 2009 | 2004 Nissan Sentra
Stereo wire diagram
1995 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Illumination Wire: Red/Blue
Mar 25, 2009 | 1995 Nissan Sentra
Car Audio & Video Logo
85 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
