Question about Toshiba 43H70 43" Rear Projection Television
42 toshiba rear pro
How to repair burn in
  • Toshiba Master
  • 8,617 Answers
Burn in is caused when the phosphorus is gone from the face of The CRT . The only way to get rid of it is to replace the afected CRT or have it rebuilt. CRT rebuilders are hard to locate and most rebuilders are almost equal to what a new CRT would cost.
Posted on Mar 30, 2008
My toshiba 42h83 tv has sound but no picture
of course check different inputs etc to make sure something did not get disconnected.
This rear projection set uses 3 picture tubes and the set will protect them if there is a problem in the vertical or horizontal sweep circuits that might burn the screens or the damage the tubes.
No simple answer as a lot of different parts are possible for this problem.
Apr 27, 2012 | Toshiba 42H83 42" Rear Projection...
Is it safe to play video games on your projection televisions?
Yes,but just don't pause the game's or leave the game without playing for a long time like about 1 to 3 hours.Because DLP tvs and Plasma tvs have higher rate picture screen burn in.The image burn in,the tv picture screen panel are useless,because there no way to get rid of the previous images burn in.
Jul 18, 2010 | Toshiba 42H81 42" Rear Projection...
Tech tips toshiba burns fuse
If F801 blew off then check standby power supply section and if F860 blew off on pressing power button then check inverter transistor (power out) on power supply board.
Sep 17, 2009 | Toshiba 42H81 42" Rear Projection...
Toshiba projestion 42 has what looks like 3d in the picture
the toshiba convergence repair kit is available at the following link for your model. It contains the parts and cd with detailed instructions
http://www.tvrepairworld.com/
Jul 18, 2009 | Toshiba 42H81 42" Rear Projection...
Toshiba 50 inch projection
In the convergence circuit, where the amps themselves are soldered to the foil side of the board, may be ring cracked. What you're doing by forcing it to start is causing an arc to form between the crack until the heat has built-up sufficiently to expand that joint and make contact. Eventually you will burn out the amps, overheat the return resistors and/or open some of the pico fuses in that circuit and send the repair bill that much higher... Better to pull that board, get out a good soldering tool and some solder and a good pair of reading glasses and locate / resolder those joints that are ring cracked...
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Oct 21, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba rezga 32 " broken
$300-500 replacement cost, installed by a pro, if you find one that doesn't tell you that you can replace the toshiba 720p 32" at a cost of $750(online) or with a toshiba 42" for $999(online). Your call.
Sep 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba 42pw33p rear projection tv
crt repair
http://www.riddledtv.com/repair/journal/Toshiba51H84/index.html
Jan 05, 2008 | Toshiba 42H81 42" Rear Projection...
TOSHIBA REAR PROJECTION TV 42H81
FIRST DO MANUALY (THE ALIGNMENT OF CRT'S)
May 12, 2007 | Toshiba 42H81 42" Rear Projection...
Red is out of line
Is time to call a Pro,the repair will need parts replaced and then it might need to be adjusted from the service menu.
Sep 19, 2006 | Toshiba 42H81 42" Rear Projection...
Toshiba 43H70 43" Rear Projection Television Logo
54 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
