Question about Refrigerators
GE Refrigerator Model TBX18QPNL [Serial SG509659] freezer or refrigerated sections are pulling down to required temperatures for either. This despite moving thermostat throughout entire range one setting at a time and waiting 24 hours in between each setting change. What is the most likely cause (s) of this anomaly and the corrective action (s) necessary to resolve same?
  • bigmdguy May 15, 2010
    I appreciate having an idea of where to begin -- I will attempt to follow these troubleshooting ideas and the suggested corrective actions and will report back on the outcome once this has been completed.
  • 4,059 Answers
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM). If it's totally blocked with ice--
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
you have a defrost timer you can test it . Yours is in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Part 648 on this diagram is your defrost timer. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=224645&diagram_id=20952025#d20952025
This diagram shows your other defrost components. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=224645&diagram_id=20952026#d20952026
Posted on May 15, 2010
The compressor of my GE PFE 29PSDASS floor model comes on for a few seconds then goes off. The lights remain on. What is wrong?
Refrigerator Repair Help ' Appliance Aid
www.applianceaid.com > ... > Refrigerator Help Section
I heard a sizzling noise inside my freezer section and it looked like something ... Myfridge makes a bang noise when it shuts off; My Frost free fridge will not run at all; Myfridge is making screeching/squeak noises; My GE SxS fridge door has ... an amp meter, each compressor is rated in running amps ( see model/serial tag ...
GE Refrigerator Repair Online Manual ' General Electric ...
www.appliancerepair.net/ge-refrigerator-repair.html
FREE ONLINE GE refrigerator repair manual - Diagnose and troubleshoot ... to know basically how the bloomin' thing works, and then get on with fixing it? ... Chapter 5: GErefrigerator problem: Refrigerator is not cold and compressor is ... Do you have somequestions that you would like to ask a professional GE repairman.
Dec 17, 2015 | GE Refrigerators
GE GSS25KGTB-BB side by side refrigerator. Serial # HL 416525 Ice occasionally melting during defrost cycle(?) Currently trying to act up on me Set at -3/39 but is now passing through +6/45...
Hello Robert; Sorry for the delay in answering your question, but the site did not send me a notification. From you description of your problem the most likely cause is the temperature sensor.
on diagram
Temperature sensorPART NUMBER: WR55X10026
Substitution: WR55X10025
It is located in the freezer section of your unit next to the evaporator. Before you replace it, I would first try to defrost it, sometimes a small amount of ice will build up on it and cause it to sense a lower temperature than what is required.
Houston AKA ImJustAvg
Oct 23, 2011 | GE Adora DSS25KSTSS Stainless Steel Side...
My refrigerator side isn't cooling the freezer is fine on my GE Monogram Model zisb42dca
Possible faulty freezer fan motor. Dirty condenser. Faulty control board.
Feb 23, 2011 | GE Refrigerators
FREEZER GETS COLD BUT BOTTOM DOES NOT
When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.
Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Feb 23, 2011 | GE GTS22KBP Top Freezer Refrigerator
I have a GE side by side refrigurator model Gss201epc ww serial Tf220054 and am having a problem with stuff freezing in the crisper, I do not see any type of adjustment any ideas here? Thanks
initially, set the refrigerator compartment control at 5 and the freezer control at 5 and allow 12 hours for the temperature to stabilize.
Several adjustments may be required. Adjust the controls one increment at a time, and allow 12 hours after each adjustment for the refrigerator to reach the temperature you set.
Adjustable Humidity Crispers and Snack Pan (on some models)
HIGH LOW
HIGH LOW
Normal
Coldest
Slide the control all the way to the High setting to provide high humidity recommended for most vegetables.
Convertible Meat Pan (on some models)
The convertible meat pan has its own cold air duct to allow a stream of cold air from the freezer compartment to flow around the pan.
The variable temperature control regulates the air flow from the freezer compartment.
Slide the control all the way to the Low setting to provide lower humidity levels recommended for most fruits.
Dec 20, 2010 | GE GSS20IEP Side by Side Refrigerator
Clicking of Ge Model PDS22SBRBRSS; serial No; AHO45649
Replace the mother board. It is only a matter of time until you experience cooling issues.
May 26, 2009 | GE Profile PDS22MHR Bottom Freezer...
Freezer works but refregerator is warm
If this is the model I am thinking about, you have the same compressor for each side. There should be a vent or opening that you can adjust to let cool air inside the refrigerator. Find it and adjust. You may have this opening blocked by something. Let me know if this fixes the problem.
Jan 24, 2009 | GE GBS18HBM Bottom Freezer Refrigerator
GE PTS22SHS Top Freezer Refrigerator temperature problem (-43)
Its always good to have a backup , the problem with your new ge is the sensor or the whole control board , ge will most likely pay you for what you lost in the unit. The sqeeky wheel gets the oil. Sorry I know the feeling , Good luck
Dec 30, 2008 | GE PTS22SHS Top Freezer Refrigerator
Ge after replace fan still fan not working
Something to check for. Is the top of the refrigerator door lower than the freezer door? If so the ref. light may not be turning off all the time. Pull bottom panel off to expose hinges. The ref hinge should have an adjuster. Adjust door up to be level with freezer.
Aug 03, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
