Question about Dryers
Dryer doesn't start
When I press the start button (and keep it pressed) there is a faint sound coming from the timer. Could it be a fuse or is it the timer?
  • 1 more comment
  • DRogowski Mar 30, 2008
    How/where do you check the thermal fuse? Kenmoe 11062922100
  • stermolle Jun 27, 2008
    Maytag Atlantis Electric dryer. Won't start. The light comes on when you open the door, and you can hear the timer running, but no go. Have checked the circuit breaker, and other 'dummy troubleshooting' in the manual. Where is this thermal fuse??? How do you troubleshoot the switch if necessary?
  • nfharvey2000 Aug 25, 2008
    When the dryer has been running for a while and is warmed up it will not restart. It just makes a humming noise and then an overload or something kicks out and then you can smell something burning.
  • 89 Answers
The faint sound seems normal. Sounds like it could be a thermal fuse. Also if the dryer is electric check your breaker box first.(there are two breaker fuses for electric dryers).... If one is blown then it may cause this problem....... Back to thermal fuse, they are easy to check... If not thermal fuse it could be the start switch or relay...... if you still have problems please respond back with model and make...
Posted on Mar 30, 2008
  • Brian Gillespie
    Brian Gillespie Mar 31, 2008
    Open back of dryer... About 10 1/4 inch screws have to be taken out.. There are two fuses back there... One is slinder and white. ohm it out. Theres another one the size of a dime.... You can always tell a fuse by the color of the wires going to it will be the same... goodluck....
sounds like u got a bad motor. try holding the lid or door switch in while u press the start button. if u give the tub a little help and it starts going then it is the motor.
Jul 25, 2013 | Dryers
I've changed the belt on my indesit is60v but now it will not start could it be a loose wire? my test pen says power is going from the start button to the timer
Just because power is getting to the switch doesn't necessarily mean the switch isn't bad. It is also possible that the motor or timer is defective.
May 12, 2012 | Indesit IS70C Electric Dryer
I have a Whirlpool dryer, model ler5644awo.When I set the timer and press the start button, you can hear the timer running but, the drum doesn't and the heating elements don't heat.could it be the...
Hello, welcome to FixYa.
Based on your post I understand you have a Whirlpool dryer that you stated "
set the timer and press the start button, you can hear the timer running but, the drum doesn't and the heating elements don't heat", correct ?
Having said that, by far and away the most common and the first thing I'd look for on these dryers is the fuse which is located on the blower housing, not likely the timer or start switch.
**Unplug the dryer from the wall before performing any service or removing any first**
You can use the link below for a tutorial video to locate, test and replace the fuse that is specific to your model.
**please check the part with an ohm meter or "jump it out" (if you know how, if not, check the second link it will show you) before replacing it...the timer or start switch is possible, just not as likely as I mentioned**
Let me know if I can assist you in any other manner going forward and I'll be glad to do so.
If this info provided solves your problem, please take a second to accept my solution and rate it accordingly. Good luck and thank you for choosing FixYa today.
Macmarkus :)
Oct 30, 2011 | Dryers
Dryer will not turn on although the timer is working
IF your hearig a click when you push the start button then the button and relay are good check the saftey switch on the door to see if it has come loose and follen down or moved back if the switch is not pressed the motor will not work also I have seen the switches go bad you need to unplug the dryer and cross the too wires togeather plug the dryer back in and press the start button if she starts order a new swith. The motor could also be bad you nees to remove the back cover and check to see when the button is pressed if you are getting the correct voltage you will need a volt meter to check this they cost around 10- 20 bucks if you have correct voltage from the wires and the conections to the motor are ok the motor is no good and needs to be replaced hope this helps...
Jul 07, 2009 | Kenmore Dryers
Whirlpool dryer will not start when I press the start button.
frist check the door switch in sure it is working if it is good unplug the dryer remove the back cover where the vent comes out there is a little white fuse with 2 wires on it. it is oblong and most of the tim the 2 wires are blue replace this fuse and your dryer should work fine.
Jan 19, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore 73954 : Only runs when the START button is continuously pressed
The start button starts the motor heater and energizes a relay that latches closed to keep the motor and heater running untill the timer switch or door switch cut the power to the relay and the relay opens.
The latching relay has failed or disconnected
if all the cables are attached to the relay
replace relay
not an expensive item, usualoly good for 10years
dryer circuits look like this, the start switch and relay are drawn just to the right of the motor, this diagram has no relevance to the physical position of the parts
Aug 22, 2008 | Kenmore 63942 Dryer
Dryer will not start properly, buzzer operating
more than likely your timer is faulty too much to replace most timers about same price to replace your dryer if not cheaper
Mar 16, 2007 | Candy CIV60 Electric Dryer
psrao, right next to the timer under the consol is the even heat board. When this fails, it will cause this problem. This has been an issue with this model. Part number for the board is 3978949. back.
Jan 14, 2007 | Kenmore 73952 Gas Dryer
Dryers Logo
142 people viewed this question
Top Dryers Experts
